Release date: January 27, 2026
Minimum operator version required for direct upgrade: 1.4.0—see Upgrade from older versions. Review the release notes for each intermediate version and pay attention to breaking changes before upgrading.
If you're running Dynatrace Operator version 1.8, we recommend upgrading to version 1.8.2 to receive the latest important patches.
Dynatrace Operator version 1.8.0 requires additional deployment permissions compared to prior and future releases. The introduction of ClusterRole aggregation for Kubernetes monitoring means the deployer needs permissions to create aggregated ClusterRoles. This particularly affects tooling such as ArgoCD that manages workloads without cluster-admin permissions. For a full list of required deployment permissions, see Deployment permissions.
Dynatrace Operator version 1.8 introduces a new default and recommended DynaKube CRD version v1beta6. We encourage you to update your existing DynaKube resources to this latest version to take advantage of new features and enhancements.
Dynatrace Operator can now automatically configure applications instrumented with OpenTelemetry to export traces, metrics and logs to Dynatrace via the OTLP exporter auto-configuration feature. This simplifies configuration management and helps ensuring consistent telemetry ingest across environments.
For configuration details and examples, see the OTLP auto-configuration guide.
dynatrace-kubernetes-monitoring ServiceAccount has been removed and replaced by the dynatrace-activegate ServiceAccount.dynatrace-activegate ServiceAccount during Operator installation. For details, see the ClusterRole aggregation documentation.dynatrace-kubernetes-monitoring ClusterRole uses Kubernetes ClusterRole aggregation to assign the required permissions to the ServiceAccount during Operator installation.rbac.kspm.create: true now requires rbac.activeGate.create: true and rbac.kubernetesMonitoring.create: true. Be sure to adjust your Helm values if applicable before upgrading.Dynatrace Operator now emits a Kubernetes warning event when the DynaKube or EdgeConnect CRD version is not the latest one supported by this Operator release. This makes it easier to identify outdated DynaKube CRD versions.
events.patch permission for the dynatrace namespace..spec.caCertsRef in requests to the Dynatrace API when rolling out EdgeConnect.csidriver.priorityClassValue. For guidance, see Use priorityClass for critical Dynatrace components..spec.templates.otelCollector.imageRef is now mandatory when telemetry ingest is enabled.dynatrace.com/split-mounts to avoid conflicts with application images that already contain a /var/lib/dynatrace directory. This annotation is mainly intended to allow code module injection in ActiveGate pods for deep monitoring. It is enabled by default on ActiveGates managed by Dynatrace Operator.GOMEMLIMIT. This will make them more resilient against OOM kills, because it optimizes the Go garbage collector behaviour. Memory limits are set to 90% of the limits configured for Operator components via Helm (e.g. csidriver.provisioner.resources.limts.memory, webhook.limits.memory). The values can be provided using IEC suffixes (e.g. 123Mi).namespaceSelectors of metadataEnrichment or oneAgent) are written to the DynaKube conditions and to the operator log. This makes it easier to verify and troubleshoot the configured selectors.dynatrace-operator) to OneAgent resource attributes to improve topological insights and provide a consistent set of resource attributes on all signals, regardless of origin.oneagent.dynatrace.com/reason, metadata-enrichment.dynatrace.com/reason, and otlp-exporter-configuration.dynatrace.com/reason annotations on the affected pods. This makes troubleshooting pod injection issues faster and more transparent.Handling removed API versions during Dyntrace Operator upgrade
Kubernetes records CRD versions in .status.storedVersions, but doesn’t remove entries when versions are deleted, so old versions accumulate and can block upgrades.
In Dynatrace Operator 1.8.0 API versions v1beta1 and v1beta2 are removed from the Dynakube CRD. If you have been using Dynatrace operator < version 1.4.0 those versions are stored in the CRD in .status.storedVersions and require a clean up otherwise the upgrade to the new API version v1beta6 will fail. With Dynatrace Operator version 1.7.3 we introduced a two-step solution to ensure smooth upgrades.
