Hardware requirements
  • Reference
  • 7-min read
Review the hardware requirements before installing Dynatrace Managed. Exact sizing of a Managed Cluster is not always possible, especially in environments with growing traffic. While upfront analysis is useful, it's more important to be able to add capacity as your monitoring needs increase. Plan to scale along these dimensions:
  • Horizontally — add more nodes. Up to 30 cluster nodes are supported.
  • Vertically — add more RAM or CPU per node.
  • Storage — use resizable disk volumes (see Storage recommendations below).
A minimum 3-node cluster is required for production environments to ensure reliability and data redundancy. For details, see Multi-node installations.
The hardware requirements in the following tables are estimates based on typical environments and load patterns. Individual environments may vary. Column definitions:
  • Minimum node specifications — CPU and RAM must be exclusively available for Dynatrace. Disable CPU power-saving mode. CPUs must run at 2 GHz or faster; hosts must have at least 32 GB RAM.
  • Transaction Storage — distributed across all nodes, not stored redundantly. In multi-node clusters, the total transaction storage is divided by the number of nodes.
  • Long-term Metrics Store — in multi-node installations, three copies of the metrics store are saved. For four or more nodes, the per-node storage requirement decreases.
    Keep the Long-term Metrics Store below 2 TB per node. Stability and operational resilience are ensured up to 4 TB per node. Persistent storage growth degrades cluster performance, resilience, and availability, and causes issues when adding nodes. If more storage is needed, add another node to reduce the per-node requirement.
Dynatrace Managed
Node TypeMax host units1
monitored
(per node)
Peak user
actions/min
(per node)
Min node
specifications
Disk IOPS
(per node)
Transaction Storage
(10 days code visibility)
Long-term
Metrics Store
(per node)
Elasticsearch
(per node)
(35 days retention)
Micro
50
1000
4 vCPUs,
32 GB RAM2
500
50 GB
100 GB
50 GB
Small
300
10000
8 vCPUs,
64 GB RAM
3000
300 GB
500 GB
500 GB
Medium
600
25000
16 vCPUs,
128 GB RAM
5000
600 GB
1 TB
1.5 TB
Large
1250
50000
32 vCPUs,
256 GB RAM
7500
1 TB
2 TB
1.5 TB
XLarge3
2500
100000
64 vCPUs,
512 GB RAM
10000
2 TB
4 TB
3 TB
1
The size of a host for licensing purposes (based on the amount of RAM provided by a host). The size of a host (in other words, the number of host units that a host is comprised of for consumption calculations) is based on the number of GBs of RAM available on the host server. The advantage of this approach is its simplicity; technology-specific factors are not taken into consideration (for example, the number of JVMs or the number of microservices that are hosted on a server). It doesn't matter if a host is .NET-based, Java-based, or something else. You can have 10 JVMs or 1,000 JVMs; such factors don't affect the amount of monitoring that an environment consumes. For full details, see Application and Infrastructure Monitoring (Host Units).
2
See RAM requirements in Log Monitoring recommendations.
3
While Dynatrace Managed runs resiliently on instances with 1 TB+ RAM/128 cores (2XLarge) and allows you to monitor more entities, it's not the optimal way of utilizing the hardware. Instead, we recommend that you use smaller instances (Large or XLarge).
Examples
  • To monitor up to 7,500 host units with a peak load of 300,000 user actions per minute, you need 3 XLarge nodes with 9 TB storage each, split across storage types.
  • To monitor 500 host units with a peak load of 25,000 user actions per minute, you need 3 Small nodes with 1.3 TB storage each, split across storage types.
Dynatrace Managed Premium High Availability
monitored
(per node)
Peak user
actions/min
(per node)
Min node
specifications
Disk IOPS
(per node)
Transaction Storage
Long-term
Metrics Store
(per node)
Elasticsearch
(per node)
(35 days retention)
Large
600
25000
32 vCPUs,
256 GB RAM
7500
1 TB
2 TB
1.5 TB
XLarge1
1250
50000
64 vCPUs,
512 GB RAM
10000
2 TB
4 TB
3 TB
1
Example
To monitor 7,500 host units with a peak load of 300,000 user actions per minute in a Premium High Availability deployment, you need 6 XLarge nodes — 3 nodes in one data center and 3 in a second, each with 9 TB storage split across storage types.
Storage requirements
Dynatrace Managed stores multiple types of monitoring data. Recommendations:
  • Store Dynatrace binaries and the data store on separate mount points so the data store can be resized independently.
  • Do not store Dynatrace data on the root volume to avoid complexity when resizing later.
  • Exclude data storage paths from antivirus scanning to prevent data consistency issues.
  • Mount different types of data storage on separate disk volumes for maximum flexibility and performance.
  • Use resizable disk partitions, for example with Logical Volume Manager (LVM).
  • Use the same partition size on all cluster nodes.
Disk size can vary depending on usage. For example, in a 2-node cluster where each node has 10 TB and transaction storage on both nodes is only 1.5 TB, a third node needs a minimum of 1 TB: (1.5 TB + 1.5 TB) / 3 = 1 TB. In a similar cluster where disks are 9 TB full, a third node needs a minimum of 6 TB: (9 TB + 9 TB) / 3 = 6 TB.
Anything below the calculated minimum is a misconfiguration. Note that multiple data sources — such as Session Replay — contribute to disk usage and can also trigger a misconfiguration.
File system requirements
Dynatrace Managed works with all common file systems. Use fast local storage suitable for database workloads. Dynatrace Managed also supports encrypted file systems, provided that disk IOPS meet the requirements and encryption is transparent at the operating system level (for example, Amazon EBS or Azure Storage encryption).
  • High-latency remote volumes such as NFS or CIFS are not supported for primary storage; NFS is sufficient for backups only.
  • Amazon Elastic File System (EFS) is not supported as primary storage for Elasticsearch, because it may lead to index corruption.
Log Monitoring requirements
Requirements for Log Monitoring Classic:
  • All cluster nodes must have at least 64 GB total RAM.
Additional recommendations:
  • Add more cluster nodes rather than increasing hardware per node for a more resilient configuration.
  • Distribute additional Elasticsearch storage equally across all cluster nodes.
  • When adding CPUs or RAM, keep all nodes equally sized.
  • Update the cluster ingest limit via Cluster Management Console or REST API whenever cluster hardware changes.
    1. To do so, log in to the Cluster Management Console.
    2. Go to Environments, select your environment, and adjust the limit in Cluster overload prevention settings.
A minimum 3-node cluster is required for production environments to ensure reliability and data redundancy. All nodes in a multi-node cluster must:
  • Have the same hardware configuration
  • Be synchronized with NTP
  • Be in the same time zone
  • Communicate over a private network on the required ports
  • Have a network latency between nodes of 10 ms or less
  • Have Dynatrace Managed system users with identical UID:GID identifiers across all nodes
