Ensure that the host you want to use for your private location complies with the following requirements.
There are no new versions of Chromium for Red Hat/Oracle Linux/Rocky Linux 8 beyond version 133. For important security and stability reasons, we've decided to discontinue our support for installing Synthetic-enabled ActiveGate on Red Hat/Oracle Linux/Rocky Linux 8 after ActiveGate version 1.325.
To ensure the continuity and security of your synthetic monitors, we recommend migrating your Synthetic-enabled ActiveGate to one of the supported operating systems, for example, Red Hat/Oracle Linux/Rocky Linux 9.
ActiveGate version 1.325 is the last Synthetic-enabled ActiveGate supported on Red Hat/Oracle Linux/Rocky Linux 8.
Additionally, with Dynatrace version 1.326, we plan to introduce mechanisms preventing Synthetic-enabled ActiveGates on Red Hat/Oracle Linux/Rocky Linux 8 from being updated beyond version 1.325.
Antivirus and anti-malware software can negatively impact Dynatrace Synthetic monitoring capabilities. Such software might block the browser or Dynatrace processes that execute synthetic monitors, cause Synthetic-enabled ActiveGate installation or update failures, interfere with network communication, and impact the reliability of measurements.
To maintain stability and performance, consider adding the directories and processes listed below to the allowlist or exclude them from the policy. Keep in mind that antivirus exclusions typically prevent file scanning but don’t disable behavioral monitoring or kernel-level hooks. These remain active and can affect how the Synthetic Engine and browser interact with system libraries. As a result, even excluded processes can experience access violations or heap corruption.
Before contacting Dynatrace Support to troubleshoot issues with your private synthetic locations, ensure that antivirus or anti-malware software has been ruled out as a potential cause.
This is the minimal list of processes and directories required for Dynatrace Synthetic to operate. It's not guaranteed that the service will function correctly with only these exclusions. Collaborate with your vendor to ensure that all expected Dynatrace behaviors are properly allowed.
Directories:
synthetic in their path. For an overview of directories in use, see ActiveGate directories.Processes:
A freshly installed ActiveGate can run your private synthetic monitors (both HTTP and browser monitors) on the following operating systems.
| Windows OS | Versions |
Windows Server | 2016, 2019, 2022, 2025 |
On Windows, the ActiveGate installer package includes the Chrome for Testing browser used to run browser monitors. The table below shows the Chrome for Testing versions that are bundled with the respective ActiveGate versions.
| ActiveGate version | Included browser version |
1.349 | 153 |
1.347 | 152 |
1.345 | 151 |
1.3431 | 150 |
1.341 | 148 |
1.339 | 147 |
1.337 | 146 |
1.335 | 146 |
1.333 | 144 |
1.331 | 143 |
1.329 | 142 |
1.327 | 141 |
1.325 | 140 |
All Windows Server versions migrated to use Chrome for Testing instead of Chromium.
If you only want to test private Synthetic locations on a non-production host, for example, your own desktop, you can install a Synthetic-enabled ActiveGate on unsupported Windows versions such as Windows 10 or Windows 11.
As of ActiveGate version 1.263+, Synthetic-enabled ActiveGates no longer work on Windows Server 2012 for testing purposes. Google has dropped support for Windows 2012 Server with Chromium 110, which is bundled with the ActiveGate version 1.263 installation package.
The Synthetic installer can be installed on all minor releases of Red Hat Enterprise Linux 9 and 10. Versions listed in this table were verified for compatibility. We recommend using them or the versions that have Extended Life-cycle Support (ELS) according to Red Hat Enterprise Linux Life Cycle.
The Synthetic installer can be installed on all minor releases of Oracle Linux 9. Versions listed in this table were verified for compatibility. We recommend using them or the latest currently supported versions according to documentation for Oracle Linux 9.
The Synthetic installer can be installed on all minor releases of Rocky Linux 9 and 10. Versions listed in this table were verified for compatibility. We recommend using them or the latest currently supported versions according to Rocky Linux Release and Version Guide.
ActiveGate version 1.305 is the last Synthetic-enabled ActiveGate to support Red Hat/CentOS 7.