Helm hook for CRD cleanup
Before the actual upgrade, a Helm hook starts a Kubernetes Job that erases obsolete API versions from the DynaKube CRD's status.storedVersions field. The job only keeps the latest API version that is available in the Dynatrace Operator version installed before the upgrade. This step ensures a smooth upgrade to the new CRD during the Helm upgrade process. See Dynatrace Operator security for information regarding required permissions.
Dynatrace Operator startup migration
After the upgrade was successful and the new Dynatrace Operator version 1.8.0 is operational, it migrates all existing DynaKubes to the latest supported API version v1beta6. After the DynaKube migration, the status.storedVersions field in the DynaKube CRD is updated to hold only the latest API version v1beta6 to ensure consistency.
Clusters that have previously run Dynatrace Operator version 1.3 and earlier may have obsolete v1beta1 or v1beta2 entries in the DynaKube CRD's .status.storedVersions. These must be removed before upgrading to this release, or the CRD upgrade will fail.
Whether you need to stop at Dynatrace Operator version 1.7.3 first depends on your installation method:
Helm-based installation
.status.storedVersions entries during the upgrade.Alternative installation methods (Red Hat OpenShift OperatorHub, OperatorHub.io, Google Marketplace, or plain Kubernetes manifests)
.status.storedVersionsInstead of upgrading to version 1.7.3, you can manually remove the obsolete entries from .status.storedVersions:
List the stored versions in the CRD:
kubectl -n dynatrace get crd dynakubes.dynatrace.com -o jsonpath='{.status.storedVersions}'
Continue only if multiple versions are listed in the output. If only one version is listed, no action is required.
Identify the currently active version:
storage_version=$(kubectl get customresourcedefinitions dynakubes.dynatrace.com -o jsonpath='{.spec.versions[?(@.storage==true)].name}')
Convert all DynaKubes to the active version:
kubectl get dynakube -n dynatrace -o yaml | kubectl replace -f -
Remove all previous versions while keeping the active version:
kubectl patch customresourcedefinitions dynakubes.dynatrace.com --subresource='status' --type='merge' -p "{\"status\":{\"storedVersions\":[\"${storage_version}\"]}}"
Ensuring that .status.storedVersions is clean is crucial to avoid issues with future upgrades.
ArgoCD may display resources that are still using an old API version as "out-of-sync".
codeModulesImage if the Dyntrace Operator CSI driver is disabled and neither applicationMonitoring nor cloudNativeFullStack is used. When attempting to do so, a validation error will be raised during DynaKube deployment or update.spec.templates.kspmNodeConfigurationCollector.nodeAffinity field is now correctly applied to the KSPM Node Configuration Collector DaemonSet.privileged SCC on OpenShift, eliminating the need for additional SCC configuration.k8s.cluster.name attribute used for telemetry ingest now considers custom cluster names instead of only the DynaKube name.subPath is no longer used for hostPath volumes to improve compatibility across Kubernetes distributions (including RKE):
subPath value is now appended at the end of the hostPath.builtin:app-transition.kubernetes tenant settings object to support newer tenants that no longer have this object.spec.extensions is enabledspec.kspm is enabledspec.telemetryIngest is enabled.metadataEnrichment and classicFullstack. Now metadataEnrichment will work with classicFullstack. For more information, see Dynatrace Operator support and known issues.automatic-tls-certificate feature flag was switched from trueto false. Starting with Operator v1.8.0, the TLS certificate previously created for the in‑cluster ActiveGate is automatically removed from injected namespaces when automatic-tls-certificate is disabled..spec.caCertsRef is set.Dynatrace Operator 1.8.0 is unable to establish Kubernetes monitoring when installed through OLM (Operator Lifecycle Manager) via OperatorHub. The Operator relies on aggregated ClusterRoles and their corresponding ClusterRoleBindings to set up the required permissions for Kubernetes monitoring. Since aggregated ClusterRoles are empty at build time (their rules are populated at runtime via aggregationRules), OLM incorrectly identifies them as empty and removes both the ClusterRole and ClusterRoleBinding manifests during installation. As a result, the necessary permissions are never granted, and Kubernetes monitoring cannot be established. This issue has been fixed in Dynatrace Operator 1.8.1, upgrading is strongly recommended.
