From the AWS overview page, you can access Dynatrace classic services and cloud services for AWS monitoring. Both types of services share the same AWS resources. However, classic services use a predefined set of metrics, so configuring which metrics to monitor, or determining which ones are already monitored, is not supported.
Classic services vs cloud services As previously mentioned, classic services and cloud services share the same AWS resources. However, cloud services support a wider range of configuration options, such as new metrics and customizable monitored metrics. To give you more customization options, we’ve started the following:
Adding more services to the Cloud services section so you can customize which metrics you want to monitor.
Adding more metrics for cloud services; not only are they configurable, but you can now monitor much more than before.
Replacing the classic services with cloud services that have more configuration options regarding metrics.
If you're using classic services, we recommend migrating to cloud services to take advantage of the wider range of customizable configuration options.
AWS Lambda If you're using OneAgent integration for your Lambdas, we recommend Lambda migration. Since the release of Dynatrace version 1.283 , we show data for the new Lambda service together with OneAgent data on the Lambda service page .
Impact of the migration Even though classic and cloud services monitor the same AWS resources on Dynatrace side, they are monitored as two different entities.
They have different entity IDs and metric keys.
Due to their different implementations, they may detect different numbers of instances. Cloud services show only instances with metrics.
Data for each Dynatrace entity type is collected and stored separately.
Breaking change You need to adapt the configuration of dashboards, alerts, and management zones based on entity ID or metric keys with the monitored service type .
You currently have the option to choose from a classic or cloud service to preserve historical data, but be aware of the following:
Historical data is persisted on the classic services. If you switch back, monitored data will present gaps for the period in which the resources were monitored via the cloud service.
You can’t have both of them turned on simultaneously. Even though on the Dynatrace side they’re two different services, the legacy and new versions monitor the same AWS resource. If you had two versions switched on simultaneously, you would be charged double for polling the same data twice.
If you turn on the new version, the classic version is turned off automatically, and vice versa.
There is no direct link between
Entities containing historical and new data. Cloud service data and data coming from OneAgent for opaque Amazon RDS —not linked to the new cloud service page with CloudWatch metrics.
Logs from Amazon Data Firehose to Amazon RDS are still being linked to the historical data and entity RELATIONAL_DATABASE_SERVICE
Events or problems that would have been auto-detected on the historical (classic) data might not be automatically raised. Alerting rules are not provided for these cloud services:
Changes in the UI Your AWS overview page changes after configuring a new version of a service.
For example, let’s have a look at Amazon EBS .
If the legacy Amazon EBS (classic) service is configured, this is what the EBS volumes section of the AWS overview looks like.
If the Amazon EBS cloud service is configured, this is what the EBS volumes section of the AWS overview looks like.
Select Cloud services to find new overview pages for the services.
Additionally, you can configure metrics for cloud services via the web UI.
Cloud services and their corresponding classic services Metrics migration Below you can find tables with classic services metrics and their corresponding cloud services metrics. Empty cells indicate the lack of an identical corresponding metric.
