Transform and filter data with the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 4-min read
The following configuration example shows how to configure a Collector instance to transform and manipulate OTLP requests, before forwarding them to Dynatrace.
Using the processors shown in this example (filter and transform), it is possible to streamline requests before sending them to Dynatrace and omit data possibly irrelevant to your use case, and to reduce billing costs.
Prerequisites
  • One of the following Collector distributions with the transform and filter processors
    • The Dynatrace OTel Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • The API URL of your Dynatrace environment
  • A Classic access token with the relevant access scope
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Demo configuration
receivers:
otlp:
protocols:
grpc:
endpoint: 0.0.0.0:4317
http:
endpoint: 0.0.0.0:4318
processors:
transform:
trace_statements:
- context: resource
statements:
# Only keep a certain set of resource attributes
- keep_matching_keys(attributes, "^(aaa|bbb|ccc).*")
- context: span
statements:
# Only keep a certain set of span attributes
- keep_matching_keys(attributes, "(^xyz.pqr$)|(^(aaa|bbb|ccc).*)")
# Set a static key
- set(attributes["svc.marker"], "purchasing")
# Delete a specific key
- delete_key(attributes, "message")
# Rewrite a key
- set(attributes["purchase.id"], ConvertCase(attributes["purchase.id"], "upper"))
# Apply regex replacement
- replace_pattern(name, "^.*(DataSubmission-\d+).*$", "$$1")
metric_statements:
- context: metric
statements:
# Rename all metrics containing '_bad' suffix in their name with `_invalid`
- replace_pattern(name, "(.*)_bad$", "$${1}_invalid")
filter:
error_mode: ignore
traces:
span:
# Filter spans with resource attributes matching the provided regular expression
- IsMatch(resource.attributes["k8s.pod.name"], "^my-pod-name.*")
metrics:
metric:
# Filter metrics which contain at least one data point with a "bad.metric" attribute
- 'HasAttrKeyOnDatapoint("bad.metric")'
logs:
log_record:
# Filter logs with resource attributes matching the configured names
- resource.attributes["service.name"] == "service1"
- resource.attributes["service.name"] == "service2"
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
service:
pipelines:
traces:
receivers: [otlp]
processors: [filter,transform]
exporters: [otlp_http]
metrics:
receivers: [otlp]
processors: [filter]
logs:
receivers: [otlp]
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we configure the following components.
Receiver
Under receivers, we specify the standard otlp receiver as active receiver component for our Collector instance.
This is for demonstration purposes. You can specify any other valid receiver here (for example, zipkin).
Processor
Transform
Under processors, we specify the transform processor with a set of different attribute modification statements. context indicates the scope to which the statements should apply (here, resource for resource attributes, span for span attributes, and metric for metrics).
See the OpenTelemetry documentation of the transform processor for more details on the individual configuration options.
The sample configuration above uses the following statements:
StatementDescription
keep_matching_keys
Evaluates the attribute key names and only keeps those, whose names match the given regular expressions of ^(aaa|bbb|ccc).* for resource attributes and (^xyz.pqr$)|(^(aaa|bbb|ccc).*) for span attributes.
set
Adds/changes the following two span attributes:
  • svc.marker, with the static value purchasing
  • purchase.id, coverting its value to uppercase, using ConvertCase
delete_key
Deletes attributes named message.
replace_pattern
Matches a string against a given regular expression and perform a string substitution on all matching entries.
In our example, we first use it for traces to match the name against the regular expression ^.*(DataSubmission-\d+).*$ and replace its content with the first capture group ($$1) of our expression. This essentially means, we search strings for DataSubmission suffixed by a number and — if found — only keep the value of the found match.
We also use the function for metrics with the regular expression (.*)_bad$, to change the _bad suffix to _invalid.
Filter
In addition, we also configure an instance of the filter processor, to filter signal based on the following criteria:
SignalDescription
Traces
Uses IsMatch to match the name of resource attributes against the regular expression ^my-pod-name.*, dropping spans with attributes whose names start with my-pod-name.
Metrics
Uses HasAttrKeyOnDatapoint to evalute if datapoints have attributes with the name bad.metric.
Logs
Uses a strict string match of the resource attribute service.name against the strings service1 and service2.
See the OpenTelemetry documentation of the filter processor for more details on the individual configuration options.
Exporter
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest logs (logs.ingest), Ingest metrics (metrics.ingest), and Ingest OpenTelemetry traces (openTelemetryTrace.ingest) scopes.
Service pipeline
Under service, we assemble our receiver, processor, and exporter objects into a traces pipeline, which accepts OTLP traces on the configured endpoints and transforms trace attributes according to the configured rules, before forwarding everything to Dynatrace using the exporter.
Limits and limitations
Data is ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP APIs and is subject to the API's limits and restrictions. For more information see:
  • OpenTelemetry metrics limitations
  • Dynatrace metrics mapping
  • Ingest OpenTelemetry logs
Related topics
  • Enrich ingested data with Dynatrace-specific fields
Related tags
Application Observability
