Dynatrace Operator release notes version 1.8.0
  • Release notes
Release date: January 27, 2026
Minimum operator version required for direct upgrade: 1.4.0—see Upgrade from older versions. Review the release notes for each intermediate version and pay attention to breaking changes before upgrading.
Upgrade to 1.8.2
If you're running Dynatrace Operator version 1.8, we recommend upgrading to version 1.8.2 to receive the latest important patches.
Announcements
Dynatrace Operator version 1.8.0 requires additional deployment permissions compared to prior and future releases. The introduction of ClusterRole aggregation for Kubernetes monitoring means the deployer needs permissions to create aggregated ClusterRoles. This particularly affects tooling such as ArgoCD that manages workloads without cluster-admin permissions. For a full list of required deployment permissions, see Deployment permissions.
Dynatrace Operator version 1.8 introduces a new default and recommended DynaKube CRD version v1beta6. We encourage you to update your existing DynaKube resources to this latest version to take advantage of new features and enhancements.
Automatic OTLP exporter configuration for applications instrumented with OpenTelemetry
Dynatrace Operator can now automatically configure applications instrumented with OpenTelemetry to export traces, metrics and logs to Dynatrace via the OTLP exporter auto-configuration feature. This simplifies configuration management and helps ensuring consistent telemetry ingest across environments.
For configuration details and examples, see the OTLP auto-configuration guide.
New features and enhancements
  • We introduced improvements to the RBAC model used for Kubernetes monitoring via ActiveGate.
    • The dynatrace-kubernetes-monitoring ServiceAccount has been removed and replaced by the dynatrace-activegate ServiceAccount.
    • You can use Kubernetes ClusterRole aggregation to assign additional monitoring permissions to the dynatrace-activegate ServiceAccount during Operator installation. For details, see the ClusterRole aggregation documentation.
    • The dynatrace-kubernetes-monitoring ClusterRole uses Kubernetes ClusterRole aggregation to assign the required permissions to the ServiceAccount during Operator installation.
    • The ServiceAccount token is only mounted to the ActiveGate statefulset if necessary. ActiveGates that no longer require the token (e.g. routing‑only ActiveGates) are restarted after Operator upgrade to ensure no ServiceAccount token remains mounted.
    • Setting rbac.kspm.create: true now requires rbac.activeGate.create: true and rbac.kubernetesMonitoring.create: true. Be sure to adjust your Helm values if applicable before upgrading.
  • Dynatrace Operator now emits a Kubernetes warning event when the DynaKube or EdgeConnect CRD version is not the latest one supported by this Operator release. This makes it easier to identify outdated DynaKube CRD versions.
    • Dynatrace Operator RBAC permissions have been updated to include the events.patch permission for the dynatrace namespace.
  • The Dynatrace Operator now uses the CA certificates provided via .spec.caCertsRef in requests to the Dynatrace API when rolling out EdgeConnect.
  • The jobs the CSI driver creates for the node image pull feature now use the same PriorityClass as the CSI driver to ensure fast scheduling and allow preemption on congested nodes. The priority is configurable via the Helm value csidriver.priorityClassValue. For guidance, see Use priorityClass for critical Dynatrace components.
  • Specifying an image in .spec.templates.otelCollector.imageRef is now mandatory when telemetry ingest is enabled.
  • Use the new pod annotation dynatrace.com/split-mounts to avoid conflicts with application images that already contain a /var/lib/dynatrace directory. This annotation is mainly intended to allow code module injection in ActiveGate pods for deep monitoring. It is enabled by default on ActiveGates managed by Dynatrace Operator.
  • Dynatrace Operator components are made aware of pod memory limits by setting the environment variable GOMEMLIMIT. This will make them more resilient against OOM kills, because it optimizes the Go garbage collector behaviour. Memory limits are set to 90% of the limits configured for Operator components via Helm (e.g. csidriver.provisioner.resources.limts.memory, webhook.limits.memory). The values can be provided using IEC suffixes (e.g. 123Mi).