Amazon Auto scaling group Number of running EC2 instances (ASG)
builtin:cloud.aws.asg.running
Number of stopped EC2 instances (ASG)
builtin:cloud.aws.asg.stopped
Number of terminated EC2 instances (ASG)
builtin:cloud.aws.asg.terminated
Amazon DynamoDB DynamoDB read capacity units
builtin:cloud.aws.dynamo.capacityUnits.consumed.read
ConsumedReadCapacityUnits Sum
ext:cloud.aws.dynamodb.consumedReadCapacityUnitsSum ext:cloud.aws.dynamodb.consumedReadCapacityUnitsByGlobalSecondaryIndexName
DynamoDB write capacity units
builtin:cloud.aws.dynamo.capacityUnits.consumed.write
ConsumedWriteCapacityUnits Sum
ext:cloud.aws.dynamodb.consumedWriteCapacityUnitsSum ext:cloud.aws.dynamodb.consumedWriteCapacityUnitsSumByGlobalSecondaryIndexName
DynamoDB provisioned read capacity units
builtin:cloud.aws.dynamo.capacityUnits.provisioned.read
ProvisionedReadCapacityUnits Sum
ext:cloud.aws.dynamodb.provisionedReadCapacityUnitsSum ext:cloud.aws.dynamodb.provisionedReadCapacityUnitsSumByGlobalSecondaryIndexName
DynamoDB provisioned write capacity units
builtin:cloud.aws.dynamo.capacityUnits.provisioned.write
ProvisionedWriteCapacityUnits Sum
ext:cloud.aws.dynamodb.provisionedWriteCapacityUnitsSum ext:cloud.aws.dynamodb.provisionedWriteCapacityUnitsSumByGlobalSecondaryIndexName
DynamoDB read capacity units %
builtin:cloud.aws.dynamo.capacityUnits.read
100 * ext:cloud.aws.dynamodb.consumedReadCapacityUnitsSum / ext:cloud.aws.dynamodb.provisionedReadCapacityUnitsSum
DynamoDB write capacity units %
builtin:cloud.aws.dynamo.capacityUnits.write
100 * ext:cloud.aws.dynamodb.consumedWriteCapacityUnitsSum / ext:cloud.aws.dynamodb.provisionedWriteCapacityUnitsSum
DynamoDB number of requests with HTTP 500 status code
builtin:cloud.aws.dynamo.errors.system
SystemErrors Sum (by Operation)
ext:cloud.aws.dynamodb.SystemErrorsSumByOperation
DynamoDB number of requests with HTTP 400 status code
builtin:cloud.aws.dynamo.errors.user
UserErrors Sum (by Region)
ext:cloud.aws.dynamodb.UserErrorsSum
DynamoDB number of successful request latency for operation
builtin:cloud.aws.dynamo.requests.latency
SuccessfulRequestLatency (by Operation)
ext:cloud.aws.dynamodb.successfulRequestLatencyByOperation
DynamoDB number of items returned by operation
builtin:cloud.aws.dynamo.requests.returnedItems
ReturnedItemCount Sum (by Operation)
ext:cloud.aws.dynamodb.returnedItemCountSumByOperation
DynamoDB number of throttled requests for operation
builtin:cloud.aws.dynamo.requests.throttled
ThrottledRequests Sum (by Operation)
ext:cloud.aws.dynamodb.ThrottledRequestsSumByOperation
DynamoDB number of read throttled events
builtin:cloud.aws.dynamo.throttledEvents.read
ext:cloud.aws.dynamodb.ReadThrottleEventsSum ext:cloud.aws.dynamodb.ReadThrottleEventsSumByGlobalSecondaryIndexName
DynamoDB number of write throttled events
builtin:cloud.aws.dynamo.throttledEvents.write
ext:cloud.aws.dynamodb.WriteThrottleEventsSum ext:cloud.aws.dynamodb.WriteThrottleEventsSumByGlobalSecondaryIndexName
Number of tables for AvailabilityZone
builtin:cloud.aws.dynamo.tables
Amazon EBS builtin:cloud.aws.ebs.latency.read
builtin:cloud.aws.ebs.latency.write
builtin:cloud.aws.ebs.ops.consumed
VolumeConsumedReadWriteOps Sum
ext:cloud.aws.ebs.volumeConsumedReadWriteOps
builtin:cloud.aws.ebs.ops.read
ext:cloud.aws.ebs.volumeReadOpsSum
builtin:cloud.aws.ebs.ops.write
ext:cloud.aws.ebs.volumeWriteOpsSum
builtin:cloud.aws.ebs.throughput.percent
VolumeThroughputPercentage
ext:cloud.aws.ebs.volumeThroughputPercentage
EBS volume read throughput
builtin:cloud.aws.ebs.throughput.read
ext:cloud.aws.ebs.volumeReadBytes / ext:cloud.aws.ebs.volumeTotalReadTime
EBS volume write throughput
builtin:cloud.aws.ebs.throughput.write
ext:cloud.aws.ebs.volumeWriteBytes / ext:cloud.aws.ebs.volumeTotalWriteTime
builtin:cloud.aws.ebs.idleTime
builtin:cloud.aws.ebs.queue
ext:cloud.aws.ebs.volumeQueueLengthSum
AWS Lambda LambdaFunction concurrent executions count
builtin:cloud.aws.lambda.concExecutions
ext:cloud.aws.lambda.concurrentExecutionsSum ext:cloud.aws.lambda.concurrentExecutionsSumByResource ext:cloud.aws.lambda.concurrentExecutionsSumByRegion
LambdaFunction code execution time.
