Remote environments API - DELETE a remote environment configuration
  • Reference
  • Published Nov 19, 2019
This API is deprecated. Use the Settings API instead. Look for the Remote environment (builtin:remote.environment) schema.
Deletes the specified remote environment configuration.
DELETEManagedDynatrace for Governmenthttps://{your-domain}/e/{your-environment-id}/api/config/v1/remoteEnvironments/{id}
DELETEEnvironment ActiveGatehttps://{your-activegate-domain}/e/{your-environment-id}/api/config/v1/remoteEnvironments/{id}
Authentication
Api-Token:
To execute this request, you need an access token with WriteConfig scope.
To learn how to obtain and use it, see Personal access tokens.
Parameters
ParameterTypeDescriptionInRequired
idstring
The ID of the configuration to be deleted.
pathRequired
Response
Response codes
CodeDescription
204
Success. The configuration has been deleted. The response doesn't have a body.
Example
In this example, the request deletes the Pre-Production remote environment created in the POST request example. The response code of 204 indicates that the deletion was successful.
The API token is passed in the Authorization header.
Curl
curl -X DELETE \
https://mySampleEnv.live.dynatrace.com/api/config/v1/remoteEnvironments/c89b9d9f-8c59-4c5b-b7ef-1a082d11e9ba \
-H 'Authorization: Api-token abcdefghij1234567890'
Request URL
Response code
204
