Adaptive Traffic Management (ATM) is an intelligent trace sampling mechanism Dynatrace uses for Full-Stack Monitoring.
OneAgent automatically manages the volume of ingested trace data via Adaptive Traffic Management and continuously adjusts the adaptive trace sampling rate to keep the ingested trace data volume roughly within your total licensed Full-Stack trace volume.
By default, the total licensed Full-Stack trace volume equals the Full-Stack included trace volume. If you extend the amount of trace data ingested with OneAgent, the total licensed Full-Stack trace volume becomes the sum of the included and extended volumes.
With Dynatrace Platform Subscription (DPS), Adaptive Traffic Management applies this behavior to all full-stack monitored hosts and applications and can be further controlled via trace ingest control and trace sampling settings.
If you have a Dynatrace Platform Subscription (DPS) license that was signed prior to April 26, 2023, refer to Adaptive Traffic Management with Dynatrace classic license (Dynatrace Classic). For these licenses, Adaptive Traffic Management consumption is calculated the same way as with Dynatrace classic licenses.
Adaptive Traffic Management continuously monitors the ingested trace data volume from full-stack monitored hosts and applications. If the ingested trace data volume exceeds your total licensed Full-Stack trace volume, Adaptive Traffic Management lowers the adaptive trace sampling rate on OneAgent. This reduces the trace capture rate and therefore the ingested trace data volume while keeping it roughly within the total licensed Full-Stack trace volume.
In a dynamic cloud environment, the amount of traffic and contributing memory can change frequently. Adaptive Traffic Management automatically adjusts the sampling rate of trace data collection in 15-minute intervals so that the collected trace data doesn't exceed your total licensed Full-Stack trace volume without your explicit consent.
In many cases, this results in a trace capture rate of 100% of all possible traces. However, depending on the monitored applications and the configuration of certain features in your environment, your capture rate might be lower.
If the OneAgent capture rate is below 100%, it means the adaptive trace sampling rate is lower than needed to capture all possible distributed traces. You can control which traces are captured by adjusting the adaptive trace sampling rate for full-stack monitored hosts and applications and by configuring trace sampling rules for specific HTTP and RPC requests.
Adaptive Traffic Management sampling decisions are made locally (on OneAgent, or on Envoy when using the Dynatrace sampler) before any Dynatrace backend infrastructure is involved.
Trace sampling for full-stack monitored hosts and applications is head-based: the decision to capture a trace is made once by the OneAgent that starts the trace and is then propagated to every service the trace passes through via the trace context header.
Therefore, a sampling rule takes effect on the scope where traces are initiated—that is, on root spans. A rule configured for a scope that only continues traces started elsewhere doesn't change how often those traces are captured, as the decision was already made upstream.
When you adjust the adaptive trace sampling rate or configure fixed-rate sampling, select the scope that contains the entry point of the traces you want to control. For example, if all external requests enter your cluster through a service in the ingress namespace, a rule set for the checkout namespace doesn't affect those traces. Instead, configure either the ingress namespace or a scope that contains this namespace. The rule set for the checkout namespace still applies to traces that start there, such as background jobs or scheduled tasks.
Dynatrace provides the following configuration options to control trace volume usage and capture rate:
Configuring adaptive sampling rules
Adjust the multiplier used to calculate the sampling threshold at the deployment level. This lets you control the usage of the usable adaptive trace volume much more closely to where you need it. For details, see Adjust adaptive trace sampling rate.
Reducing the usable adaptive trace volume provided to Adaptive Traffic Management
Reduce adaptive usage when it's not needed. This allows you to allocate part of the Full-Stack included trace volume to fixed-rate sampled spans from OpenTelemetry or OneAgent, or to better self-service your trace volume after requesting extended ingest. For details, see Reduce usable adaptive trace volume.
Configuring trace sampling rules for HTTP and RPC requests
If a process monitored by OneAgent has a capture rate below 100%, you can prioritize specific HTTP or RPC requests to be captured more or less often relative to other request types. For details, see Adjust trace sampling for HTTP or RPC requests.
