Use journald to ingest systemd journal logs with the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 4-min read
The journald receiver reads log entries from the systemd journal by invoking journalctl as a subprocess and streaming its output into the OTel Collector pipeline.
Each journal entry becomes an OTLP log record where journal fields are mapped to log attributes. You can use operators to rename or transform these attributes to align with OpenTelemetry semantic conventions.
Use the journald receiver when:
  • Your Linux-based services write logs to the systemd journal rather than to separate log files.
  • You want to centralize host-level system service logs (for example, ssh, kubelet, or docker) in Dynatrace without managing additional log file paths.
  • You need to filter ingestion by specific systemd units and priority levels to control data volume.
Prerequisites
  • One of the following Collector distributions with the journald receiver.
    • Dynatrace Collector
    • Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • The Dynatrace API endpoint URL to which the data should be exported.
  • OptionalIf you ingest via an ActiveGate, you'll need a Classic access token with the relevant access scope. For more information, see Dynatrace OTLP API endpoints (Dynatrace Classic).
  • Linux OS on the host or container where the Collector runs.
  • The journalctl binary needs to be present on the host or in the container where the Collector runs. This is because the receiver relies on journalctl for all journal access.
    • For container deployments, use an image that includes systemd and mount the journal directory from the host.
    • For Kubernetes-specific requirements, see Kubernetes deployment.
  • The Collector process needs permission to read the systemd journal via journalctl.
    • On a Linux OS host, add the user running the Collector to the systemd-journal group to grant read access to the journal. The Collector doesn't need to run as root.
    • For Kubernetes, the Collector must run as root because container isolation prevents group-based journal access. For more information, see Kubernetes deployment.
Demo configuration
The following configuration example shows how to:
  • Configure a Collector instance to read logs from specific systemd units.
  • Map journald fields to OpenTelemetry semantic conventions.
  • Send the entries to Dynatrace.
extensions:
health_check:
endpoint: 0.0.0.0:13133
receivers:
journald:
directory: /var/log/journal
priority: info
start_at: end
operators:
# Move (rename) _PID to pid
- type: move
to: body.pid
# Promote _EXE to a semantic convention attribute
- type: move
to: attributes["process.executable.name"]
# Rename MESSAGE to a consistently named body field
- type: move
to: body.message
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
service:
extensions: [health_check]
pipelines:
logs:
receivers: [journald]
exporters: [otlp_http]
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we configure the following components.
Receivers
Under receivers, we configure the journald receiver with the following parameters.
Filtering by systemd unit
The units parameter restricts ingestion to entries belonging to the listed systemd units. Remove it to collect logs from all units on the host.
For more granular filtering use the matches parameter instead. For example, you can combine unit names with specific journal field values.
See the journald receiver documentation for a full parameter reference, filtering examples, and performance considerations for start_at and priority.
Operators
The operators parameter accepts an array of stanza operators applied to each log entry as it enters the pipeline.
In this configuration, we use move operators to rename specific journal fields and promote _EXE to a log attribute aligned with the OpenTelemetry process semantic conventions.
  • body._PID is renamed to body.pid.
  • body._EXE is renamed to attributes["process.executable.name"].
  • body.MESSAGE is renamed to body.message.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest logs (logs.ingest) scope.
Service pipelines
Under service, we assemble the receiver and exporter into a logs pipeline. The pipeline reads journal entries, applies the operator-based field transformations, and ingests the results into Dynatrace.
Considerations for Kubernetes deployments
When running the journald receiver in Kubernetes, deploy the Collector as a DaemonSet so that one Collector pod runs on every node.
A Deployment is unsuitable because each pod can only access the systemd journal of the node it is scheduled on. Scaling a Deployment to multiple replicas can cause duplicate log ingestion when more than one replica lands on the same node. A DaemonSet ensures complete cluster-wide log coverage and guarantees exactly one privileged, host-access pod per node. This limits the security footprint of running the Collector as root.
Image requirements
As said in Prerequisites, the Collector container must include journalctl to access the systemd journal.
For more information, see the OTel upstream documentation.
Security context
Reading from the systemd journal requires specific Linux capabilities.
Apply the following securityContext (shown in the code block below) to the Collector container. The table then describes the purpose of relevant attributes within the security context definition.
securityContext:
allowPrivilegeEscalation: false
readOnlyRootFilesystem: true
seccompProfile:
type: RuntimeDefault
runAsUser: 0
capabilities:
drop:
- ALL
add:
- DAC_READ_SEARCH
- SYS_PTRACE
SettingReason
Prevents the process from gaining additional privileges beyond the declared capabilities.
Makes the container root filesystem read-only to reduce the attack surface.
seccompProfile: RuntimeDefault
Applies the default seccomp profile to restrict permitted system calls.
runAsUser: 0
The Collector process runs as root to access the journal socket.
When you run as root, you increase the risk of granting root-level access to the node. For more information, see Run as root.
DAC_READ_SEARCH
Bypasses file-system permission checks when reading journal files.
SYS_PTRACE
Required for process introspection used by the journald receiver.
Run as root
The journald receiver does not require that you run as root, but it is the simplest way to obtain the necessary Linux capabilities in a containerized environment.
If your Collector runs as root, avoid co-locating network-exposed receivers (such as otlp bound to 0.0.0.0) in the same instance. A remotely exploitable vulnerability in a network receiver would grant root-level access to the node.
To reduce risk, use a dedicated Collector instance solely for journald log collection. If you must include additional receivers in the same instance, bind them to 127.0.0.1 (loopback) rather than 0.0.0.0 to prevent external access.
Volume mounts
Mount the host's journal directory into the container as read-only.
Set directory: /run/log/journal in the journald receiver configuration to match this mount path.
  • On traditional (non-containerized) Linux systems the persistent journal is stored at /var/log/journal.
  • In containerized Linux environments the journal is typically written to /run/log/journal. This is ephemeral, in-memory storage.
volumeMounts:
- name: run-journal
mountPath: /run/log/journal
readOnly: true
volumes:
- name: run-journal
hostPath:
path: /run/log/journal
Limits and limitations
Logs are ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP API and are subject to the API's limits and restrictions. For more information, see Ingest OpenTelemetry logs.
Related topics
  • Ingest logs from files with the OTel Collector (Dynatrace Classic)
  • Ingest syslog data with the OTel Collector (Dynatrace Classic)
  • Ingest Kubernetes pod logs with the OTel Collector (Dynatrace Classic)
  • Transform and filter data with the OTel Collector (Dynatrace Classic)
Related tags
Application Observability
