Send Telegraf metrics to Dynatrace
  • Dynatrace Classic
  • 2-min read
  • Published Oct 15, 2020
Telegraf is a plugin-driven server agent for collecting, processing, aggregating, and writing metrics. Telegraf comes with the Dynatrace Output Plugin that enables you to easily send Telegraf metrics to Dynatrace.
Enable Telegraf ingestion
Telegraf metric ingestion comes with OneAgent version 1.201+. The easiest configuration scenario is to install Telegraf and OneAgent on the same host. Then you only need to enable the Dynatrace Output Plugin in your Telegraf configuration (Telegraf version 1.16+) and enable Telegraf metric ingestion at the environment or host level in your Dynatrace configuration. Note that the host-level configuration overrides the environment-level configuration.
Enable the Dynatrace Output Plugin in Telegraf configuration
  1. Edit telegraf.conf, the Telegraf configuration file.
  2. Uncomment the [[outputs.dynatrace]] line.
  3. Optional Uncomment the prefix = "telegraf." line and set the prefix to easily find the Telegraf ingested metrics. The prefix will also be visible in the Dynatrace metric key.
  4. Save the file.
# # Send telegraf metrics to a Dynatrace environment
# ## For usage with the Dynatrace OneAgent you can omit any configuration,
# ## the only requirement is that the OneAgent is running on the same host.
# ## Only setup environment url and token if you want to monitor a Host without the OneAgent present.
# ## Your Dynatrace environment URL.
# ## For Dynatrace OneAgent you can leave this empty or set it to "http://127.0.0.1:14499/metrics/ingest" (default)
# ## For Dynatrace SaaS environments the URL scheme is "https://{your-environment-id}.live.dynatrace.com/api/v2/metrics/ingest"
# ## For Dynatrace Managed environments the URL scheme is "https://{your-domain}/e/{your-environment-id}/api/v2/metrics/ingest"
# url = ""
# ## Your Dynatrace API token.
# ## Create an API token within your Dynatrace environment, by navigating to Settings > Integration > Dynatrace API
# ## The API token needs data ingest scope permission. When using OneAgent, no API token is required.
# api_token = ""
# ## Optional prefix for metric names (e.g.: "telegraf.")
# ## Optional TLS Config
# # tls_ca = "/etc/telegraf/ca.pem"
# # tls_cert = "/etc/telegraf/cert.pem"
# # tls_key = "/etc/telegraf/key.pem"
# ## Optional flag for ignoring tls certificate check
# # insecure_skip_verify = false
# ## Connection timeout, defaults to "5s" if not set.
# timeout = "5s"
No OneAgent on the host
If you can't install OneAgent on the Telegraf-monitored host, you can configure the Dynatrace Output Plugin to push metrics directly to your Dynatrace environment through Metrics API v2.
Prerequisites
  • API token with the Ingest metrics data points scope.
  • Your Environment ID.
  2. Uncomment the # [[outputs.dynatrace]] line.
  3. Optional Uncomment the # prefix = "telegraf." line and set the prefix to easily find the Telegraf ingested metrics. The prefix will also be visible in the Dynatrace metric key.
  4. Uncomment the # api_token = "" line and add your API token, for example api_token = "abcdefjhij1234567890"
  5. Uncomment the # url = "" line and add your Dynatrace metric API endpoint, for example, url = "https://{your-environment-id}.live.dynatrace.com/api/v2/metrics/ingest".
  6. Save the file.
# url = "https://abd12345.live.dynatrace.com/api/v2/metrics/ingest"
# timeout = "5s"
Enable at the environment level
  1. Go to Settings and select Preferences > Extension Execution Controller.
  2. Turn on Enable Extension Execution Controller.
  3. Turn on Enable local HTTP Metric, Log and Event Ingest API.
Enable for a single host
  1. Go to Hosts Hosts Classic.
  2. Find and select your host to display the host overview page.
  3. In the upper-right corner of the host overview page, select More (…) > Settings.
  1. In the host settings, select Extension Execution Controller.
Enable for a host group
  1. Go to Deployment Status Deployment Status > OneAgents.
  2. On the OneAgent deployment page, turn off Show new OneAgent deployments.
  3. In the Filter by field, enter Host group, and then select the host group you want to configure from the dropdown list.
    The host list is now filtered by the selected host group. Each listed host has a Host group: <group name> link, where <group name> is the name of the host group that you want to configure.
    The Host group property is not displayed when the selected host doesn't belong to any host group.
  4. Select the host group name in any row.
    As you have filtered by host group, all displayed hosts go to the same host group.
  1. In the host group settings, select Extension Execution Controller.
Topology awareness
When OneAgent and Telegraf are installed on the same host, the host ID and host name context are automatically added to each metric as dimensions. Learn how to enrich your metrics with other Dynatrace-specific dimensions and apply Dynatrace-AI causation details to your ingested data.
Metric format
Provided data points must follow the Metrics ingestion protocol.
Communication port
The Telegraf Dynatrace Output Plugin sends metrics to the OneAgent metric API endpoint.
The default metric ingestion port is 14499. If necessary, you can use the oneagentctl command to check or change the port. Changing the metric ingestion port requires restart of OneAgent. Add --restart-service to the command to restart OneAgent automatically.
Check the ingestion port
Use the --get-extensions-ingest-port parameter to show the current local ingestion port, 14499 by default.
  • Linux, AIX: ./oneagentctl --get-extensions-ingest-port
  • Windows: .\oneagentctl.exe --get-extensions-ingest-port
Set a custom ingestion port
Use the --set-extensions-ingest-port=<arg> parameter to set a custom local ingestion port.
  • Linux, AIX: ./oneagentctl --set-extensions-ingest-port=14499 --restart-service
  • Windows: .\oneagentctl.exe --set-extensions-ingest-port=14499 --restart-service
Configure proxy
Configure your host proxy to allow localhost traffic going to the metric ingestion port, 14499 by default.
If you change the default OneAgent communication port, make sure you also update the Telegraf configuration.
  2. Set the url property to url = "http://127.0.0.1:<your-custom-port>/metrics/ingest".
  3. Save the file.
Note that changing the port for Telegraf ingested metrics also affects OneAgent REST API and Scripting integration.
