Size Dynatrace ActiveGates in Kubernetes
  • Latest Dynatrace
  • How-to guide
  • 5-min read
Setting appropriate resource requests (and limits, when needed) keeps your ActiveGate instances stable and predictable. A stable, healthy ActiveGate ensures continuous gap‑free monitoring data.
This guide details sizing recommendations according to the deployment type, deployment size, and assumed workload.
Deployment recommendations
Use separate ActiveGates
We recommend to run two sets of ActiveGates for production deployments:
  • One set should cover Kubernetes platform monitoring, including any Prometheus integration and Kubernetes Security Posture Management (KSPM) functionalities.
  • One set should cover OneAgent traffic routing and telemetry ingest (including OTLP log ingest).
Using two sets of ActiveGates has several advantages:
  • Isolation: A spike in OneAgent traffic won't slow down Kubernetes metrics collection, and vice versa.
  • Independent scaling: OneAgent traffic routing and platform monitoring have fundamentally different scaling characteristics, see How to scale ActiveGates. Separate ActiveGates let you scale each dimension independently without over‑provisioning resources.
  • Easier troubleshooting: When issues occur, you can immediately identify whether they originate from platform monitoring or OneAgent traffic, reducing diagnosis time.
When traffic increases beyond the capacity of your current ActiveGate deployment, you can scale in two ways:
  • Scale horizontally: Increase the number of ActiveGate replicas in your DynaKube configuration. This allows the Kubernetes Service to distribute incoming traffic across multiple ActiveGate instances.
  • Scale vertically: Increase CPU and memory resource requests for your ActiveGate replicas. Use the resource recommendations tables above as a starting point and adjust based on your actual throughput requirements. Adjust the requests first and then, if necessary, adjust the limits. Use CPU limits only if required by policy.
Sizing recommendations
The following sections cover the four main deployment types: Kubernetes Platform Monitoring, OneAgent traffic routing and proxying, OTLP log ingestion, and combined log ingestion and OneAgent traffic routing. Identify your deployment type and apply the corresponding recommendations.
For each deployment type, we've organized recommendations according to the following cluster sizes: small, medium, and large.
Cluster sizePodsNodes
Small
<1,000
Up to 25
Medium
1,000–5,000
Up to 100
Large
5,000–20,000
Up to 500
This guide does not cover environments with more than 20,000 pods; as a starting point, use the large cluster size guidance and gradually increase resources until stable gap-free monitoring is established.
Node count is a secondary sizing driver. For clusters beyond 500 nodes, contact Dynatrace Support for tailored recommendations.
This section provides sizing recommendations for the ActiveGate that handles Kubernetes Platform Monitoring, whether alone or in combination with Application Observability and Full-Stack Observability.
Cluster sizeCPU requestsCPU limitsMemory requestsMemory limits
Small
200m
1000m
6 GiB
6 GiB
Medium
1000m
2000m
10 GiB
10 GiB
Large
2000m
4000m
12 GiB
12 GiB
This section provides sizing recommendations for an ActiveGate that handles OneAgent traffic routing and proxying. If this ActiveGate should also handle log ingest via API, see Combined log ingestion and OneAgent traffic routing.
Cluster sizeCPU requestsCPU limitsMemory requestsMemory limitsReplicas
Small
250m
1000m
2 GiB
2 GiB
3
Medium
500m
2000m
4 GiB
4 GiB
3
Large
1000m
4000m
6 GiB
6 GiB
6
The sizing recommendations are based on representative workload testing:
  • Workload: OneAgent traffic routing including metrics, traces, events, and log module data.
  • Log traffic assumption: Average production load of 100 KB/min per monitored pod.
OTLP log ingestion
This section provides sizing recommendations and throughput benchmarks for ActiveGates that handle log ingestion via the OTLP API endpoint.
Cluster sizeCPU requestsCPU limitsMemory requestsMemory limitsOTLP log throughput per replica
Small
250m
1000m
2 GiB
2 GiB
350 MB/min
Medium
500m
2000m
4 GiB
4 GiB
650 MB/min
Large
1000m
4000m
6 GiB
6 GiB
1,200 MB/min
  • Workload: Sustained log ingest via OTLP over HTTP (uncompressed).
