Enable Dynatrace telemetry ingest endpoints
Dynatrace Operator version 1.6+
Enable Dynatrace telemetry endpoints in Kubernetes for cluster-local data ingest.
  • Ingest data via OTLP, Jaeger, StatsD or Zipkin endpoints
  • Analyze context-rich data with built-in apps, DQL, Notebooks and Dashboards
Prerequisites
  • The data ingest token requires the token scopes openTelemetryTrace.ingest, logs.ingest, and metrics.ingest and must be provided via the dataIngestToken field in the same secret as your API token.
Setup and Use
The following two steps explain how to setup and use telemetry ingest endpoints.
Kubernetes App onboarding
If you got your DynaKube from the onboarding screen of the Dynatrace Kubernetes App the telemetry ingest service name will be set to telemetry-ingest.dynatrace. See Customize the name of the telemetry ingest service to change it.
1. Create DynaKube
To enable telemetry ingest endpoints, specify a list of desired protocols in the DynaKube field .spec.telemetryIngest.protocols. Please find more information about the exact values in our DynaKube reference documentation.
Data routing
With an ActiveGate running in the Kubernetes cluster, the OpenTelemetry Collector will be configured to route all ingested data through the in-cluster ActiveGate instead of connecting directly to a public ActiveGate. Additionally, the capabilities required for telemetry ingest will automatically be enabled.
If no in-cluster ActiveGate is deployed (i.e., .spec.activeGate is not specified), the OpenTelemetry Collector will be configured to communicate directly with your Dynatrace tenant.
apiVersion: dynatrace.com/v1beta5
kind: DynaKube
metadata:
namespace: dynatrace
spec:
apiUrl: https://ENVIRONMENTID.live.dynatrace.com/api
activeGate:
capabilities:
- kubernetes-monitoring
replicas: 1
resources:
requests:
cpu: 500m
memory: 1.5Gi
limits:
cpu: 1000m
memory: 1.5Gi
telemetryIngest:
protocols:
- jaeger
- zipkin
- otlp
- statsd
templates:
otelCollector:
imageRef:
repository: public.ecr.aws/dynatrace/dynatrace-otel-collector
tag: <tag>
OTel collector image
OTel collector image is sourced from our supported public registries, make sure the used tag exists! Alternatively, you can use your private registry.
2. Configure applications
Once the DynaKube is applied, the Dynatrace Operator will deploy the Dynatrace OpenTelemetry Collector with the default image (configurable using .spec.templates.otelCollector.imageRef) and a Kubernetes service named <dynakube-name>-telemetry-ingest.dynatrace (configurable using .spec.telemetryIngest.serviceName) for telemetry ingest. The used port number depends on the protocol your application supports. To find the respective port numbers, please see the reference below.
The following snippet shows how you can configure an application using an environment variable that is instrumented with the OpenTelemetry SDK:
env:
- name: OTEL_EXPORTER_OTLP_ENDPOINT
value: http://<dynakube-name>-telemetry-ingest.dynatrace:4317
Ports reference
The following ports are open for telemetry data ingestion:
NameProtocolPort
OTLP GRPC
TCP
4317
OTLP HTTP
TCP
4318
Zipkin
TCP
9411
Jaeger GRPC
TCP
14250
Jaeger Thrift Binary
UDP
6832
Jaeger Thrift Compact
UDP
6831
Jaeger Thrift HTTP
TCP
14268
StatsD
UDP
8125
Additional configurations
Use HTTPS endpoints
By default, the ingest endpoints operate in HTTP mode. If you want to encrypt the telemetry traffic by using HTTPS, you can reference a Kubernetes TLS secret via .spec.telemetryIngest.tlsRefName. The ingest endpoints will then be configured to use referenced certificates and listen for HTTPS.
Example for an OpenTelemetry instrumented application using HTTPS
The following snippet shows how you can configure an application that is instrumented with the OpenTelemetry SDK through the environment variable:
env:
value: https://<dynakube-name>-telemetry-ingest.dynatrace:4318
By default, the service name for telemetry ingest is <dynakube-name>-telemetry-ingest.dynatrace, but it can be customized by setting .spec.telemetryIngest.serviceName. The provided value will be used as a service name, but the services will still be in the namespace of the DynaKube, which is where also the Dynatrace OpenTelemetry Collector is deployed.
Be aware that having multiple DynaKubes with the same service name will cause service name collisions.
For example, if you set .spec.telemetryIngest.serviceName to my-telemetry-ingest, the endpoints are available at http://my-telemetry-ingest.dynatrace:4318.
Example
kind: DynaKube
metadata:
spec:
telemetryIngest:
serviceName: my-telemetry-ingest
protocols:
- jaeger
- zipkin
- otlp
- statsd
templates:
otelCollector:
imageRef:
tag: <tag>
Proxy settings
Any proxy specified in .spec.proxy will be propagated to the OpenTelemetry Collector via environment variables HTTP_PROXY and HTTPS_PROXY. If an in-cluster ActiveGate is used, the URL of the in-cluster ActiveGate will automatically be added to the NO_PROXY environment variable to avoid unnecessary communication loops.
Trusted CAs
If you need to use certificates for proxy communication, they can be specified in .spec.trustedCAs. System CAs from the OpenTelemetry Collector container image are loaded together with CAs in trustedCAs. The system CAs contain the certificates required for communication with public ActiveGates.
ActiveGate persistent storage
When telemetry ingest is used with an in-cluster ActiveGate, ingested data is buffered on a PersistentVolume on the ActiveGate until data has been transfered successfully. For this purpose, a PersistentVolumeClaim is mounted to the ActiveGate. The following example illustrates the default PVC configured to the ActiveGate by the operator if no custom PVC is specified:
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
Default storage class
Please ensure a default storage class is defined. Otherwise, the PersistentVolumeClaim of the ActiveGate cannot be provisioned.
A custom PersistentVolumeClaim can be configured in .spec.activegate.volumeClaimTemplate.
Ephemeral volume
For test purposes, a PVC can be replaced by local ephemeral storage using .spec.activeGate.useEphemeralVolume.
Using .spec.activeGate.useEphemeralVolume is not recommended for production environments.
ActiveGate time for shutdown
If an ActiveGate is shut down (for example, in scale-in scenarios), it needs some time to flush its buffers by sending all the buffered data to Dynatrace. In large environments, this can take some time and Kubernetes could potentially terminate the ActiveGate too early. To expand the so-called termination grace period, you can increase the duration via '.spec.activegate.terminationGracePeriodSeconds' to give the ActiveGate pod more time to gracefully shut down.
Related topics
  • DynaKube parameters for Dynatrace Operator
