Classic (formerly "built-in") AWS metrics
For information about differences between classic services and other services, see Migrate from AWS classic (formerly "built-in") services to cloud services.
The table below lists all AWS metrics that Dynatrace collects by default when you enable AWS monitoring.
For all other metrics collected by Dynatrace per configurable AWS service, see the cloud services pages.
Metric key
Name
Unit
Aggregations
builtin:cloud.aws.alb.connections.active
ALB number of active connections
Count
autoavgmaxmin
builtin:cloud.aws.alb.connections.new
ALB number of new connections
Count
autovalue
builtin:cloud.aws.alb.errors.alb.http4xx
ALB number of 4XX errors
Count
autovalue
builtin:cloud.aws.alb.errors.alb.http5xx
ALB number of 5XX errors
Count
autovalue
builtin:cloud.aws.alb.errors.target.http4xx
ALB number of 4XX target errors
Count
autovalue
builtin:cloud.aws.alb.errors.target.http5xx
ALB number of 5XX target errors
Count
autovalue
builtin:cloud.aws.alb.errors.rejCon
ALB number of rejected connections
Count
autovalue
builtin:cloud.aws.alb.errors.targConn
ALB number of target connection errors
Count
autovalue
builtin:cloud.aws.alb.errors.tlsNeg
ALB number of client TLS negotiation errors
Count
autovalue
builtin:cloud.aws.alb.bytes
ALB number of processed bytes
Count
autovalue
builtin:cloud.aws.alb.lcus
ALB number of consumed LCUs
Count
autovalue
builtin:cloud.aws.alb.requests
ALB number of requests
Count
autovalue
builtin:cloud.aws.alb.respTime
ALB target response time
Second
autoavgmaxmin
builtin:cloud.aws.asg.running
Number of running EC2 instances (ASG)
Count
autoavgmaxmin
builtin:cloud.aws.asg.stopped
Number of stopped EC2 instances (ASG)
Count
autoavgmaxmin
builtin:cloud.aws.asg.terminated
Number of terminated EC2 instances (ASG)
Count
autoavgmaxmin
builtin:cloud.aws.az.running
Number of running EC2 instances (AZ)
Count
autoavgmaxmin
builtin:cloud.aws.az.stopped
Number of stopped EC2 instances (AZ)
Count
autoavgmaxmin
builtin:cloud.aws.az.terminated
Number of terminated EC2 instances (AZ)
Count
autoavgmaxmin
builtin:cloud.aws.dynamo.capacityUnits.consumed.read
DynamoDB read capacity units
Count
autovalue
builtin:cloud.aws.dynamo.capacityUnits.consumed.write
DynamoDB write capacity units
Count
autovalue
builtin:cloud.aws.dynamo.capacityUnits.provisioned.read
DynamoDB provisioned read capacity units
Count
autovalue
builtin:cloud.aws.dynamo.capacityUnits.provisioned.write
DynamoDB provisioned write capacity units
Count
autovalue
builtin:cloud.aws.dynamo.capacityUnits.read
DynamoDB read capacity units %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.dynamo.capacityUnits.write
DynamoDB write capacity units %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.dynamo.errors.system
DynamoDB number of requests with HTTP 500 status code
Count
autovalue
builtin:cloud.aws.dynamo.errors.user
DynamoDB number of requests with HTTP 400 status code
Count
autovalue
builtin:cloud.aws.dynamo.requests.latency
DynamoDB number of successful request latency for operation
Millisecond
autoavgmaxmin
builtin:cloud.aws.dynamo.requests.returnedItems
DynamoDB number of items returned by operation
Count
autovalue
builtin:cloud.aws.dynamo.requests.throttled
DynamoDB number of throttled requests for operation
Count
autovalue
builtin:cloud.aws.dynamo.throttledEvents.read
DynamoDB number of read throttled events
Count
autovalue
builtin:cloud.aws.dynamo.throttledEvents.write
DynamoDB number of write throttled events
Count
autovalue
builtin:cloud.aws.dynamo.tables
Number of tables for AvailabilityZone
Count
autoavgmaxmin
builtin:cloud.aws.ebs.latency.read
EBS volume read latency
Second
autoavgmaxmin
builtin:cloud.aws.ebs.latency.write
EBS volume write latency
Second
autoavgmaxmin
builtin:cloud.aws.ebs.ops.consumed
EBS volume consumed OPS
Per second
autovalue
builtin:cloud.aws.ebs.ops.read
EBS volume read OPS
Per second
autoavgmaxmin
builtin:cloud.aws.ebs.ops.write
EBS volume write OPS
Per second
autoavgmaxmin
builtin:cloud.aws.ebs.throughput.percent
EBS volume throughput %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.ebs.throughput.read
EBS volume read throughput
Per second
autoavgmaxmin
builtin:cloud.aws.ebs.throughput.write
EBS volume write throughput
Per second
autoavgmaxmin
builtin:cloud.aws.ebs.idleTime
EBS volume idle time %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.ebs.queue
