Ingest syslog data with the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 3-min read
The following configuration example shows how to configure a Collector instance to receive data from syslog and send it to the Dynatrace backend.
Prerequisites
  • One of the following Collector distributions with the attributes processor and the Syslog receiver:
    • The Dynatrace OTel Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • The Dynatrace API endpoint URL to which the data should be exported
  • A Classic access token with the relevant access scope (only required for SaaS and ActiveGate)
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Demo configuration
receivers:
syslog/f5:
tcp:
listen_address: "0.0.0.0:54526"
protocol: rfc5424
operators:
- type: add
field: attributes.log.source
value: syslog
- type: add
field: attributes.dt.ip_addresses
value: "1xx.xx.xx.xx1"
- type: add
field: attributes.instance.name
value: "ip-1xx-xx-x-xx9.ec2.internal"
- type: add
field: attributes.device.type
value: "f5bigip"
syslog/host:
tcp:
listen_address: "0.0.0.0:54527"
protocol: rfc5424
operators:
- type: add
value: syslog
- type: add
value: "ubuntu-syslog"
processors:
attributes:
actions:
- key: net.host.name
action: delete
- key: net.peer.name
action: delete
- key: net.peer.port
action: delete
- key: net.transport
action: delete
- key: net.host.ip
action: delete
- key: dt.ingest.port
from_attribute: net.host.port
action: upsert
- key: dt.ingest.source.ip
from_attribute: net.peer.ip
action: upsert
- key: net.peer.ip
action: delete
- key: net.host.port
action: delete
- key: syslog.hostname
from_attribute: hostname
action: upsert
- key: hostname
action: delete
- key: syslog.facility
from_attribute: facility
action: upsert
- key: facility
action: delete
- key: syslog.priority
from_attribute: priority
action: upsert
- key: priority
action: delete
- key: syslog.proc_id
from_attribute: proc_id
action: upsert
- key: proc_id
action: delete
- key: syslog.version
from_attribute: version
action: upsert
- key: version
action: delete
- key: syslog.appname
from_attribute: appname
action: upsert
- key: appname
action: delete
- key: syslog.message
from_attribute: message
action: upsert
- key: message
action: delete
- key: syslog.message_id
from_attribute: msg_id
action: upsert
- key: msg_id
action: delete
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
service:
pipelines:
logs:
receivers: [syslog/f5, syslog/host]
processors: [attributes]
exporters: [otlp_http]
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we use the following components.
Receivers
Under receivers, we specify two instances of the syslog receiver as active receiver components for our Collector instance.
The Syslog receiver supports a number of configuration parameters, which enable you to customize its behavior. For our example, we use the following:
  • tcp—Specifies a TCP listener for the receiver and configures ports 54526 and 54527
  • protocol—Specifies the RFC 5424 implementation for our receiver (alternatively, RFC 3164 is also supported)
  • operators—Configures the operators we apply to each log entry. For our example, we use the add operator to add additional information.
    • field—Specifies the name of value we are adding
    • value—Specifies the content of the value we are adding
Processors
Under processors, we configure the attributes processor to drop and adjust the indicated attributes in our OTLP request.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest logs (logs.ingest) scope.
Service pipelines
Under service, we eventually assemble our receiver, processor, and exporter objects into a logs pipeline, which uses the receiver instances to obtain syslog data and ingest it into Dynatrace using OTLP.
Limits and limitations
Logs are ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP API and are subject to the API's limits and restrictions. For more information, see Ingest OpenTelemetry logs.
Related topics
  • Enrich ingested data with Dynatrace-specific fields
  • Enrich OTLP requests with Kubernetes data (Dynatrace Classic)
  • Ingest logs from files with the OTel Collector (Dynatrace Classic)
  • Ingest FluentD data with the OTel Collector (Dynatrace Classic)
  • Syslog ingestion with ActiveGate (Logs Classic)
Related tags
Application Observability
