Release date: October 15, 2026
Minimum operator version required for direct upgrade: 1.5.0—see Upgrade from older versions. Review the release notes for each intermediate version and pay attention to breaking changes before upgrading.
This page provides an overview of the patches included in Dynatrace Operator version 1.10.3. For detailed information on new features and other enhancements, see the release notes for version 1.10.0.
Since Dynatrace Operator 1.9.0, a RuntimeDefault seccomp profile is applied to the Dynatrace init container by default. On OpenShift, this can interfere with SecurityContextConstraints (SCCs) — such as anyuid, restricted, or nonroot — that prevent seccomp profile usage, causing the system to fall back to a different SCC (for example restricted-v2). This may render application pods unschedulable or cause workload degradation.
The Helm repository located in dynatrace/helm-charts is archived and no longer receives updates. If you still install or upgrade Dynatrace Operator from it, switch to the OCI registry:
helm upgrade dynatrace-operator oci://public.ecr.aws/dynatrace/dynatrace-operator \--version <version> \--namespace dynatrace \--reset-then-reuse-values \--install
If you can't use OCI, point your Helm repository to dynatrace/dynatrace-operator instead:
helm repo remove dynatracehelm repo add dynatrace https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/main/config/helm/repos/stable
For details, see Migrate from the legacy Helm repository.
operator.apparmor, webhook.apparmor, and csidriver.apparmor Helm values are deprecated. On Kubernetes version 1.31+, set AppArmor using appArmorProfile in the podSecurityContext instead. These values will continue to work until Kubernetes version 1.30 reaches end of life (August 2026). See Enable AppArmor for enhanced security for details.No additional migration steps are required beyond those described in the upgrade notes for version 1.10.0.