  • Namespaces selected for monitoring (matching the configured namespaceSelectors of metadataEnrichment or oneAgent) are written to the DynaKube conditions and to the operator log. This makes it easier to verify and troubleshoot the configured selectors.
  • Kubernetes cluster and node metadata (such as cluster name, cluster UID, and node name) is now automatically added (via initContainer named dynatrace-operator) to OneAgent resource attributes to improve topological insights and provide a consistent set of resource attributes on all signals, regardless of origin.
  • Detailed reasons for pod injection failures are now written to the oneagent.dynatrace.com/reason, metadata-enrichment.dynatrace.com/reason, and otlp-exporter-configuration.dynatrace.com/reason annotations on the affected pods. This makes troubleshooting pod injection issues faster and more transparent.
  • Dynatrace Operator managed ActiveGate now use a liveness probe to improve detection of broken states.
  • Default resource requirements for the jobs created by the CSI driver for the node image pull feature have been lowered. For guidance, see Set resource limits for Dynatrace Operator components
Resolved issues
  • Handling removed API versions during Dyntrace Operator upgrade
    Kubernetes records CRD versions in .status.storedVersions, but doesn’t remove entries when versions are deleted, so old versions accumulate and can block upgrades.
    In Dynatrace Operator 1.8.0 API versions v1beta1 and v1beta2 are removed from the Dynakube CRD. If you have been using Dynatrace operator < version 1.4.0 those versions are stored in the CRD in .status.storedVersions and require a clean up otherwise the upgrade to the new API version v1beta6 will fail. With Dynatrace Operator version 1.7.3 we introduced a two-step solution to ensure smooth upgrades.
    1. Helm hook for CRD cleanup
      Before the actual upgrade, a Helm hook starts a Kubernetes Job that erases obsolete API versions from the DynaKube CRD's status.storedVersions field. The job only keeps the latest API version that is available in the Dynatrace Operator version installed before the upgrade. This step ensures a smooth upgrade to the new CRD during the Helm upgrade process. See Dynatrace Operator security for information regarding required permissions.
    2. Dynatrace Operator startup migration
      After the upgrade was successful and the new Dynatrace Operator version 1.8.0 is operational, it migrates all existing DynaKubes to the latest supported API version v1beta6. After the DynaKube migration, the status.storedVersions field in the DynaKube CRD is updated to hold only the latest API version v1beta6 to ensure consistency.
Important notice for clusters that have been running Dynatrace Operator version 1.3 and earlier in the past
Clusters that have previously run Dynatrace Operator version 1.3 and earlier may have obsolete v1beta1 or v1beta2 entries in the DynaKube CRD's .status.storedVersions. These must be removed before upgrading to this release, or the CRD upgrade will fail.
Whether you need to stop at Dynatrace Operator version 1.7.3 first depends on your installation method:
  • Helm-based installation
    • Current version 1.4.0 and later—No action required. The Helm pre-upgrade hook automatically removes obsolete .status.storedVersions entries during the upgrade.
    • Current version 1.3 and earlier—You must upgrade to Dynatrace Operator 1.7.3 before upgrading to the next release.
  • Alternative installation methods (Red Hat OpenShift OperatorHub, OperatorHub.io, Google Marketplace, or plain Kubernetes manifests)
    • Never ran version 1.3 and earlier—No action required.
    • Previously ran version 1.3 and earlier—You must upgrade to Dynatrace Operator 1.7.3 before upgrading to the next release.
