Dynatrace Operator release notes version 1.4.1
  • Latest Dynatrace
  • Release notes
Release date: Feb 12, 2025
Resolved issues
  • When Log Monitoring is activated, OneAgent containers now have the ServiceAccount token mounted, fixing the previous issue with accessing the Kubelet API.
  • The host path for Log Monitoring is now static (/tmp/dynatrace) and no longer includes the environment UUID, allowing for easier allowlisting on platforms like GKE Autopilot.
  • The base pod name is now passed to the Log Monitoring pod via an environment variable instead of the argument list (for example, -c k8s_basepodname gke-autopilot-my-cluster), resulting in a static argument string and resolving allowlisting issues on platforms like GKE Autopilot."
  • The k8s.workload.kind metadata enrichment attribute is now consistently lowercase across all annotations, environment variables, and the enrichment files, in line with the Dynatrace Semantic Dictionary.
  • From version 1.4.0, only one Dynatrace Operator manifest (kubernetes.yaml or kubernetes-csi.yaml) is needed for installation. The issue with the CSI Driver not enabling/disabling correctly when both manifests were applied sequentially, causing validation errors, has been fixed.
  • Image field validation in the Dynatrace Operator has been fixed to support URIs with IP addresses (for example, 127.0.0.1:5000/image:tag) and those pointing to the Dynatrace server registry, resolving previous errors in the validation webhook.
  • Custom arguments for the OneAgent (for example, .spec.oneAgent.cloudNativeFullstack.args) and default arguments set by the operator could cause argument duplications, leading to unwanted side effects. Now, except for --set-host-property and --set-host-tag, duplications are avoided, with custom arguments taking precedence.
    • Providing a custom argument (for example, --set-server) multiple times will cause a DynaKube to be rejected, except for --set-host-property and --set-host-tag.
    • Providing the same host tag multiple times (for example, --set-host-tag=tag1, --set-host-tag=tag1) will cause a DynaKube to be rejected."
  • The Dynatrace Operator support archive was corrupted, causing issues with some unzip utilities. This has been fixed.
  • Tenant tokens can be manually rotated using the Dynatrace API. Previously, this required a manual restart of the ActiveGate and OneAgent. Now, the restart is automatically initiated when a new tenant token is created.
    • Please be aware that monitored applications need to be restarted once token rotation has been initiated.
  • The OTLP_TOKEN environment variable is redundant and obsolete and is no longer applied to the OpenTelemetry Collector pod for extensions. The same token is available in the EEC_DS_TOKEN environment variable.
  • To prevent premature kills in the CSI driver, the timeout values of the liveness probe for the CSI driver have been increased.
  • The retryTimeout attribute on CSI volumes, which was previously enforced but unused, has been removed to prevent issues during Dynatrace Operator upgrades.
  • Dependencies have been updated to mitigate
    • CVE-2024-3154.
    • SNYK-GOLANG-GOLANGORGXNETHTML-8535262 (also known as CVE-2024-45338).
Upgrade from Dynatrace Operator version 1.4
Several features introduced in Dynatrace Operator version 1.4.0 rely on the Kubernetes monitoring capability:
  • Kubernetes Security Posture Management (.spec.kspm)
  • Log Monitoring (.spec.logMonitoring)
  • Extensions for Kubernetes (.spec.extensions)
To use these features, add kubernetes-monitoring to the capabilities list in the ActiveGate section (.spec.activeGate.capabilities) and ensure the feature flag feature.dynatrace.com/automatic-kubernetes-api-monitoring is not set to false.
Related tags
Dynatrace Platform