  • Message sizes: 5% extra-small (1.5 KB), 20% small (1.5 KB), 50% medium (2.2 KB), 20% large (3 KB), 5% extra-large (7.8 KB).
  • Attribute counts: Varying from 5 to 100 attributes per log record.
  • Batch sizes: Varying from 10 to 100 messages per API call.
  • Test environment: Kubernetes cluster on Google Cloud Platform using e2-standard-8 machines (x86_64).
  • Deployment configuration: ActiveGate provisioned with resource allocations matching the recommendations in the table above.
These resource configurations provide headroom for traffic spikes and replica failover during updates.
The sustained throughput values represent performance that meets all quality gates. Peak burst throughput may be higher for short durations.
This section provides sizing recommendations for an ActiveGate that handles both log ingestion and OneAgent traffic routing in a unified deployment. If your ActiveGate does not have any log ingestion via API, see OneAgent traffic routing and proxying.
  1. Determine base configuration: Start with the base ActiveGate configuration for your cluster size from OneAgent traffic routing and proxying.
  2. Calculate additional replicas for OTLP log traffic: Use the per-replica throughput values from OTLP log ingestion to calculate how many additional replicas your deployment needs: additional replicas = ceil(expected log traffic (MB/min) ÷ throughput per replica). Add these replicas to your base configuration as calculated in step 1.
As an example, if your cluster generates 1,500 MB/min of OTLP log traffic and you're using the medium resource config (650 MB/min per replica): ceil(1,500 ÷ 650) = 3 additional replicas.
If you observe consistent resource exhaustion (CPU usage >80%, memory usage >85%, or frequent GC pauses), consider splitting the workload into separate ActiveGate deployments rather than continuously increasing resources for a single deployment. Separate deployments provide better isolation and independent scaling. For more information, see Deployment recommendations.
Log Agent traffic routing capacity benchmarks
This section provides a reference benchmark for ActiveGate throughput when handling Log Agent traffic routing. The throughput values shown represent compressed log data volume and reflect the recommended operating maximum under sustained conditions.
How to use this benchmark:
  • Calculate your log traffic volume: Estimate your total OneAgent log traffic volume (in MB/min). This depends on your application's logging behavior and volume, not just the number of pods.
  • Scale resources proportionally: Throughput scales approximately linearly with CPU and memory. Use the benchmark values in the table above as a reference point and adjust resources based on your expected log traffic volume.
  • Headroom is included: The listed values already reserve capacity for traffic spikes and replica failover. If you consistently exceed the recommended throughput, add replicas or increase per-replica resources. For more information, see How to scale ActiveGates.
CPU requestsCPU limitsMemory resource requestsMemory resource limitsSustained maximum throughput per replica
500m
2000m
4Gi
4Gi
750 MB/min
Actual throughput may vary depending on your infrastructure, OneAgent version, and workload composition. Monitor your ActiveGate instances and adjust resources based on observed performance.
Monitor and validate
Monitor your ActiveGate instances to ensure load is distributed appropriately and adjust your scaling strategy based on observed performance and resource utilization patterns.
This section describes how to monitor your ActiveGates and verify they're behaving as expected.
Signs of an unhealthy ActiveGate
These symptoms indicate exhausted resources and potential data loss:
  • Gaps in monitoring data: ActiveGate collects different types of data independently (for example, Prometheus metrics, Kubernetes events, entities). If one collection task takes longer than one minute, only that data type experiences a gap for that window. Other collection tasks continue operating normally.
    • Metrics will have missing data point for the given minute.
    • Events for the given collection timeframes are not available at all.
    • Entities may not reflect the latest updates or may be missing at all if short-living.
  • Heavy CPU throttling: Sustained high throttling means insufficient CPU. Heavy throttling can cause gaps. Minor throttling is usually harmless. If the throttling affects the pod serving the monitoring ActiveGate this can cause data gaps.
  • Out‑of‑memory kills: If the ActiveGate is OOM-killed, data becomes unavailable until it restarts. After a restart, repeated OOM kills are likely to occur.