ActiveGate version 1.307 is the last Synthetic-enabled ActiveGate to support Amazon Linux 2.
ActiveGate version 1.325 is the last Synthetic-enabled ActiveGate to support Red Hat/Oracle Linux/Rocky Linux 8.
We strongly recommend that you keep your Linux-based Synthetic-enabled ActiveGates and browser versions updated—Dynatrace supports browser versions that are no more than two versions behind the latest Dynatrace-supported version for a specific ActiveGate release. For example, if the latest supported browser version is 103, Dynatrace supports up to browser version 101. If the provided browser version is significantly older for a specific OS, we support only the provided version. See information on updating browser automatically and manually.
On Linux, the ActiveGate installer downloads the browser dependencies that are required by the Synthetic engine. On Red Hat and Rocky, you need to enable particular repositories from which the installer downloads the dependencies. The Dynatrace web UI provides you with all the required commands. For detailed instructions, see Create a private synthetic location.
When installing ActiveGate and the browser from a custom, local repository, you need to resolve all dependencies and enable repositories as required; the custom repository can be used only for browser packages, not their dependencies. Place the browser package archive and the signature file in the custom repository for installation. If your package archive file is https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip (Chrome for Testing 143 for Ubuntu on ActiveGate version 1.333), you can find the signature file by appending .sig to the URL: https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip.sig.
Due to changes in libdav1d.so.6 packet availability Chromium versions older than 130 cannot be installed on Red Hat/Rocky Linux 9.
Please refer to troubleshooting guide for details.
| ActiveGate version | Latest supported Chromium version Red Hat/Oracle/Rocky Linux | Latest supported Chromium version Ubuntu 20 and 22 | Latest supported Chrome for Testing version Amazon Linux 2023, Ubuntu 24, Oracle Linux 9 |
1.329 | |||
1.327 | |||
1.325 | 133 Red Hat/Oracle/Rocky Linux 8, 140 Red Hat/Rocky Linux 9 | 140 |
Red Hat/Rocky Linux 10 support introduced.
Ubuntu Server 20.04 and 22.04 migrated to use Chrome for Testing.
fapolicyd)If not configured correctly, the File Access Policy Daemon (fapolicyd) can potentially affect Dynatrace Synthetic monitoring capabilities. Similarly to antivirus or anti-malware software, fapolicyd might block the browser or Dynatrace processes responsible for executing synthetic monitors.
To ensure proper stability and performance, consider adding directories and processes to the allowed list or excluding them from the policy. For more detailed information, refer to the Red Hat documentation on fapolicyd. Prior to contacting Dynatrace support to troubleshoot issues with your private synthetic locations, make sure that fapolicyd was excluded as a source of problems.
By default, fapolicyd trusts only files installed from RPM packages. Add rules for files that don't come from an RPM package to a new file in /etc/fapolicyd/rules.d/, for example, 35-custom.rules. Because fapolicyd reads these files in name order and applies the first matching rule, start the file name with a number lower than 40, before the default files that deny untrusted files.
Here is an example of a unified minimal ruleset.