Configuring fixed-rate sampling
Capture traces initiated within a scope at a configured rate, regardless of the current adaptive trace sampling rate or ingested trace data volume. This is useful when you need a guaranteed or predictable capture rate for regulatory, auditing, fraud detection, business, or supportability reasons. For details, see Configure fixed-rate sampling.
Environment-wide allocation vs per-service rates
Many sampling approaches, such as fixed-rate head-based sampling configured in individual SDKs or agents make sampling decisions independently per service or host, at a static rate. Adaptive Traffic Management also samples at the start of a trace (head-based sampling), but distributes the usable adaptive trace volume across all OneAgents in an environment, so low-volume services effectively share unused capacity with high-volume services that need more traces.
Adaptive vs static configuration
Traditional sampling is often configured as a static percentage per service or via hand-maintained rules. Adaptive Traffic Management continuously adjusts the adaptive trace sampling rate based on the actually ingested trace data volume and your total licensed Full-Stack trace volume, while still allowing you to control specific requests via HTTP- and RPC-based trace sampling rules.
Cost and volume predictability
With fixed sampling rates, the total amount of captured trace data still scales with transaction volume, so trace ingest and storage costs follow traffic spikes. Adaptive Traffic Management keeps ingested trace data from full-stack monitored hosts and applications roughly within your total licensed Full-Stack trace volume or a configured percentage of it, making trace ingest and cost more predictable.
The Full-Stack included trace volume is measured in bytes per minute. It is calculated based on your Full-stack gibibyte-hours.
Each environment can process a minimum trace volume. For each contributing gibibyte, the environment peak trace volume is increased by 200 KiB per minute, for a total included volume of 3,000 KiB per contributing gibibyte in each 15-minute interval.
Every 15 minutes, the peak trace volume is calculated and automatically adjusted based on the average of contributing gibibytes in the previous 15-minute interval.
With Dynatrace Platform Subscription (DPS), all features—especially data-heavy ones like bind variables capture—are available.
To learn more about the Full-Stack included trace volume, see Traces included with Full-Stack Monitoring.
If OneAgent applies Adaptive Traffic Management and not all requests are captured, the individual spans have the sampling.threshold attribute with a non-zero value. This attribute represents the effective sampling threshold used when the trace was created. You can use the sampling.threshold attribute to derive the effective trace capture rate for a process.
The following scenario demonstrates how each configuration lever affects trace capture rates, ingested volumes, and billing.
The example environment consists of four Kubernetes namespaces (Namespace A through Namespace D), each generating 40 GiB of potential trace traffic per month (160 GiB total), with a 100 GiB Full-Stack included trace volume. Trace data from full-stack monitored sources that exceeds the included volume is billed via Traces – Ingest & Process.
The volumes in this scenario are idealized monthly averages. In practice, ATM adjusts the per-agent rate limit every 15 minutes, so ingest can briefly overshoot before being corrected. Over a full billing period, actual adaptive ingest converges toward—and might slightly exceed—the usable adaptive trace volume.
Each of the following steps builds on the previous one to demonstrate a possible real-world example of how the volume and billing react to sampling configurations.
All namespaces use adaptive sampling at the default rate factor of 1x. No extended ingest or fixed-rate sampling is configured. ATM distributes the 100 GiB of usable adaptive trace volume equally, giving each namespace ~25 GiB (~62.5% capture rate). The total ingested volume exactly matches the included volume.
Detailed breakdown
Per-namespace impact:
Billing summary:
The extended ingest factor increases the total licensed Full-Stack trace volume to 120 GiB. All namespaces benefit equally, each capturing 30 GiB (~75% capture rate). The 20 GiB above the 100 GiB of the included trace volume is billed as the fullstack-adaptive licensing type via Traces – Ingest & Process.
Detailed breakdown
Billing summary:
fullstack-adaptive licensing type)Namespace A now receives a much larger share of the adaptive budget and saturates at its full 40 GiB potential (~100% capture rate). The remaining 80 GiB is distributed among Namespace B, C, and D, each capturing ~66.7% (~26.7 GiB). The total ingested volume stays at 120 GiB, so the excess remains 20 GiB.
