Release date: February 9, 2026
Minimum operator version required for direct upgrade: 1.4.0—see Upgrade from older versions. Review the release notes for each intermediate version and pay attention to breaking changes before upgrading.
This page provides an overview of the patches included in Dynatrace Operator version 1.8.1. For detailed information on new features and other enhancements, please refer to the release notes for version 1.8.
ActiveGate permissions on OperatorHub marketplace
Dynatrace Operator 1.8.1 now includes the RBAC resources that were previously missing for ClusterServiceVersion (CSV) based installations. The Dynatrace Operator bundle build process has been modified to overcome the CSV limitations regarding aggregated roles that caused this issue.
Limitation: The ClusterRoleBinding included in this fix is hard-coded to reference the dynatrace-activegate ServiceAccount in the dynatrace namespace. If you deploy the Dynatrace Operator in a different namespace, the required permissions for Kubernetes monitoring are not granted, resulting in the same behavior as version 1.8.0.
Log monitoring allowlist on GKE Autopilot
Fixed an issue with log monitoring on GKE Autopilot where the tenant suffix added to the HostPath for RKE support caused validation failures.
Removed Rancher Kubernetes Engine 1 (RKE1) from supported distributions.
The Helm repository located in dynatrace/helm-charts is archived and no longer receives updates. If you still install or upgrade Dynatrace Operator from it, switch to the OCI registry:
helm upgrade dynatrace-operator oci://public.ecr.aws/dynatrace/dynatrace-operator \--version <version> \--namespace dynatrace \--reset-then-reuse-values \--install
If you can't use OCI, point your Helm repository to dynatrace/dynatrace-operator instead:
helm repo remove dynatracehelm repo add dynatrace https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/main/config/helm/repos/stable
For details, see Migrate from the legacy Helm repository.
Specifying an image in .spec.templates.otelCollector.imageRef is now mandatory when telemetry ingest is enabled.
Deprecated DynaKube API versions v1beta1 and v1beta2 have been removed from the DynaKube CRD schema.
DynaKube API version v1beta3 is no longer served and will be removed in a future Dynatrace Operator release. See: Migration guide for DynaKube API versions
Upgrading Dynatrace Operator may restart the ActiveGate, the OneAgent DaemonSet (host agent), and Log Monitoring DaemonSet.
If you are monitoring Kubernetes through the public Kubernetes API from within an in-cluster ActiveGate, you will need to recreate the bearer token because the name of the used ServiceAccount changed from dynatrace-kubernetes-monitoring to dynatrace-activegate. Follow the instructions at Connect to the public Kubernetes API.
Due to the aformentioned changes to the ActiveGate RBAC objects, setting rbac.kspm.create: true now requires rbac.activeGate.create: true and rbac.kubernetesMonitoring.create: true. Be sure to adjust your Helm values if applicable before upgrading.
Clusters that have previously run Dynatrace Operator version 1.3 and earlier may have obsolete v1beta1 or v1beta2 entries in the DynaKube CRD's .status.storedVersions. These must be removed before upgrading to this release, or the CRD upgrade will fail.
Whether you need to stop at Dynatrace Operator version 1.7.3 first depends on your installation method:
Helm-based installation
.status.storedVersions entries during the upgrade.Alternative installation methods (Red Hat OpenShift OperatorHub, OperatorHub.io, Google Marketplace, or plain Kubernetes manifests)
.status.storedVersionsInstead of upgrading to version 1.7.3, you can manually remove the obsolete entries from .status.storedVersions:
List the stored versions in the CRD:
kubectl -n dynatrace get crd dynakubes.dynatrace.com -o jsonpath='{.status.storedVersions}'
Continue only if multiple versions are listed in the output. If only one version is listed, no action is required.
Identify the currently active version:
storage_version=$(kubectl get customresourcedefinitions dynakubes.dynatrace.com -o jsonpath='{.spec.versions[?(@.storage==true)].name}')
Convert all DynaKubes to the active version:
kubectl get dynakube -n dynatrace -o yaml | kubectl replace -f -
Remove all previous versions while keeping the active version:
kubectl patch customresourcedefinitions dynakubes.dynatrace.com --subresource='status' --type='merge' -p "{\"status\":{\"storedVersions\":[\"${storage_version}\"]}}"
Ensuring that .status.storedVersions is clean is crucial to avoid issues with future upgrades.
ArgoCD may display resources that are still using an old API version as "out-of-sync".
