Enrich ingested data with Dynatrace-specific fields
  • Dynatrace Classic
  • Reference
  • 5-min read
Unlike automatic ingestion using OneAgent, data sent directly to an ActiveGate (for example, ingest APIs) is not automatically enriched with host-related information. This may incur additional charges, as it would not take into account possibly included DDU quotas.
The different Dynatrace deployment options provide several Java-style properties and JSON files with sets of attributes that you can use to enrich your requests to Dynatrace and ensure Dynatrace can map the data to your infrastructure.
Enrichment directory
Dynatrace uses the following directories to provide .json and .properties files with enrichment data:
  • On Unix: /var/lib/dynatrace/enrichment
  • On Windows: %ProgramData%\dynatrace\enrichment
Dynatrace OneAgent
A standard OneAgent setup provides the following files with host-specific details in the enrichment directory:
  • dt_host_metadata.json
  • dt_host_metadata.properties
Both files contain the same collection of host-level resource attributes that OneAgent uses to enrich monitoring artifacts for a given host. This also includes key-value tags and properties set via oneagentctl or through Remote configuration management.
If you supply telemetry data via different channels than OneAgent (for example, using OpenTelemetry), it is important you enrich your telemetry data manually with these attributes to ensure the proper host association.
For more information, see Host-level resource attributes.
For an example of how to load the JSON file, see the Python example below.
OneAgent virtual files
When OneAgent is monitoring your application, your application is also able to access the following virtual files:
  • dt_metadata_e617c525669e072eebe3d0f08212e8f2.json
  • dt_metadata_e617c525669e072eebe3d0f08212e8f2.properties
These files are not specific to the enrichment directory and do not physically exists in your file system, but are provided by the OneAgent instrumentation. Both files return the same data and the file extension (.json/.properties) only determines the output format.
In the context of Dynatrace Operator, the virtual file also contains the attributes of the dt_metadata.{json,properties} files.
How to access the virtual files
  1. Use the standard file read function of your language platform to open and read one of these files:
    The file extension you choose is relevant for step 4. Only use the filename and do not specify an additional path.
  2. The content of the file is a single text line with an absolute file path (consider it an ephemeral value and do not store, persist, or cache that path for later use).
  3. Open the file at the path location obtained in the previous step and read its entire content.
  4. The content format received from the previous read will match the file extension you chose in step 1 (Java-style properties or JSON).
If step 1 returns a file-not-found error, verify that your application is instrumented by OneAgent.
Limitations
  • Supported for full-stack and application-only deep-monitored processes.
  • The stat and other if (exists) checks fail for these files. These checks are not required for the mechanism to work.
  • syscalls used directly for file access aren't supported. This also means that the Go-based applications used for metric ingestion aren't supported unless you use the OneAgent SDK as explained in Instrument your Go application with OpenTelemetry (Dynatrace Classic).
Python example
The following example shows how to load the enrichment information as JSON in Python on Unix.
# Initialize dictionary variable
enrich_attrs = dict()
# Iterate over the potential data files and try reading them
for name in ["dt_metadata_e617c525669e072eebe3d0f08212e8f2.json", "/var/lib/dynatrace/enrichment/dt_metadata.json", "/var/lib/dynatrace/enrichment/dt_host_metadata.json"]:
try:
data = ''
with open(name) as f:
data = json.load(f if name.startswith("/var") else open(f.read()))
enrich_attrs.update(data)
except:
pass # An exception indicates the file was not available
# Use enrich_attrs here to enrich your requests to Dynatrace.
# For example, when instrumenting with OpenTelemetry, add the data as resource attributes.
The example code initializes an empty dictionary for the imported attributes. It then iterates over an array of .json filenames and loads the content of each file as JSON document, adding the keys to the dictionary. File exceptions indicate the particular file is not available and are ignored.
Dynatrace Operator
When metadataEnrichment is enabled in your DynaKube, the Dynatrace Operator injects the following files into the enrichment directory of each pod:
  • dt_metadata.json
  • dt_metadata.properties
Both files contain the same Kubernetes metadata in different formats. For an example of how to load the JSON file, see the Python example above. With OneAgent enabled, these files are applied automatically; without OneAgent, load and apply them manually.
The resource attributes you declare in your DynaKube also land in these files. See Set resource attributes in the DynaKube.
metadataEnrichment is automatically enabled — no explicit DynaKube configuration required — when using OneAgent injection (cloudNativeFullStack or applicationMonitoring) or OTLP exporter auto-configuration.
Enable metadataEnrichment in your DynaKube
Add metadataEnrichment to your DynaKube spec:
spec:
metadataEnrichment:
enabled: true
To limit enrichment to specific namespaces, add a namespaceSelector:
spec:
metadataEnrichment:
enabled: true
namespaceSelector:
matchLabels:
team: finance
Enrichment file contents
Both files expose the following attributes:
"k8s.cluster.name": "<cluster-name>",
"k8s.cluster.uid": "<cluster-uid>",
"k8s.namespace.name": "<namespace-name>",
"k8s.node.name": "<node-name>",
"k8s.pod.name": "<pod-name>",
"k8s.pod.uid": "<pod-uid>",
"k8s.container.name": "<container-name>",
"k8s.workload.kind": "<workload-kind>",
"k8s.workload.name": "<workload-name>",
"dt.entity.kubernetes_cluster": "<kubernetes-cluster-id>",
"dt.kubernetes.cluster.id": "<cluster-id>",
"dt.kubernetes.workload.kind": "<workload-kind>",
"dt.kubernetes.workload.name": "<workload-name>"
Confirm enrichment is working by inspecting /var/lib/dynatrace/enrichment inside an injected pod and verifying both files are present.
