Remote environments API - POST a remote environment configuration
  • Reference
  • Published Nov 19, 2019
This API is deprecated. Use the Settings API instead. Look for the Remote environment (builtin:remote.environment) schema.
Creates a new remote environment configuration.
Before creation, Dynatrace verifies the provided URI and token by trying to reach the environment using the token for authentication. If the attempt fails, no remote environment configuration is created.
The request consumes and produces an application/json payload.
POSTManagedDynatrace for Governmenthttps://{your-domain}/e/{your-environment-id}/api/config/v1/remoteEnvironments
POSTEnvironment ActiveGatehttps://{your-activegate-domain}/e/{your-environment-id}/api/config/v1/remoteEnvironments
Authentication
Api-Token:
To execute this request, you need an access token with WriteConfig scope.
To learn how to obtain and use it, see Personal access tokens.
Parameters
The body must not provide an ID. An ID is assigned automatically by Dynatrace.
ParameterTypeDescriptionInRequired
bodyRemoteEnvironmentConfigDto
The JSON body of the request. Contains parameters of the new remote environment configuration.
bodyOptional
Request body objects
The RemoteEnvironmentConfigDto object
ElementTypeDescriptionRequired
displayNamestring
The display name of the remote environment.
Required
idstring
The ID of the configuration.
Optional
networkScopestring
The network scope of the remote environment:
  • EXTERNAL: The remote environment is located in an another network.
  • INTERNAL: The remote environment is located in the same network.
  • CLUSTER: The remote environment is located in the same cluster.
Dynatrace SaaS can only use EXTERNAL.
If not set, EXTERNAL is used.
The element can hold these values
  • CLUSTER
  • EXTERNAL
  • INTERNAL
Optional
tokenstring
The API token granting access to the remote environment.
The token must have the Fetch data from a remote environment (RestRequestForwarding) scope.
For security reasons, GET requests return this field as null.
Optional
uristring
The URI of the remote environment.
Required
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"displayName": "string",
"id": "string",
"networkScope": "EXTERNAL",
"token": "string",
"uri": "string"
Response
Response codes
CodeTypeDescription
201RemoteEnvironmentConfigStub
Success. A new remote environment configuration has been created. The response contains the ID of the new configuration.
400ErrorEnvelope
Failed. The input is invalid.
Response body objects
The RemoteEnvironmentConfigStub object
The short representation of a remote environment.
idstring-
namestring-
networkScopestring
  • CLUSTER
  • EXTERNAL
  • INTERNAL
uristring
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"id": "string",
"name": "string",
"networkScope": "CLUSTER",
"uri": "string"
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Validate payload
We recommend that you validate the payload before submitting it with an actual request. A response code of 204 indicates a valid payload.
The request consumes an application/json payload.
POSTManagedDynatrace for Governmenthttps://{your-domain}/e/{your-environment-id}/api/config/v1/remoteEnvironments/validator
POSTEnvironment ActiveGatehttps://{your-activegate-domain}/e/{your-environment-id}/api/config/v1/remoteEnvironments/validator
Authentication
Api-Token:
Response
Response codes
CodeTypeDescription
204-
Validated. The submitted configuration is valid. Response doesn't have a body
400ErrorEnvelope
errorError-
The Error object
codeinteger
messagestring
The error message
locationstring-
messagestring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
"error": {
"code": 1,
"path": "string"
"message": "string"
Example
In this example, the request creates a new remote environment configuration, referring to the Pre-Production environment.
The API token is passed in the Authorization header.
Curl
curl -X POST \
https://mySampleEnv.live.dynatrace.com/api/config/v1/remoteEnvironments/ \
-H 'Accept: application/json' \
-H 'Authorization: Api-Token dt0c01.abc123.abcdefjhij1234567890' \
-H 'Content-Type: application/json' \
-d '{
"displayName": "Pre-Production",
"uri": "https://preProd.live.dynatrace.com",
"token": "1234567890abcdefjhij",
Request URL
Request body
"uri": "https://PreProd.live.dynatrace.com",
"networkScope": "INTERNAL"
Response body
"id": "c89b9d9f-8c59-4c5b-b7ef-1a082d11e9ba",
"name": "Pre-Production",
Response code
201