# ActiveGateallow perm=execute exe=/usr/bin/bash : path=/opt/dynatrace/gateway/launcher/dynatracegateway ftype=application/x-executable trust=0allow perm=execute exe=/opt/dynatrace/gateway/launcher/dynatracegateway : path=/opt/dynatrace/gateway/jre/bin/java ftype=application/x-executable trust=0allow perm=open exe=/opt/dynatrace/gateway/jre/bin/java : dir=/opt/dynatrace/gateway/jre/lib/ ftype=application/x-sharedlib trust=0allow perm=open exe=/opt/dynatrace/gateway/jre/bin/java : dir=/opt/dynatrace/gateway/lib/ ftype=application/java-archive trust=0allow perm=open exe=/opt/dynatrace/gateway/jre/bin/java : path=/opt/dynatrace/gateway/lib/native/libzstd-jni.so ftype=application/x-sharedlib trust=0allow perm=open exe=/opt/dynatrace/gateway/jre/bin/java : path=/opt/dynatrace/gateway/lib/native/libsnappyjava.so ftype=application/x-sharedlib trust=0# Synthetic engineallow perm=execute exe=/usr/bin/bash : path=/opt/dynatrace/synthetic/jre/bin/java ftype=application/x-executable trust=0allow perm=execute exe=/usr/bin/bash : path=/opt/dynatrace/synthetic/vucontroller/vucwrapper ftype=application/x-executable trust=0allow perm=execute exe=/opt/dynatrace/synthetic/vucontroller/vucwrapper : path=/opt/dynatrace/synthetic/jre/bin/java ftype=application/x-executable trust=0allow perm=open exe=/opt/dynatrace/synthetic/jre/bin/java : dir=/opt/dynatrace/synthetic/jre/lib/ ftype=application/x-sharedlib trust=0allow perm=open exe=/opt/dynatrace/synthetic/jre/bin/java : dir=/opt/dynatrace/synthetic/vucontroller/lib/ ftype=application/java-archive trust=0# Synthetic engine: helper processes and the HTTP monitor executorallow perm=execute exe=/opt/dynatrace/synthetic/jre/bin/java : path=/opt/dynatrace/synthetic/jre/lib/jspawnhelper ftype=application/x-executable trust=0allow perm=execute exe=/opt/dynatrace/synthetic/jre/lib/jspawnhelper : path=/opt/dynatrace/synthetic/jre/bin/java ftype=application/x-executable trust=0allow perm=open exe=/opt/dynatrace/synthetic/jre/bin/java : dir=/opt/dynatrace/synthetic/vucontroller/libhttpexecutor/ ftype=application/java-archive trust=0# Synthetic engine: native library that Java extracts to the temp directoryallow perm=open exe=/opt/dynatrace/synthetic/jre/bin/java : dir=/var/tmp/dynatrace/synthetic/ ftype=application/x-sharedlib trust=0# Chrome for Testingallow perm=execute exe=/usr/bin/bash : path=/usr/lib/chrome_for_testing/chrome-linux64/chrome ftype=application/x-executable trust=0allow perm=execute exe=/opt/dynatrace/synthetic/jre/lib/jspawnhelper : path=/usr/lib/chrome_for_testing/chrome-linux64/chrome ftype=application/x-executable trust=0allow perm=execute exe=/usr/lib/chrome_for_testing/chrome-linux64/chrome : path=/usr/lib/chrome_for_testing/chrome-linux64/chrome ftype=application/x-executable trust=0allow perm=execute exe=/usr/lib/chrome_for_testing/chrome-linux64/chrome : path=/usr/lib/chrome_for_testing/chrome-linux64/chrome_crashpad_handler ftype=application/x-executable trust=0allow perm=execute exe=/usr/lib/chrome_for_testing/chrome-linux64/chrome_crashpad_handler : path=/usr/lib/chrome_for_testing/chrome-linux64/chrome_crashpad_handler ftype=application/x-executable trust=0allow perm=open exe=/usr/lib/chrome_for_testing/chrome-linux64/chrome : dir=/usr/lib/chrome_for_testing/chrome-linux64/ ftype=application/x-sharedlib trust=0# Only if OneAgent is installed on the same hostallow perm=open all : path=/usr/lib64/liboneagentproc.so ftype=application/x-sharedlib trust=0
To apply the rules, run:
sudo fagenrules --loadsudo systemctl restart fapolicydsudo systemctl restart dynatracegatewaysudo systemctl restart vuc
Because fapolicyd checks a program only when the program starts, restart the ActiveGate (dynatracegateway) and the Synthetic engine (vuc) after changing the rules. A missing rule can show up only after the next reboot, so reboot once after you add the rules. Restarting vuc can occasionally take several minutes. If vuc is in the failed state after repeated restarts, run sudo systemctl reset-failed vuc before you restart it.
If the ActiveGate or the Synthetic engine doesn't start, or a monitor doesn't run after you add the rules, see Troubleshooting fapolicyd on private Synthetic locations.
Based on the number of tests executed per hour, Synthetic-enabled ActiveGates need to meet the following hardware requirements.
The estimated limits listed in the table below were determined in our internal tests. The actual values might vary depending on the complexity of your monitors.