The adaptive rate factor is a relative weight for dividing the usable adaptive trace volume, not a target capture rate, and it can never claim more traces than a scope actually produces. So any factor above the point where Namespace A reaches 100% capture produces the same result. Setting it generously has no downside and keeps Namespace A prioritized when the adaptive volume or the set of competing scopes changes, as Step 5 demonstrates.
Detailed breakdown
Billing summary:
fullstack-adaptive licensing type)Namespace B hosts the most business-critical applications, where 100% trace capture is required regardless of the current adaptive trace sampling rate. With fixed-rate sampling activated, Namespace B captures every trace it initiates (40 GiB). ATM redistributes the 120 GiB adaptive budget among the remaining three namespaces. With Namespace A saturating at 40 GiB, the remaining 80 GiB covers Namespace C and D exactly (~100% each). Total ingest rises to 160 GiB. The 60 GiB above the included volume is split proportionally: 45 GiB as the fullstack-adaptive licensing type and 15 GiB as the fullstack-fixed-rate licensing type.
Detailed breakdown
Billing summary:
fullstack-adaptive licensing type (120/160 Ă— 60)fullstack-fixed-rate licensing type (40/160 Ă— 60)Full visibility is now guaranteed for the business-critical applications in Namespace B, at a cost of 60 GiB above the Full-Stack included trace volume. To keep that visibility while returning to the included volume, reduce the usable adaptive trace volume to 50%. The adaptive budget drops from 120 GiB to 60 GiB. Namespace A still saturates at 40 GiB, leaving 10 GiB each for Namespace C and D (25% capture rate). Namespace B remains at 100% fixed-rate (40 GiB). The total ingest is 100 GiB (60 GiB + 40 GiB), matching the included trace volume exactly, with no excess billing.
Note that the extended ingest factor (1.2x) is still configured, so the total licensed volume remains at 120 GiB. This is a transitional state, and you may still want to keep it active for peak traffic periods. After observing stable billing, review your extended ingest, adaptive, and fixed-rate ingest configuration to find the right balance.
Detailed breakdown
Billing summary:
Use this feature to adjust the adaptive trace sampling rate at the following scopes: environment, host group, Kubernetes cluster, Kubernetes namespace, Kubernetes deployment, or process group. This allows you to control the usage of the Full-Stack included trace volume at a settings scope level. The rate factor affects traces that are initiated within the selected scope. For details, see Where sampling rules take effect. The setting applies to processes monitored by OneAgent; trace ingestion via Envoy or Istio doesn't account for it yet.
This control is available via the Settings API. It will also soon be available directly in
Settings.
To adjust the adaptive trace sampling rate, use the Trace ingest control schema provided by the Settings API. The following is the general guidance for this setting.
schemaId to builtin:trace.ingest.control.scope to the meaningful value, for example, to the HOST_GROUP-1A2B3C4D5E6F7G8H entity ID.objectId for the settings object.adaptiveSamplingSwitch to true.adaptiveTraceIngestRateFactor to a factor between 0.01 and 100 to indicate that you want the trace capture rate to be 1/100th of normal (0.01) or 100x of normal (100) rate.adaptiveTraceIngestRateFactor is only evaluated when adaptiveSamplingSwitch is true. When adaptiveSamplingSwitch is false, the scope uses fixed-rate sampling and only fixedSamplingRate is evaluated.
For step-by-step details on using the Settings API, see Example 3 and Example 4 in the use cases section.
Dynatrace enables you to control how much of your total licensed Full-Stack trace volume is allocated to Adaptive Traffic Management as usable adaptive trace volume.
This self-service capability lets you reduce the usable adaptive trace volume when full capacity isn't needed. Common use cases include lowering adaptive usage, extending the amount of trace data for major events, reserving part of the licensed Full-Stack trace volume for fixed-rate sampled spans from OpenTelemetry or OneAgent, or better self-servicing your trace volume after requesting extended ingest.
Overall, this control gives you greater flexibility to manage ingested trace data effectively.