RBAC for Kubernetes monitoring requires elevated permissions to deploy the aggregated ClusterRole. This affects tooling, like ArgoCD, that manages workloads without cluster-admin permissions.
Support for Kubernetes 1.27 ended in July 2025. As a result, Dynatrace Operator 1.8.0+ will no longer support this version.
The dynatrace-kubernetes-monitoring ServiceAccount will no longer exist. Instead, an aggregate ClusterRole is now bound to the dynatrace-activegate ServiceAccount, which will be used for Kubernetes monitoring permissions from this version onward. For more information, see the ClusterRole aggregation documentation.
If you have participated in the Kubernetes Enhanced Object Visibility Preview and also unlocked monitoring of the sensitive Kubernetes objects ConfigMaps and Secrets, we recommend the following cleanup step, after upgrading to Operator 1.8.0:
kubectl delete ClusterRoleBinding/dynatrace-kubernetes-monitoring-sensitive
Details: Dynatrace Operator 1.8.0 uses aggregationRules to merge permissions from different ClusterRoles. This makes the ClusterRoleBinding dynatrace-kubernetes-monitoring-sensitive obsolete, which can safely be deleted after upgrading to Operator 1.8.0.
The Helm repository located in dynatrace/helm-charts is archived and no longer receives updates. If you still install or upgrade Dynatrace Operator from it, switch to the OCI registry:
helm upgrade dynatrace-operator oci://public.ecr.aws/dynatrace/dynatrace-operator \--version <version> \--namespace dynatrace \--reset-then-reuse-values \--install
If you can't use OCI, point your Helm repository to dynatrace/dynatrace-operator instead:
helm repo remove dynatracehelm repo add dynatrace https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/main/config/helm/repos/stable
For details, see Migrate from the legacy Helm repository.
/usr/local/bin/csi-node-driver-registrar and /usr/local/bin/livenessprobe, along with the Helm chart flags csidriver.registrar.builtIn and csidriver.livenessprobe.builtIn have been removed (deprecated in v1.7.0). The CSI driver pods will now always use the built-in implementations of livenessprobe and CSI node driver registrar. Customers who previously set these flags to false may observe a change in behavior. The purpose of this change is to minimize vulnerabilities in the Dynatrace Operator by ensuring prompt updates of these components.autoUpdate field has been removed. Automatic updates now follow your tenant's configured target version. To disable automatic updates, set either the version or image field in the DynaKube CR.Specifying an image in .spec.templates.otelCollector.imageRef is now mandatory when telemetry ingest is enabled.
Deprecated DynaKube API versions v1beta1 and v1beta2 have been removed from the DynaKube CRD schema.
DynaKube API version v1beta3 is no longer served and will be removed in a future Dynatrace Operator release. See: Migration guide for DynaKube API versions
Upgrading Dynatrace Operator may restart the ActiveGate, the OneAgent DaemonSet (host agent), and Log Monitoring DaemonSet.
If you are monitoring Kubernetes through the public Kubernetes API from within an in-cluster ActiveGate, you will need to recreate the bearer token because the name of the used ServiceAccount changed from dynatrace-kubernetes-monitoring to dynatrace-activegate. Follow the instructions at Connect to the public Kubernetes API.
Due to the aformentioned changes to the ActiveGate RBAC objects, setting rbac.kspm.create: true now requires rbac.activeGate.create: true and rbac.kubernetesMonitoring.create: true. Be sure to adjust your Helm values if applicable before upgrading.