While XS nodes can be used on Windows Server-based ActiveGates, they may not be the best fit due to the higher hardware demands of the browser. For optimal performance and to prepare for future enhancements, we recommend having at least 8 GB of RAM and 25 GB of free disk space.
On Linux systems with only 4 GB of RAM, the increasing resource requirements of the browser, combined with the installation of third-party tools on the host, may lead to occasional memory shortages. Upgrading to 8 GB of RAM is strongly recommended to help ensure a smoother and more reliable experience.
| Node with browser monitor support | Browserless node | |
Minimum CPUs | 2 vCPU | 1 vCPU |
Minimum free disk space | 20 GB | 17 GB |
Minimum RAM | 4 GB | 4 GB |
Minimum free RAM | 3 GB | 2,7 GB |
Minimum disk IOPS (Windows) | 100 | 100 |
Estimated maximum number of HTTP monitor executions/h1 | 300k | 300k |
Estimated maximum number of high-resource HTTP monitor2 executions/h | 10k | 10k |
Estimated maximum number of browser monitor executions/h | 300 | - |
500k | 500k | |
1M | 1M | |
100k | 100k |
Calculated as 5000 monitor executions (maximum for a single environment) run once every minute (maximum frequency).
These are HTTP monitors on private locations with any of: pre- or post-execution scripts, OAuth2 authorization, Kerberos authentication.
For NAM monitors using ICMP request type, capacity is related to number of ICMP echo requests (packets) that are being sent during monitors execution. As this number of packets-to-be-sent may significantly vary among defined monitors, using the number of monitor executions as a capacity limit would be inaccurate.
For NAM monitors using TCP and DNS request types, capacity is related to the number of network connections (requests) that are being sent during monitors execution. As this number of requests may significantly vary among defined monitors, using the number of monitor executions as a capacity limit would be inaccurate.
During load tests that helped to establish capacity limits, NAM ICMP monitors were exclusively scheduled on location; monitors had the following characteristic. Actual capacity may be different for other environments (for example, those where monitored targets respond slower or are failing to provide a response within timeout limit or other type of monitors are executed at the same time). Monitors were using default settings (including default timeouts settings and single packet per-request) and were scheduled every 1 minute. There were multiple target hosts used during tests; all of them were responding properly with average RTT around 200ms.
During load tests that helped to establish capacity limits, NAM TCP monitors were exclusively scheduled on location; monitors had the following characteristic. Actual capacity may be different for other environments (for example, those where monitored targets respond slower or are failing to provide a response within timeout limit or other type of monitors are executed at the same time). Monitors were using default settings (including default timeouts settings) and were scheduled every 1 minute. There were multiple target hosts and ports used during tests; all of them were responding properly with average TCP connection time around 200ms.
During load tests that helped to establish capacity limits, NAM DNS monitors were exclusively scheduled on location; monitors had the following characteristic. Actual capacity may be different for other environments (for example, those where monitored targets respond slower or are failing to provide a response within timeout limit or other type of monitors are executed at the same time). Please note that DNS server used during resolution should be able to handle incoming requests and may not consider the incoming traffic as a subject to throttling or rejection (for example, due to detection as bot-originated). Monitors were using default settings (including default timeouts settings and UDP as a transport) and were scheduled every 1 minute. There were multiple resolution targets used during tests; all of them were resolved properly with average DNS resolution time around 10ms. Publicly available DNS servers were used: Google (8.8.8.8 and 8.8.4.4) and Cloudflare (1.1.1.1 and 1.1.1.2)
The table below shows the default installation locations (Linux and Windows) of various ActiveGate directories and the minimum size requirements. This information is compiled from details in ActiveGate directories.
| Installation parameter | Default path | Min. size | Notes |
| 600 MB | For executable files, libraries, and related files
| 1.7 GB |
| 1 MB | |
| 21 GB1 |
For an XS ActiveGate—more space is required for execution logs on larger ActiveGates.
/tmpSynthetic-enabled ActiveGate requires write access to the /tmp directory during runtime. Its dependencies, including xvfb, utilize /tmp for storing temporary files and runtime data.
Lack of write permissions to this directory may result in unexpected failures or degraded functionality.
Ensure that the host environment provides sufficient access rights and available space in /tmp to support these operations reliably.
Synthetic Classic