This control is available via the Settings API from Dynatrace version 1.332+. It will also soon be available directly in
Settings. Note that the Dynatrace version (the platform/cluster version) and the OneAgent version (the agent build number) are independently versioned. Verify each against the respective version in your environment.
To adjust the usable adaptive trace volume, use the Global trace ingest rate control schema provided by the Settings API. The following is the general guidance for this setting.
schemaId to builtin:global.trace.ingest.control.scope to environment, as this is an environment-wide setting only.usableAdaptiveTraceVolumePercentage to a value between 1 and 100.For the instructions on using the Settings API, see Example 5 and Example 6 in the use cases section.
With fixed-rate sampling, you can set a fixed trace capture rate for a scope, bypassing Adaptive Traffic Management for traces initiated within that scope—that is, for root spans. OneAgents monitoring services that participate in a trace started outside the scope continue to follow the original sampling decision, so configure the scope to match the entry point of the traces you want to control. For details, see Where sampling rules take effect. This is useful when you need a guaranteed or predictable capture rate, for example, for regulatory, auditing, fraud detection, or supportability requirements.
Fixed-rate sampling requires OneAgent version 1.339+ across the environment and is highly recommended to ensure consistent billing. Fixed-rate sampling applies to processes monitored by OneAgent. Trace ingest via Envoy or Istio doesn't take it into account yet.
Currently, you can configure fixed-rate sampling via the Settings API. Soon, it will also be available directly in
Settings.
Configuring fixed-rate sampling on the environment scope isn't available for all environments. Because a fixed rate applied environment-wide can produce high trace ingest volumes, fixed-rate sampling is automatically activated only for environments that ingest less than 2 TiB of trace data per day. If you need to set fixed-rate sampling on the environment scope and don't see the corresponding option, contact your Dynatrace representative.
When fixed-rate sampling is activated for a scope, OneAgents within that scope independently sample each trace at the configured rate. The sampling decision is propagated to all downstream OneAgents via the trace context header, ensuring that the entire distributed trace follows the fixed sampling decision regardless of where it continues.
Fixed-rate sampled spans still consume your Full-Stack included trace volume. Only the portion of the ingested trace volume that exceeds the included volume is billed as Traces – Ingest & Process, with the fullstack-fixed-rate licensing type.
Fixed-rate sampled spans are not counted against the usable adaptive trace volume, and Adaptive Traffic Management ignores them when adjusting the adaptive trace sampling rate. Therefore, activating fixed-rate sampling for one scope doesn't lower the capture rate of scopes that rely on adaptive capture.
To manage your trace budget when activating fixed-rate sampling for a high-traffic scope, consider reducing the usable adaptive trace volume to reserve more of the Full-Stack included trace volume for fixed-rate sampled spans.
To configure fixed-rate sampling for a scope, use the Trace ingest control schema provided by the Settings API:
schemaId to builtin:trace.ingest.control.scope to the relevant entity ID (for example, CLOUD_APPLICATION_NAMESPACE-1A2B3C4D5E6F7G8H for a Kubernetes namespace, or HOST_GROUP-1A2B3C4D5E6F7G8H for a host group).adaptiveSamplingSwitch to false to deactivate Adaptive Traffic Management for this scope.fixedSamplingRate to a value from 0 (100% capture) through 7 (~0.78% capture). Each increment halves the capture rate (for example, 0 = 100%, 1 = 50%, 2 = 25%).HTTP and gRPC sampling rules apply to OneAgent-monitored processes only. Envoy traces that participate in Adaptive Traffic Management via the Dynatrace sampler are subject to the environment-wide adaptive trace sampling rate but are not affected by these per-request rules.
When you increase or decrease the sampling frequency of HTTP or RPC requests, these requests are captured more or less often relative to other request types.
Modifying trace sampling for HTTP or RPC requests does not change the overall capture rate for the process or the overall ingested trace data volume. However, if you deactivate tracing for specific HTTP and RPC requests, the capture rate is increased.