Manually remove obsolete entries from .status.storedVersions
Instead of upgrading to version 1.7.3, you can manually remove the obsolete entries from .status.storedVersions:
  1. List the stored versions in the CRD:
    kubectl -n dynatrace get crd dynakubes.dynatrace.com -o jsonpath='{.status.storedVersions}'
  2. Continue only if multiple versions are listed in the output. If only one version is listed, no action is required.
  3. Identify the currently active version:
    storage_version=$(kubectl get customresourcedefinitions dynakubes.dynatrace.com -o jsonpath='{.spec.versions[?(@.storage==true)].name}')
  4. Convert all DynaKubes to the active version:
    kubectl get dynakube -n dynatrace -o yaml | kubectl replace -f -
  5. Remove all previous versions while keeping the active version:
    kubectl patch customresourcedefinitions dynakubes.dynatrace.com --subresource='status' --type='merge' -p "{\"status\":{\"storedVersions\":[\"${storage_version}\"]}}"
Ensuring that .status.storedVersions is clean is crucial to avoid issues with future upgrades.
ArgoCD may display resources that are still using an old API version as "out-of-sync".
  • It is no longer possible to set codeModulesImage if the Dyntrace Operator CSI driver is disabled and neither applicationMonitoring nor cloudNativeFullStack is used. When attempting to do so, a validation error will be raised during DynaKube deployment or update.
  • The spec.templates.kspmNodeConfigurationCollector.nodeAffinity field is now correctly applied to the KSPM Node Configuration Collector DaemonSet.
  • KSPM DaemonSet now uses the built-in privileged SCC on OpenShift, eliminating the need for additional SCC configuration.
  • The Dynatrace OTel Collector is now configured to skip using a proxy to connect to the in-cluster ActiveGate or the Kubernetes API.
  • The cluster name used for the k8s.cluster.name attribute used for telemetry ingest now considers custom cluster names instead of only the DynaKube name.
  • subPath is no longer used for hostPath volumes to improve compatibility across Kubernetes distributions (including RKE):
    • The underlying host path structure remains unchanged. The former subPath value is now appended at the end of the hostPath.
  • There was an issue with the architecture of code modules images on ARM nodes. Default code modules images are now correctly downloaded.
  • When enabled, the CSI driver is now correctly installed if Dynatrace Operator is deployed from Google Marketplace.
  • Handle missing builtin:app-transition.kubernetes tenant settings object to support newer tenants that no longer have this object.
  • Reduced maximum DynaKube name length according to enabled features to prevent issues when deploying components. The following name length limits are now enforced:
    • 32 characters if spec.extensions is enabled
    • 35 characters if spec.kspm is enabled
    • 38 characters if spec.telemetryIngest is enabled.
    • Existing resources that violate these new validation rules will continue to work as before, but will need to be fixed if a change or update is desired.
  • Fixed an interoperability issue related to metadataEnrichment and classicFullstack. Now metadataEnrichment will work with classicFullstack. For more information, see Dynatrace Operator support and known issues.
  • Fixed a connectivity issue in Dynatrace Operator v1.7 that occurred between the OTLP exporter or CodeModules injected into application pods and the in‑cluster ActiveGate when the automatic-tls-certificate feature flag was switched from trueto false. Starting with Operator v1.8.0, the TLS certificate previously created for the in‑cluster ActiveGate is automatically removed from injected namespaces when automatic-tls-certificate is disabled.
  • Changed mount point of EdgeConnect custom CA certificates to prevent overwriting well-known trusted CAs. Previous versions of the operator require including CA certs for public Dynatrace endpoints in the ConfigMap if EdgeConnect .spec.caCertsRef is set.
Known issues
  • Dynatrace Operator 1.8.0 is unable to establish Kubernetes monitoring when installed through OLM (Operator Lifecycle Manager) via OperatorHub. The Operator relies on aggregated ClusterRoles and their corresponding ClusterRoleBindings to set up the required permissions for Kubernetes monitoring. Since aggregated ClusterRoles are empty at build time (their rules are populated at runtime via aggregationRules), OLM incorrectly identifies them as empty and removes both the ClusterRole and ClusterRoleBinding manifests during installation. As a result, the necessary permissions are never granted, and Kubernetes monitoring cannot be established. This issue has been fixed in Dynatrace Operator 1.8.1, upgrading is strongly recommended.
