Release date: October 22, 2026
This page provides an overview of the patches included in Dynatrace Operator version 1.9.2. For detailed information on new features and other enhancements, see the release notes for version 1.9.0.
Dynatrace Operator version 1.9.2 will not be published to OperatorHub or supported cloud marketplaces. If you installed from one of those, upgrade to version 1.11.1 to get this fix.
When upgrading, review the release notes and breaking changes section for each minor version between your current version and this version (1.9), not just this version itself. Skipping this step may cause you to miss a breaking change introduced in an intermediate release.
Direct upgrades from versions older than 1.5.0 are not supported. See Upgrade from older versions for further guidance.
No additional migration steps are required beyond those described in the upgrade notes for version 1.9.0.