In all environments, there are transactions for which traces are of lower value. You can turn off tracing for specific HTTP and RPC requests completely at any time, freeing up trace volume for more important requests. This feature removes those traces completely from the capture rate calculation (they are no longer considered when computing the capture rate) and therefore leads to an overall increase in capture rate. Deactivation rules always take effect regardless of the current OneAgent capture rate.
Adaptive Traffic Management assigns each process the adaptive trace sampling rate. When this sampling rate is lower than needed for a 100% trace capture rate, OneAgent decides which traces to capture while staying within the configured rate and the usable adaptive trace volume.
To do this, OneAgent groups requests by signature (for example, URI or RPC endpoint) and computes a list of top requests for each process every minute. Based on that list and on any HTTP and RPC trace sampling rules you configure, OneAgent applies capture factors so that:
This ensures that you use your trace volume most effectively. As the sampling is not random, important data is captured while maintaining a statistically valid sample set.
The following table illustrates how different URIs can be captured at different rates while respecting the overall capture rate for a process.
| Request | Number of requests processed by the application, per minute | Capture factor | Captured end-to-end distributed traces, per minute |
URI A | 900 | 1/2 | 450 |
URI B | 440 | 1/2 | 220 |
URI C | 250 | 1 | 250 |
URI D | 60 | 1 | 60 |
…50 other URIs | 100 | 1 | 100 |
Total | 1750 | 1080 |
In this example, OneAgent observes 1,750 HTTP requests per minute but captures traces for about 1,080 of them. Lower-volume URIs (C, D, and the other URIs) are fully captured, while the most frequent URIs (A and B) are captured at half the rate. The total number of captured traces still respects the capture rate that Adaptive Traffic Management has assigned to the process.
You can configure web request trace sampling for the following configuration scopes: environment, host group, process group, Kubernetes cluster, and Kubernetes namespace.
For all traces in your environment.
For traces started within a particular host group, process group, Kubernetes cluster, or Kubernetes namespace. This is useful if you don't have environment permissions or want to modify trace sampling for a particular part of your environment.
Navigate to the trace sampling configuration page depending on the entity for which you want to modify the sampling frequency of HTTP or RPC requests.
Go to
Deployment Status > OneAgents.
On the OneAgent deployment page, turn off Show new OneAgent deployments.
In the Filter by field, enter Host group, and then select the host group you want to configure from the dropdown list.
The host list is now filtered by the selected host group. Each listed host has a Host group: <group name> link, where <group name> is the name of the host group that you want to configure.
The Host group property is not displayed when the selected host doesn't belong to any host group.
Select the host group name in any row.
As you have filtered by host group, all displayed hosts go to the same host group.
Go to
Technologies & Processes Classic and choose a technology.
Alternatively, go to
Hosts Classic and choose a host.
Find and select the required process group.
In the upper-right corner of the process group overview page, select Settings.
Select Trace sampling for HTTP requests or Trace sampling for RPC requests.
Kubernetes Classic.Adjust the trace sampling for your HTTP or RPC requests.
Select Add URL.
Choose how to adjust the trace sampling.
To match the HTTP request, do one or a combination of the following:
Enter the URL path and select the comparison condition.
Use wildcards (**) for URL paths with similar segments.
For example, in /api/product/**/detail, all values between slashes are ignored; the path applies to both /api/product/1/detail and /api/product/2/detail.
Use the query parameters.
Optional To apply the scaling factor to specific HTTP methods, turn off Any HTTP method, and select the required HTTP methods.
Select Save changes.
Select Add RPC.
Specify the Protocol.
To match the RPC request, enter the name and the comparison condition of one or a combination of the following parameters:
Check the examples below to understand how to properly adjust the trace sampling for your HTTP or RPC requests.
The following rule reduces the importance (by a factor of four) of requests that start with _healthz.
/_healthz for the URL path.The following rule ignores all requests (starting with /) that use OPTIONS as an HTTP method for a selected process group.
/ for the URL path.Navigate to the cluster settings page.
Kubernetes Classic.Copy the cluster ID (entity ID) from the settings page URL, for example, KUBERNETES_CLUSTER-1A2B3C4D5E6F7G8H.
