Hosted self-monitoring environment
This page will soon be available only on the dedicated Dynatrace Managed Documentation site. Update your bookmarks.
Each Dynatrace Managed cluster node is observed by Mission Control. Self-monitoring takes a significant role in Dynatrace pro-active support capabilities. You have control over where the self-monitoring data is stored and who has access it. All clusters have a Local self-monitoring environment with internal metrics. Additionally, a cluster node can be monitored by OneAgent reporting to Dynatrace or your own environment. This topic describes in detail the available self-monitoring options, configuration, and data exchange.
Pro-active support with turnkey self-monitoring
Dynatrace Managed deployment includes Dynatrace OneAgent at each cluster node, which provides self-monitoring of cluster health. Monitoring is enabled in Full-Stack Monitoring mode.
With this capability, Dynatrace product experts can support you proactively so you can focus on monitoring your applications. Data is reported to Mission Control Support Services and stored in a self-monitoring cluster hosted by Dynatrace. Data is stored in a US region. Only Dynatrace privileged employees have access to the data.
Premium self-monitoring environment with full access
To get detailed insights, control who has access to self-monitoring data, and set up additional alerting and dashboards, you can get premium self-monitoring.
Dynatrace offers the possibility to set up a premium self-monitoring environment on a Dynatrace SaaS cluster. This SaaS environment is hosted by Dynatrace, which monitors your Dynatrace Managed cluster. Data is reported to Mission Control Support Services and stored in a US region. Only Dynatrace privileged employees have access to the data. You will be given permission to access the environment and invite other users.
The premium self-monitoring environment is only available and included in Enterprise Success and Support subscriptions. To learn more about setting up such an environment or subscribing to Enterprise Success and Support, please contact a Dynatrace product expert via live chat.
Self-monitoring data exchange
On each new installation or upgrade of a Dynatrace Managed cluster node, Mission Control provides a self-monitoring OneAgent download URL. Installation sets up a pre-defined self-monitoring configuration, and data is reported to the configured environment. In addition to infrastructure and Dynatrace service metrics, the following is captured:
User information such as IP address
Geolocation of users
Browser or device type
User-action details within Dynatrace Managed such as clicks or page loads
Dynatrace Managed processes logs
Private self-monitoring environment
You can opt out at any time from sending self-monitoring data to Dynatrace. This setting varies depending on your licensing. If this setting is disabled and you want to adjust it - Please contact a Dynatrace product expert via live chat within your environment.
If you opt out from Dynatrace deployment health monitoring, we recommend that you set it up on your own in any other environment. You will not only gain additional visibility into your Dynatrace Managed deployment, but you will also help Dynatrace product experts troubleshoot your issues. You can also install OneAgents on your Cluster and Environment ActiveGates.
When you install OneAgents on your cluster nodes, they contribute to and consume your Dynatrace licenses like any other monitored hosts and applications.
Read Private self-monitoring environment to learn how to opt out and configure your self-monitoring environment.