  • RBAC for Kubernetes monitoring requires elevated permissions to deploy the aggregated ClusterRole. This affects tooling, like ArgoCD, that manages workloads without cluster-admin permissions.
Removal and deprecation notices
  • Support for Kubernetes 1.27 ended in July 2025. As a result, Dynatrace Operator 1.8.0+ will no longer support this version.
  • The dynatrace-kubernetes-monitoring ServiceAccount will no longer exist. Instead, an aggregate ClusterRole is now bound to the dynatrace-activegate ServiceAccount, which will be used for Kubernetes monitoring permissions from this version onward. For more information, see the ClusterRole aggregation documentation.
  • If you have participated in the Kubernetes Enhanced Object Visibility Preview and also unlocked monitoring of the sensitive Kubernetes objects ConfigMaps and Secrets, we recommend the following cleanup step, after upgrading to Operator 1.8.0:
    kubectl delete ClusterRoleBinding/dynatrace-kubernetes-monitoring-sensitive
    Details: Dynatrace Operator 1.8.0 uses aggregationRules to merge permissions from different ClusterRoles. This makes the ClusterRoleBinding dynatrace-kubernetes-monitoring-sensitive obsolete, which can safely be deleted after upgrading to Operator 1.8.0.
  • The Helm repository located in dynatrace/helm-charts is archived and no longer receives updates. If you still install or upgrade Dynatrace Operator from it, switch to the OCI registry:
    helm upgrade dynatrace-operator oci://public.ecr.aws/dynatrace/dynatrace-operator \
    --version <version> \
    --namespace dynatrace \
    --reset-then-reuse-values \
    --install
    If you can't use OCI, point your Helm repository to dynatrace/dynatrace-operator instead:
    helm repo remove dynatrace
    helm repo add dynatrace https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/main/config/helm/repos/stable
    For details, see Migrate from the legacy Helm repository.
  • To prevent potential disruptions, we strongly advise keeping your DynaKube API version up to date. Once a version is deprecated and removed, updates may become significantly more complex and time-sensitive.
    • More information about the deprecation process of the DynaKube API versions can be found in the migration guide.
  • CSI sidecar binaries, located in /usr/local/bin/csi-node-driver-registrar and /usr/local/bin/livenessprobe, along with the Helm chart flags csidriver.registrar.builtIn and csidriver.livenessprobe.builtIn have been removed (deprecated in v1.7.0). The CSI driver pods will now always use the built-in implementations of livenessprobe and CSI node driver registrar. Customers who previously set these flags to false may observe a change in behavior. The purpose of this change is to minimize vulnerabilities in the Dynatrace Operator by ensuring prompt updates of these components.
  • The OneAgent autoUpdate field has been removed. Automatic updates now follow your tenant's configured target version. To disable automatic updates, set either the version or image field in the DynaKube CR.
  • The “Mark for Termination” event is deprecated and will be removed in a future Operator version. This functionality is now redundant, as it has been superseded by host availability events on host shutdown and reboot introduced in OneAgent version 1.301.
Upgrade from Dynatrace Operator version 1.7
  • Deprecated DynaKube API versions v1beta1 and v1beta2 have been removed from the DynaKube CRD schema.
  • DynaKube API version v1beta3 is no longer served and will be removed in a future Dynatrace Operator release. See: Migration guide for DynaKube API versions
  • Upgrading Dynatrace Operator may restart the ActiveGate, the OneAgent DaemonSet (host agent), and Log Monitoring DaemonSet.
  • If you are monitoring Kubernetes through the public Kubernetes API from within an in-cluster ActiveGate, you will need to recreate the bearer token because the name of the used ServiceAccount changed from dynatrace-kubernetes-monitoring to dynatrace-activegate. Follow the instructions at Connect to the public Kubernetes API.
  • Due to the aformentioned changes to the ActiveGate RBAC objects, setting rbac.kspm.create: true now requires rbac.activeGate.create: true and rbac.kubernetesMonitoring.create: true. Be sure to adjust your Helm values if applicable before upgrading.