Use the Settings API - POST an object endpoint to create a new settings object according to the following.
adaptiveTraceIngestRateFactor to 50.adaptiveSamplingSwitch to true.[{"schemaId": "builtin:trace.ingest.control","scope": "KUBERNETES_CLUSTER-1A2B3C4D5E6F7G8H","value": {"adaptiveSamplingSwitch": true,"adaptiveTraceIngestRateFactor": 50}}]
You should receive a successful response that contains objectId.
Optional Use the Settings API - GET effective values endpoint to verify the settings change.
Kubernetes Classic.Copy the cluster ID (entity ID) from the settings page URL, for example, KUBERNETES_CLUSTER-H8G7F6E5D4C3B2A1.
Use the Settings API - GET effective values endpoint to check the value of adaptiveTraceIngestRateFactor, which is the currently effective adaptive trace ingest rate factor for this scope.
The response shows that the adaptive trace ingest rate factor (adaptiveTraceIngestRateFactor) is already reduced to 0.8 for this Kubernetes cluster:
{"items": [{"origin": "KUBERNETES_CLUSTER-H8G7F6E5D4C3B2A1","value": {"adaptiveSamplingSwitch": true,"adaptiveTraceIngestRateFactor": 0.8}}],"totalCount": 1,"pageSize": 100}
Use the Settings API - GET objects endpoint to find the settings objectId for your Kubernetes cluster.
Add scope to the fields query parameter.
Use the Settings API - PUT an object endpoint to update the existing settings object according to the following.
adaptiveTraceIngestRateFactor to 0.01.adaptiveSamplingSwitch to true.{"value": {"adaptiveSamplingSwitch": true,"adaptiveTraceIngestRateFactor": 0.01}}
Optional Use the Settings API - GET effective values endpoint to verify the updated value of adaptiveTraceIngestRateFactor.
Use the Settings API - POST an object endpoint to create a new settings object. Use the following configuration:
usableAdaptiveTraceVolumePercentage to 20.scope to environment, as this is an environment-wide setting.[{"schemaId": "builtin:global.trace.ingest.control","scope": "environment","value": {"usableAdaptiveTraceVolumePercentage": 20}}]
You should receive a successful response.
usableAdaptiveTraceVolumePercentage to 50.scope to environment, as this is an environment-wide setting.[{"schemaId": "builtin:global.trace.ingest.control","scope": "environment","value": {"usableAdaptiveTraceVolumePercentage": 50}}]
Usually not at all.
The shaping of traffic is accounted for transparently and done in a way that ensures statistical validity while capturing rare requests with high probability. All charts and analysis options show the total number of requests that your application processes with high statistical accuracy. You will not see a difference in charts or service call analysis data unless you're looking at a single distributed trace.
No, Adaptive Traffic Management focuses only on the number of traces. Neither service settings nor (global) request settings are modified by Adaptive Traffic Management. Depending on the capture rate and sampling, a low-volume or unique request might not be captured. Service settings such as request naming rules and key request settings will apply only to captured traces.
Yes, in a few cases, as service monitoring metrics are based on captured traces. The following are some known effects.
If the OneAgent capture rate is below 100%, sampling has been applied because the number of traces that can be captured by OneAgent has exceeded the Full-Stack included trace volume. There are several things you can do to increase the capture rate:
Verify what is currently being captured and reduce the rate for traces and requests of lower relevance. Start by looking at the following:
Excessive custom services
Custom services with poor configurations can lead to a high number of requests and increase the trace ingress volume. If custom services are consuming a considerable amount of the trace volume, revisit the configuration to reduce the number of captured custom service calls.
Background activity services
In certain environments, background activity produces a lot of service calls but adds little value. To disable this feature on an environment-wide level, go to Settings > OneAgent features, and turn off Background Requests for Services (HTTP/GRPC) and Background Requests for Services (Messaging).
High number of low-value traces
In all environments, there are transactions for which traces are of lower value. You can exclude them from capture:
Data-heavy features
Data-heavy features can reduce the capture rate. You can:
Extend the trace ingest as a billed option on top of Full-Stack Monitoring. To learn more, see Extended trace ingest for Full-Stack Monitoring.