Observe health with platform metrics
Dynatrace provides two ready-made dashboards to help you observe your ActiveGate health: ActiveGate diagnostic overview and Kubernetes Monitoring Statistics. To access these, go to Dashboards Dashboards > Ready-made and search for the dashboard by name.
Additionally, you can use DQL to query the following platform metrics and build your own dashboards or notebooks.
IndicatorWhen to actPlatform metrics for validationClassic metrics for validationDetail level
CPU usage
Utilization consistently exceeds 85%: increase the CPU request.
dt.kubernetes.container.cpu_usage
builtin:kubernetes.node.cpu_usage, builtin:kubernetes.workload.cpu_usage
ActiveGate pod
CPU requests
dt.kubernetes.resourcequota.requests_cpu
builtin:kubernetes.node.requests_cpu, builtin:kubernetes.workload.requests_cpu
ActiveGate pod
CPU throttling
Throttling consistently exceeds 10%: increase the CPU request. Calculate by dividing container_cpu_cfs_throttled_periods_total by the number of periods.
dt.kubernetes.container.cpu_throttled
builtin:kubernetes.workload.cpu_throttled, builtin:kubernetes.node.cpu_throttled
ActiveGate pod
Memory working set
Usage consistently exceeds 80%: increase the memory requests.
dt.kubernetes.container.memory_working_set
builtin:kubernetes.node.memory_working_set, builtin:kubernetes.workload.memory_working_set
ActiveGate pod
Memory requests
dt.kubernetes.resourcequota.requests_memory
builtin:kubernetes.node.requests_memory builtin:kubernetes.workload.requests_memory
ActiveGate pod
Restart count
After an OOM-based restart, promptly raise the configured memory to prevent recurrence.
dt.kubernetes.container.restarts
builtin:kubernetes.container.restarts
ActiveGate pod
OOM kills
Any OOM kills: increase memory limits to prevent restart cycles.
dt.kubernetes.container.oom_kills
builtin:kubernetes.container.oom_kills
ActiveGate pod
Processing duration
Pipeline execution consistently exceeds 50–60 seconds: increase the CPU request. Also depends on ingested data volume and other factors.
dt.sfm.active_gate.kubernetes.pipeline_duration
dsfm:active_gate.kubernetes.pipeline_duration
ActiveGate ID
Garbage collection times
Increasing GC times indicate an under-provisioned ActiveGate.
dt.sfm.active_gate.jvm.gc.major_collection_time
dsfm:active_gate.jvm.gc.major_collection_time
ActiveGate ID
Factors that drive an increase in resource consumption
Actual required resources increase with:
  • Number of pods: The primary sizing driver is the number of monitored pods. The resource consumption (CPU and memory) for Dynatrace ActiveGate components scales with the number of pods primarily due to increased data processing and storage needs. As the number of monitored pods grows, the ActiveGate handles more entity data, events, and metrics, resulting in higher CPU load for ingestion and processing, as well as increased memory for caching pod-related information. This is the primary sizing driver, with consumption scaling proportionally to pod count.
  • Log traffic volume: For ActiveGates handling log ingestion (via OTLP endpoints or OneAgent log modules), log traffic volume is an important sizing driver. Resource requirements scale with the volume of log data (measured in MB/min), not only the number of pods. A small number of pods with verbose logging can generate more traffic than many pods with minimal logging.
  • Prometheus metrics volume: The number of Prometheus annotated pods directly correlates with increased resource requirements for Dynatrace ActiveGate, primarily through higher CPU consumption. As the count of annotated pods rises, the volume of scraped metrics grows, demanding more CPU cycles for collection, aggregation, and forwarding tasks. Memory impact is secondary, as metrics are forwarded to the Dynatrace tenant without long-term storage on the ActiveGate, though it scales proportionally with peak ingest rates.
  • Number of nodes: The resource consumption (CPU and memory) for Dynatrace ActiveGate components scales with the number of nodes primarily due to increased monitoring overhead and load from node-level system pods. As the node count grows, the ActiveGate must handle more system-level data collection, entity processing, and event ingestion, leading to higher computational demands. This is a secondary driver compared to the number of pods, but it contributes proportionally to overall resource needs, especially in larger clusters where node-level monitoring adds cumulative load.
