Private self-monitoring
  • How-to guide
  • 1-min read
To keep full control over data residency and access, follow the steps below.
If your data privacy requirements are strict, you can opt out at any time. Opting out stops sending self-monitoring data to Dynatrace.
Step 1 Opt out of reporting self-monitoring data
To opt out of reporting Dynatrace Managed self-monitoring data, you need Managed Cluster administrator permissions.
  1. Sign in to your Cluster Management Console.
  2. Go to Settings to display the Dynatrace Managed settings page.
  3. Select Preferences.
  4. Turn off Dynatrace deployment health monitoring. If you can't change this setting in your Managed Cluster, contact Dynatrace Support to make it available.
    Dynatrace Managed stops sending self-monitoring data to Dynatrace.
Step 2 Set up your own self-monitoring
Setting up your own self-monitoring environment requires installing OneAgent on your Cluster nodes, which consumes Dynatrace licenses.
Setting up your own self-monitoring gives you additional visibility into your Managed Cluster and makes it easier for Dynatrace product experts to troubleshoot issues. You can install OneAgents on your Cluster nodes and Environment ActiveGates. For installation information, see Dynatrace OneAgent and Dynatrace ActiveGate.
To retain high availability of your self-monitoring data, set up cross-cluster monitoring. For example, have a pre-production Managed Cluster monitor a production Managed Cluster, and vice versa. If one Managed Cluster goes down, you still have access to self-monitoring data to troubleshoot on your own or with Dynatrace support and services teams.
For advanced configuration of a self-monitoring environment, dashboards, alerting, and naming rules, contact the Dynatrace ACE Services team.
