A Managed Cluster includes a dedicated local self-monitoring environment that collects internal deployment self-monitoring metrics. The local self-monitoring environment is a fully working Dynatrace environment. The self-monitoring environment includes all the self-monitoring metrics collected and aggregated from the other environments on your Managed Cluster. Dynatrace Managed stores all data exclusively on-premises.
The self-monitoring environment does not count toward license consumption and lacks certain functionality, such as connecting OneAgents. The environment is available only for Dynatrace Managed customers using Davis data units (DDUs) licensing.
You can go to the self-monitoring environment from the user menu as you would to any other environment. The local self-monitoring environment has the name Local-Self-Monitoring. The self-monitoring environment also appears in the Cluster Management Console so you can assign user permissions to it.
For an overview of the currently implemented self-monitoring metrics, filter for metrics prefixed with dsfm: in the metric browser. The metric description provides details. You can use the self-monitoring environment to set up alerting or further dashboarding. Dynatrace protects this environment from deletion.
The Cluster health self-monitoring dashboard shows aggregated data for all environments in your Managed Cluster. It includes current utilization and an indicator of whether the Managed Cluster has sufficient capacity for the current load.
The Cluster health self-monitoring dashboard provides:
The self-monitoring dashboard targets the self-monitoring environment of Managed Clusters.
