Synthetic Monitoring username-password and token credentials in the Dynatrace credential vault can be synchronized with an external vault—Azure Key Vault, HashiCorp Vault, or CyberArk Vault (username-password credentials only). Synchronized credentials contain the keys of external key-value pairs that hold the required values.
When you set up synchronized credentials in the credential vault, Dynatrace automatically creates HTTP monitors specifically for the purpose of synchronization. You can also use the api.saveCredential() or api.saveToken() methods in pre-and post-execution scripts to create your own synchronization monitors.
Autocreated synchronization monitors are named with the credential ID of the synchronized credential and are executed hourly by default from the Amazon US East (N. Virginia) public Synthetic location. Note that the request and response bodies and headers of synchronization monitors are automatically hidden from execution details (Analyze execution details).
Other synthetic monitors can call and use these synchronized credentials for testing API endpoints and websites. The monitors that call these credentials use the synchronized values obtained from the external vaults. Synchronization frequency determines how often these credentials are rotated within the synthetic monitors that call them.
Synchronization process reads the credentials from external vault and saves a copy within the Dynatrace vault.
Username-password or token credentials for use in synthetic monitors can be synchronized with Azure Key Vault key-value pairs containing the username, password, or token value.
Before setting up credentials synchronized with Azure Key Vault, you need to define the required client (application) ID and client secret as token credentials stored in the Dynatrace credential vault. We recommend naming such prerequisite tokens so that they're easily identifiable as companion credentials for synchronization. If your vault doesn't contain any tokens that you have access to, you'll see a warning.
In the credential vault, create a User and password or Token credential. You can also overwrite an existing credential.
For Credential scope, select Synthetic.
Turn on Synchronization with external vault.
Select Azure Key Vault (default) as the Credential source.
We recommend editing the default Credential name to easily identify your new credential.
Enter the URL to access the vault (Vault URL) and the Tenant (directory) ID.
Select the companion tokens created earlier for the Client (application) ID and Client secret.
Enter the name of the Azure Key Vault key.
Select a Location for synchronization—you can select any public or private Synthetic location for synchronization monitor execution. You can search for a location by entering the location name in the field.
Optional Provide a Description for the credential.
Credentials are set to Owner access only by default. (Read more about credential ownership.)
Save your credential.
See also Best practices and what happens when you edit or delete synchronized and companion credentials.
When you have set up your synchronized username-password or token credential, Dynatrace automatically creates and executes an HTTP monitor that synchronizes the credential with Azure Key Vault. This monitor is automatically associated with the synchronized username-password or token credential.
See also Best practices and what happens when you edit or delete synchronization credentials.
The synchronization monitor contains three requests. Azure Key Vault requires splitting the retrieval of the username and password into two separate requests.
The request URL references the tenant ID as an attribute of the synchronized credential defined above; the tenant ID is not displayed.
The client ID and client secret, referenced as attributes of the synchronized credential, are passed as key-value pairs in the request body; the client ID and client secret are not displayed.
A client token is returned in the response body. A post-execution script saves the token in a global variable.
The request URL references the vault URL as an attribute of the synchronized credential defined above; the vault URL is not displayed. The request URL also references the key mapped to the username value in Azure Key Vault.
The Authorization header contains the access token retrieved in the first request.
The username value is returned in the response body. A post-execution script saves the value in a global variable.
api.saveCredential() in a post-execution script to write the fetched values to the synchronized username-password credential defined above.
The request URL references the vault URL as an attribute of the synchronized credential; the vault URL is not displayed. The request URL also references the key mapped to the password value in Azure Key Vault.
The password value is returned in the response body. A post-execution script saves the value in a global variable. It also uses api.saveCredential() to write the retrieved values to the synchronized username-password credential.
Username-password or token credentials for use in synthetic monitors can be synchronized with HashiCorp Vault key-value pairs containing the username, password, or token value. You can use either AppRole-based or certificate authentication.
Before using AppRole-based authentication, you need to define the required secret ID as a token credential stored in the Dynatrace credential vault; do not reuse other tokens as the secret ID. If your vault doesn't contain any tokens you have access to, you'll see a warning.
Before using certificate authentication, you need to store the required TLS certificate in the Dynatrace credential vault. If your vault doesn't contain any certificates you have access to, you'll see a warning.
We recommend naming such prerequisite tokens and certificates so that they're easily identifiable as companion credentials for synchronization.
Select HashiCorp Vault as the Credential source.
Enter the URL to access the vault (Vault URL) and the Path to credentials (folders must be separated by a forward slash).
The HashiCorp Vault URL for certificate authentication might be different from that used for AppRole-based authentication.
Enter the name of the HashiCorp Vault key.
Perform steps related to Authentication method.