Scrape Prometheus metrics
Dynatrace supports up to 1,000 pod exporters, with each exporter able to provide up to 1,000 metrics. If your environment approaches these limits, you'll need to increase the resources allocated to the ActiveGate to ensure reliable performance.
For high-volume Prometheus scraping, and for new deployments, we recommend the OpenTelemetry Collector.
Example DynaKube resources
Adjust requests (and limits if required) to fit your environment.
CPU limits are commented out. We recommend defining requests only so the ActiveGate can use additional CPU when available. If limits are required, set them equal to or higher than requests.
This DynaKube covers Kubernetes platform monitoring and OneAgent traffic routing in a single resource. The routing ActiveGate is sized for a large cluster (5,000–20,000 nodes); the Kubernetes monitoring StatefulSet is sized for a medium cluster (1,000–5,000 nodes) and can be scaled independently. It includes optional (commented-out) configuration for Kubernetes Security Posture Management, OTLP log ingest, log monitoring, telemetry ingest, and the OTel Collector.
apiVersion: dynatrace.com/v1beta6
kind: DynaKube
metadata:
namespace: dynatrace
spec:
apiUrl: https://ENVIRONMENTID.live.dynatrace.com/api
tokens: <SECRET NAME>
# Link to api reference for further information: https://docs.dynatrace.com/docs/ingest-from/setup-on-k8s/reference/dynakube-parameters
oneAgent:
applicationMonitoring: {} # or cloudNativeFullStack: {}
activeGate:
capabilities:
- routing
- debugging
resources:
requests:
cpu: 1000m
memory: 6Gi
limits:
# cpu: 4000m
memory: 6Gi
replicas: 6
kubernetesMonitoring:
registration: {}
resources:
requests:
cpu: 1000m
memory: 10Gi
limits:
# cpu: 2000m
memory: 10Gi
#kspm:
#mappedHostPaths:
#- /etc
#- /usr/lib
#- /var/lib
#logMonitoring: {}
#telemetryIngest:
#protocols:
#- jaeger
#- otlp
#- statsd
#- zipkin
#serviceName: telemetry-ingest
templates:
#kspmNodeConfigurationCollector:
#imageRef:
#repository: public.ecr.aws/dynatrace/dynatrace-k8s-node-config-collector
#tag: 1.5.2
#logMonitoring:
#imageRef:
#repository: public.ecr.aws/dynatrace/dynatrace-logmodule
#tag: <>
#tolerations:
#- effect: NoSchedule
# key: node-role.kubernetes.io/master
# operator: Exists
# key: node-role.kubernetes.io/control-plane
# operator: Exists
#otelCollector:
#replicas: 1
#imageRef:
#repository: public.ecr.aws/dynatrace/dynatrace-otel-collector
#tag: <tag>
  • The k8s-monitoring DynaKube handles Kubernetes platform monitoring, sized for a medium cluster (1,000–5,000 nodes). It includes an optional (commented-out) configuration for Kubernetes Security Posture Management.
  • The agents DynaKube handles OneAgent traffic routing, sized for a large cluster (5,000–20,000 nodes). It includes an optional (commented-out) configuration for OTLP log ingest, log monitoring, telemetry ingest, and the OTel Collector.
apiVersion: dynatrace.com/v1beta5
kind: DynaKube
metadata:
spec:
activeGate:
capabilities:
- kubernetes-monitoring
resources:
requests:
cpu: 1000m
memory: 10Gi
limits:
# cpu: 2000m
memory: 10Gi
#kspm:
#mappedHostPaths:
#- /etc
#- /usr/lib
#- /var/lib
#templates:
#imageRef:
#tag: 1.5.2
kind: DynaKube
metadata:
spec:
metadataEnrichment:
enabled: true
oneAgent:
activeGate:
capabilities:
- routing
- debugging
resources:
requests:
cpu: 1000m
memory: 6Gi
limits:
# cpu: 4000m
memory: 6Gi
replicas: 6
#logMonitoring: {}
#telemetryIngest:
#protocols:
#- jaeger
#- otlp
#- statsd
#- zipkin
templates:
#logMonitoring:
#imageRef:
#tag: <>
#otelCollector:
#replicas: 1
#imageRef:
#tag: <tag>