builtin:cloud.aws.lambda.duration
ext:cloud.aws.lambda.duration ext:cloud.aws.lambda.durationByResource ext:cloud.aws.lambda.durationByRegion
LambdaFunction number of failed invocations with HTTP 4XX status code
builtin:cloud.aws.lambda.errors
ext:cloud.aws.lambda.errorsSum ext:cloud.aws.lambda.errorsSumByResource ext:cloud.aws.lambda.errorsSumByRegion
LambdaFunction rate of failed invocations to all invocations %
builtin:cloud.aws.lambda.errorsRate
100 * ext:cloud.aws.lambda.errorsSum / ext:cloud.aws.lambda.invocationsSum
LambdaFunction number of times a function is invoked
builtin:cloud.aws.lambda.invocations
ext:cloud.aws.lambda.invocationsSum ext:cloud.aws.lambda.invocationsSumByResource ext:cloud.aws.lambda.invocationsSumByRegion
LambdaFunction provisioned concurrent executions count
builtin:cloud.aws.lambda.provConcExecutions
ProvisionedConcurrentExecutions Sum
ext:cloud.aws.lambda.provisionedConcurrentExecutionsSum ext:cloud.aws.lambda.provisionedConcurrentExecutionsSumByResource ext:cloud.aws.lambda.provisionedConcurrentExecutionsSumByRegion
LambdaFunction provisioned concurrency invocation count
builtin:cloud.aws.lambda.provConcInvocations
ProvisionedConcurrencyInvocations Sum
ext:cloud.aws.lambda.provisionedConcurrencyInvocationsSum ext:cloud.aws.lambda.provisionedConcurrencyInvocationsSumByResource ext:cloud.aws.lambda.provisionedConcurrencyInvocationsSumByRegion
LambdaFunction provisioned concurrency spillover invocation count
builtin:cloud.aws.lambda.provConcSpilloverInvocations
ProvisionedConcurrencySpilloverInvocations Sum
ext:cloud.aws.lambda.provisionedConcurrencySpilloverInvocationsSum ext:cloud.aws.lambda.provisionedConcurrencySpilloverInvocationsSumByResource ext:cloud.aws.lambda.provisionedConcurrencySpilloverInvocationsSumByRegion
LambdaFunction throttled function invocation count
builtin:cloud.aws.lambda.throttlers
ext:cloud.aws.lambda.throttlesSum ext:cloud.aws.lambda.throttlesSumByResource ext:cloud.aws.lambda.throttlesSumByRegion
Amazon RDS builtin:cloud.aws.rds.cpu.usage
ext:cloud.aws.rds.cpuUtilization ext:cloud.aws.rds.cpuUtilizationByRegionDatabaseClass ext:cloud.aws.rds.cpuUtilizationByRegionDBClusterIdentifier ext:cloud.aws.rds.cpuUtilizationByRegion ext:cloud.aws.rds.cpuUtilizationByRegionEngineName ext:cloud.aws.rds.cpuUtilizationByRegionDBClusterIdentifierRole
builtin:cloud.aws.rds.latency.read
ext:cloud.aws.rds.readLatency ext:cloud.aws.rds.readLatencyByRegionDatabaseClass ext:cloud.aws.rds.readLatencyByRegionDBClusterIdentifier ext:cloud.aws.rds.readLatencyByRegion ext:cloud.aws.rds.readLatencyByRegionEngineName ext:cloud.aws.rds.readLatencyByRegionDBClusterIdentifierRole
builtin:cloud.aws.rds.latency.write
ext:cloud.aws.rds.writeLatency ext:cloud.aws.rds.writeLatencyByRegionDatabaseClass ext:cloud.aws.rds.writeLatencyByRegionDBClusterIdentifier ext:cloud.aws.rds.writeLatencyByRegion ext:cloud.aws.rds.writeLatencyByRegionEngineName ext:cloud.aws.rds.writeLatencyByRegionDBClusterIdentifierRole