Optional Provide a Description.
When you have set up your synchronized credential, Dynatrace automatically creates and executes an HTTP monitor that synchronizes the credential with HashiCorp Vault.
The autocreated HTTP monitor contains two requests and is automatically associated with the synchronized credential defined above.
The request URL references the vault URL as an attribute of the synchronized credential; the vault URL is not displayed. The request URL also contains the authentication method approle.
The vault namespace, referenced as an attribute of the synchronized credential, is passed as a request header; the vault namespace is not displayed.
The role ID and secret ID, referenced as attributes of the synchronized credential, are passed as key-value pairs in the request body; the role ID and secret ID are not displayed.
api.saveCredential() in s post-execution script to write the fetched values to the synchronized username-password credential defined above.
The request URL references the vault URL and the path to credentials as attributes of the synchronized credential; the vault URL and path to credentials are not displayed.
A request header contains the client token retrieved in the first request. The vault namespace (not displayed, but referenced as an attribute of the synchronized credential) is also passed as a request header.
The username and password values are returned in the JSON response. A post-execution script saves the values in global variables. It also uses api.saveCredential() to write the retrieved values to the synchronized username-password credential.
The request URL references the vault URL as an attribute of the synchronized credential; the vault URL is not displayed. The request URL also contains the authentication method cert.
The request uses the TLS certificate for authentication.
Username-password credentials for use in synthetic monitors can be synchronized with CyberArk Vault key-value pairs containing the username or password. You can use either username and password or host-based authentication to CyberArk Vault. Host-based authentication allows you to predefine hosts (Allowed Machines) in CyberArk Vault that are allowed to access credentials. These hosts are the public or private Synthetic locations you select for synchronization monitor execution and are defined by hostname or IP address. Host-based authentication enables synchronization monitors to bypass fetching an access token from CyberArk Vault.
Before using username and password authentication, you need to define authentication credentials for CyberArk Vault—a username-password pair and, optionally, a certificate credential stored in the Dynatrace credential vault. We recommend naming such prerequisite credentials so that they're easily identifiable as companion credentials for synchronization.
Before using host-based authentication, you need to define Allowed Machines by hostname or IP address in CyberArk Vault Application Details. These are the hosts that are allowed to access the synchronized credentials in CyberArk Vault and are the public or private Synthetic locations you select for synchronization monitor execution. Note that when defining allowed machines in CyberArk Vault, the application ID must be the same as provided when you set up a synchronized credential in Dynatrace. Optionally, you can also define a certificate credential stored in the Dynatrace credential vault for authentication to CyberArk Vault. If your vault doesn't contain any certificates you have access to, you'll see a warning.
We recommend naming any prerequisite credentials so that they're easily identifiable as companion credentials for synchronization.
In the credential vault, create a User and password credential. You can also overwrite an existing credential.
Select CyberArk Vault as the Credential source.
Enter the Central Credential Provider URL (HTTPS) to access the vault.
Recommended Select a Certificate used for authentication to CyberArk application from the list provided.
Enter additional fields for identifying the CyberArk Vault key-value pair.
Root.Select a Location for synchronization—you can select any public or private Synthetic location for synchronization monitor execution. You can search for a location by entering the location name in the field.
When you have set up your synchronized credential, Dynatrace automatically creates and executes an HTTP monitor that synchronizes the credential with CyberArk Vault.
The request URL references the Central Credential Provider URL as an attribute of the synchronized credential defined above; the central credential provider URL is not displayed.
The request body references the username-password credential selected for CyberArk Vault authentication (Username and password for Central Credential Provider); the authentication username and password are not displayed.
Additionally, the first request contains any authentication certificate specified in Certificate used for authentication to CyberArk.
A token is returned in the response body. A post-execution script saves the token in a global variable.
The request URL references the Central Credential Provider URL as an attribute of the synchronized credential; the central credential provider URL is not displayed. The request URL also references (but doesn't display) the Application ID, Safe name, Account name, and Folder name.
The second request also contains any authentication certificate and the access token retrieved in the first request in the Authorization header.
The username and password values are returned in the response body. A post-execution script saves the values in global variables. It also uses api.saveCredential() to write the retrieved values to the synchronized username-password credential.
Because the autocreated HTTP monitor can bypass fetching an access token, it contains a single GET request to fetch the username and password values from CyberArk Vault. It also uses api.saveCredential() in a post-execution script to write the fetched values to the synchronized username-password credential defined above. The synchronization monitor is automatically associated with the synchronized credential.
If creating a synchronization monitor manually, be sure to select Do not store and display request and response bodies and header values in execution details in any requests that fetch client tokens or credential values from external vaults. Failing to do so will expose the sensitive information when you Analyze execution details in HTTP monitor details.