EBS volume queue length
Count
autoavgmaxmin
builtin:cloud.aws.ec2.cpu.usage
EC2 CPU usage %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.ec2.disk.readOps
EC2 instance storage read IOPS
Per second
autoavgmaxmin
builtin:cloud.aws.ec2.disk.readRate
EC2 instance storage read rate
kB/s
autoavgmaxmin
builtin:cloud.aws.ec2.disk.writeOps
EC2 instance storage write IOPS
Per second
autoavgmaxmin
builtin:cloud.aws.ec2.disk.writeRate
EC2 instance storage write rate
kB/s
autoavgmaxmin
builtin:cloud.aws.ec2.net.rx
EC2 network data received rate
Byte/second
autoavgmaxmin
builtin:cloud.aws.ec2.net.tx
EC2 network data transmitted rate
Byte/second
autoavgmaxmin
builtin:cloud.aws.elb.errors.backend.connection
CLB backend connection errors
Count
autovalue
builtin:cloud.aws.elb.errors.backend.http2xx
CLB number of backend 2XX errors
Count
autovalue
builtin:cloud.aws.elb.errors.backend.http3xx
CLB number of backend 3XX errors
Count
autovalue
builtin:cloud.aws.elb.errors.backend.http4xx
CLB number of backend 4XX errors
Count
autovalue
builtin:cloud.aws.elb.errors.backend.http5xx
CLB number of backend 5XX errors
Count
autovalue
builtin:cloud.aws.elb.errors.elb.http4xx
CLB number of 4XX errors
Count
autovalue
builtin:cloud.aws.elb.errors.elb.http5xx
CLB number of 5XX errors
Count
autovalue
builtin:cloud.aws.elb.errors.frontend
CLB frontend errors percentage
Percent (%)
autoavgmaxmin
builtin:cloud.aws.elb.hosts.healthy
CLB number of healthy hosts
Count
autoavgmaxmin
builtin:cloud.aws.elb.hosts.unhealthy
CLB number of unhealthy hosts
Count
autoavgmaxmin
builtin:cloud.aws.elb.latency
CLB latency
Second
autoavgmaxmin
builtin:cloud.aws.elb.reqCompl
CLB number of completed requests
Count
autovalue
builtin:cloud.aws.lambda.concExecutions
LambdaFunction concurrent executions count
Count
autoavgcountmaxminsum
builtin:cloud.aws.lambda.duration
LambdaFunction code execution time.
Millisecond
builtin:cloud.aws.lambda.errors
LambdaFunction number of failed invocations with HTTP 4XX status code
Count
autovalue
builtin:cloud.aws.lambda.errorsRate
LambdaFunction rate of failed invocations to all invocations %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.lambda.invocations
LambdaFunction number of times a function is invoked
Count
autovalue
builtin:cloud.aws.lambda.provConcExecutions
LambdaFunction provisioned concurrent executions count
Count
autovalue
builtin:cloud.aws.lambda.provConcInvocations
LambdaFunction provisioned concurrency invocation count
Count
autovalue
builtin:cloud.aws.lambda.provConcSpilloverInvocations
LambdaFunction provisioned concurrency spillover invocation count
Count
autovalue
builtin:cloud.aws.lambda.throttlers
LambdaFunction throttled function invocation count
Count
autovalue
builtin:cloud.aws.nlb.flow.active
NLB number of active flows
Count
autoavgmaxmin
builtin:cloud.aws.nlb.flow.new
NLB number of new flows
Count
autovalue
builtin:cloud.aws.nlb.tcp.reset.client
NLB number of client resets
Count
autovalue
builtin:cloud.aws.nlb.tcp.reset.elb
NLB number of resets
Count
autovalue
builtin:cloud.aws.nlb.tcp.reset.target
NLB number of target resets
Count
autovalue
builtin:cloud.aws.nlb.bytes
NLB number of processed bytes
Count
autovalue
builtin:cloud.aws.nlb.lcus
NLB number of consumed LCUs
Count
autovalue
builtin:cloud.aws.rds.cpu.usage
RDS CPU usage %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.rds.latency.read
RDS read latency
Second
autoavgmaxmin
builtin:cloud.aws.rds.latency.write
RDS write latency
Second
autoavgmaxmin
builtin:cloud.aws.rds.memory.freeable
RDS freeable memory
Byte
autoavgmaxmin
builtin:cloud.aws.rds.memory.swap
RDS swap usage
Byte
autoavgmaxmin
builtin:cloud.aws.rds.net.rx
RDS network received throughput
Byte/second
autoavgmaxmin
builtin:cloud.aws.rds.net.tx
RDS network transmitted throughput
Byte/second
autoavgmaxmin
builtin:cloud.aws.rds.ops.read
RDS read IOPS
Per second
autoavgmaxmin
builtin:cloud.aws.rds.ops.write
RDS write IOPS
Per second
autoavgmaxmin
builtin:cloud.aws.rds.throughput.read
RDS read throughput
Byte/second
autoavgmaxmin
builtin:cloud.aws.rds.throughput.write
RDS write throughput
Byte/second
autoavgmaxmin
builtin:cloud.aws.rds.connections
RDS connections
Count
autoavgmaxmin
builtin:cloud.aws.rds.free
RDS free storage space %
Percent (%)
autoavgmaxmin
builtin:cloud.aws.rds.restarts
RDS restarts
Count
autovalue
