Dynatrace Operator release notes version 1.8.2
  • Latest Dynatrace
  • Release notes
Release date: October 28, 2026
This page provides an overview of the patches included in Dynatrace Operator version 1.8.2. For detailed information on new features and other enhancements, see the release notes for version 1.8.0.
Not available on marketplaces
Dynatrace Operator version 1.8.2 will not be published to OperatorHub or supported cloud marketplaces. If you installed from one of those, upgrade to version 1.11.1 to get these fixes.
Resolved issues
  • Fixed a security vulnerability (CVE-2026-111943) by updating the Go version used to build Dynatrace Operator to 1.26.10. The private keys of several intermediate certificate authorities (CAs) operated by eMudhra were compromised, which could allow an attacker to issue valid-looking certificates for any domain. Go 1.26.10 rejects TLS certificate chains that contain these intermediate CAs, so Dynatrace Operator no longer trusts certificates issued through them. We recommend that you upgrade to this version.
  • Pods for the CRD storage migration job are now excluded from code module injection (dynatrace.com/inject: "false"), matching the Operator, webhook, and CSI driver pods.
Upgrade Dynatrace Operator
Minimum operator version required for direct upgrade: 1.4.0
When upgrading, review the release notes and breaking changes section for each minor version between your current version and this version (1.8), not just this version itself. Skipping this step may cause you to miss a breaking change introduced in an intermediate release.
Direct upgrades from versions older than 1.4.0 are not supported. See Upgrade from older versions for further guidance.
Upgrade from Dynatrace Operator version 1.7
No additional migration steps are required beyond those described in the upgrade notes for version 1.8.0.