builtin:cloud.aws.rds.memory.freeable
ext:cloud.aws.rds.freeableMemory ext:cloud.aws.rds.freeableMemoryByRegionDatabaseClass ext:cloud.aws.rds.freeableMemoryByRegionDBClusterIdentifier ext:cloud.aws.rds.freeableMemoryByRegion ext:cloud.aws.rds.freeableMemoryByRegionEngineName ext:cloud.aws.rds.freeableMemoryByRegionDBClusterIdentifierRole
builtin:cloud.aws.rds.memory.swap
ext:cloud.aws.rds.swapUsage ext:cloud.aws.rds.swapUsageByRegionDatabaseClass ext:cloud.aws.rds.swapUsageByRegionDBClusterIdentifier ext:cloud.aws.rds.swapUsageByRegion ext:cloud.aws.rds.swapUsageByRegionEngineName ext:cloud.aws.rds.swapUsageByRegionDBClusterIdentifierRole
RDS network received throughput
builtin:cloud.aws.rds.net.rx
ext:cloud.aws.rds.networkReceiveThroughput ext:cloud.aws.rds.networkReceiveThroughputByRegionDatabaseClass ext:cloud.aws.rds.networkReceiveThroughputByRegionDBClusterIdentifier ext:cloud.aws.rds.networkReceiveThroughputByRegion ext:cloud.aws.rds.networkReceiveThroughputByRegionEngineName ext:cloud.aws.rds.networkReceiveThroughputByRegionDBClusterIdentifierRole
RDS network transmitted throughput
builtin:cloud.aws.rds.net.tx
NetworkTransmitThroughput
ext:cloud.aws.rds.networkTransmitThroughput ext:cloud.aws.rds.networkTransmitThroughputByRegionDatabaseClass ext:cloud.aws.rds.networkTransmitThroughputByRegionDBClusterIdentifier ext:cloud.aws.rds.networkTransmitThroughputByRegion ext:cloud.aws.rds.networkTransmitThroughputByRegionEngineName ext:cloud.aws.rds.networkTransmitThroughputByRegionDBClusterIdentifierRole
builtin:cloud.aws.rds.ops.read
ext:cloud.aws.rds.readIOPS ext:cloud.aws.rds.readIOPSByRegionDatabaseClass ext:cloud.aws.rds.readIOPSByRegion ext:cloud.aws.rds.readIOPSByRegionEngineName
builtin:cloud.aws.rds.ops.write
ext:cloud.aws.rds.writeIOPS ext:cloud.aws.rds.writeIOPSByRegionDatabaseClass ext:cloud.aws.rds.writeIOPSByRegion ext:cloud.aws.rds.writeIOPSByRegionEngineName
builtin:cloud.aws.rds.throughput.read
ext:cloud.aws.rds.readThroughput ext:cloud.aws.rds.readThroughputByRegionDatabaseClass ext:cloud.aws.rds.readThroughputByRegion ext:cloud.aws.rds.readThroughputByRegionEngineName
builtin:cloud.aws.rds.throughput.write
ext:cloud.aws.rds.writeThroughput ext:cloud.aws.rds.writeThroughputByRegionDatabaseClass ext:cloud.aws.rds.writeThroughputByRegion ext:cloud.aws.rds.writeThroughputByRegionEngineName
builtin:cloud.aws.rds.connections
ext:cloud.aws.rds.databaseConnectionsSumByRegionDatabaseClass ext:cloud.aws.rds.databaseConnectionsSumByRegionDBClusterIdentifier ext:cloud.aws.rds.databaseConnectionsSumByRegion ext:cloud.aws.rds.databaseConnectionsSumByRegionEngineName ext:cloud.aws.rds.databaseConnectionsSumByRegionDBClusterIdentifierRole
builtin:cloud.aws.rds.free
builtin:cloud.aws.rds.restarts
