Dynatrace provides end-to-end observability for AWS Lambda functions through distributed tracing, log correlation, and AI-powered insights using auto-instrumentation without code changes. The OneAgent AWS Lambda extension collects logs directly from Lambda functions, offering an alternative to CloudWatch via Firehose with lower cost, lower latency, and easier setup.
Collect logs from AWS Lambda functions
Monitor AWS Lambda (built-in) and view available metrics.
AWS Lambda instrumentation is available for the following runtimes:
| Runtime | Lambda layer version1 | Applies to Lambda Classic |
Python | 1.321 (or later) | Yes |
Node.js | 1.319 (or later) | Yes |
Java | 1.319 (or later) | Yes |
.NET | 1.335 (or later) | Yes |
Go | 1.333 (or later) | Log Monitoring only |
Managed offline clusters are not supported.
For more details, see Technology support.
For AWS Lambda, monitoring consumption is based on Davis data units. See Serverless monitoring for details.
