Dynatrace Operator release notes version 1.7.4
  • Latest Dynatrace
  • Release notes
Release date: November 3, 2026
This page provides an overview of the patches included in Dynatrace Operator version 1.7.4. For detailed information on new features and other enhancements, see the release notes for version 1.7.0.
Not available on marketplaces
Dynatrace Operator version 1.7.4 will not be published to OperatorHub or supported cloud marketplaces. If you installed from one of those, upgrade to version 1.11.1 to get these fixes.
No FIPS-compliant image for this version
Dynatrace Operator version 1.7.4 isn't published as a FIPS-compliant image. If you need a FIPS-compliant image, upgrade to version 1.9.2 instead.
Resolved issues
  • Fixed a security vulnerability (CVE-2026-111943) by updating the Go version used to build Dynatrace Operator to 1.26.10. The private keys of several intermediate certificate authorities (CAs) operated by eMudhra were compromised, which could allow an attacker to issue valid-looking certificates for any domain. Go 1.26.10 rejects TLS certificate chains that contain these intermediate CAs, so Dynatrace Operator no longer trusts certificates issued through them. We recommend that you upgrade to this version.
  • Pods for the CRD storage migration job are now excluded from code module injection (dynatrace.com/inject: "false"), matching the Operator, webhook, and CSI driver pods.
Upgrade from Dynatrace Operator version 1.6
No additional migration steps are required beyond those described in the upgrade notes for version 1.7.0.
