Monitor the health and performance of your VMware vSphere infrastructure.
Use VMware to connect to the vCenter and gather metrics, events, and alerts about your vSphere clusters, ESXi hosts, virtual machines, datastores, and disks.
Use this extension to:
Differences in system time can lead to missing VMware metrics. For Dynatrace to properly display monitoring data, synchronize time settings on all monitored host environments and vCenters with an NTP server.
Active VMware vCenter
ActiveGate with EEC Performance Profile of High or Dedicated deployed on a Linux or Windows environment. For more information about the performance profiles, see Dedicated performance profile configuration.
When you use the dedicated performance profile, the REST Interface is disabled by default. To ingest vCenter Triggered Alarms and vCenter Custom Attributes & Tags, you need to manually turn on the REST Interface in the ActiveGate's custom.properties file by setting the following:
[collector]restInterface = true
ActiveGate connected to the vSphere
A user with read-only permissions in vSphere
This extension uses pyVmomi, the Python SDK for the VMware vSphere Management API.
pyVmomi has its own compatibility information. To learn more, see pyVmomi Compatibility Policy.
3.14.2 and below use pyvmomi==8.0.3.0.1.3.14.7+ use pyvmomi==9.0.0.0.The VMware vSphere platform has been deprecating some metrics. Metric availability may vary based on vSphere version.
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The VMware (remote monitoring) extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
This extension uses logs (for more information, see vSphere Events) and custom metrics.
If you are concerned about license usage due to the number of metrics collected and their potential cardinality in larger VMware vSphere deployments, contact your Dynatrace account team.
The amount of custom metrics will vary depending on the number of resources running in your vCenter, and the number of resources will naturally increase and decrease as resources are created and deleted.
Consider the average number of resources you will have deployed long-term.
With these values, the formula for datapoints used by the extension per minute is as follows:
(7 x <total number of clusters>) + (70 + (14 x <avg number of disks per host>) + (1 x <avg number of datastores per host>) + (5 x <avg number of NICs per host>)) * <number of hosts deployed> + (58 + (9 x <avg number of disks per VM) + (3 x <avg number of datastores per VM>) + (2 x <avg number of volumes per VM>) + (3 x <avg number of NICs per VM>)) * <number of VMs deployed> + (11 x <total number of datastores>)
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
For logs, regular consumption applies. See Log Analytics.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
For logs, regular DDU consumption applies. See DDU consumption for Log Management and Analytics or DDUs for Log Monitoring Classic.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
| Metric name | Metric key | Description |
| CPU Usage | vmware.vm.cpu.usage.average | CPU usage as a percentage during the interval |
| CPU Ready Percent | vmware.vm.cpu.ready.percent | Time that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval |
| CPU Ready | vmware.vm.cpu.ready.summation | Time that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval |
| CPU Swap Wait | vmware.vm.cpu.swapwait.summation | CPU time spent waiting for swap-in |
| CPU Usage in MHz | vmware.vm.cpu.usagemhz.maximum | CPU usage in megahertz during the interval |
| Disk Usage | vmware.vm.disk.usage.average | Aggregated disk I/O rate. For hosts, this metric includes the rates for all virtual machines running on the host during the collection interval. |
| VM Memory Used % (avg) | vmware.vm.mem.usage.average | Percentage of vm memory that has been consumed |
| Active Memory Used | vmware.vm.mem.active.average | Amount of guest physical memory that is being actively read or written by guest. Activeness is estimated by ESXi |
| Memory Compression Rate | vmware.vm.mem.compressionRate.average | Rate of guest physical memory page compression by ESXi |
| Memory Decompression Rate | vmware.vm.mem.decompressionRate.average | Rate of guest physical memory decompression |
| Memory Swap In Rate | vmware.vm.mem.swapinRate.average | Rate at which guest physical memory is swapped in from the swap space |
| Memory Swap Out Rate | vmware.vm.mem.swapoutRate.average | Rate at which guest physical memory is swapped out to the swap space |
| Data transmit rate | vmware.vm.net.transmitted.average | Rate at which data was transmitted during the interval |
| Data receive rate | vmware.vm.net.received.average | Rate at which data was received during the interval |
| Datastore Max Total Latency | vmware.vm.datastore.maxTotalLatency.latest | — |
| System Overall Status | vmware.host.overall.status | The overall alarm status of the host. 0=Green 1=Gray 2=Yellow 3=Red |
| Connection Status | vmware.host.connected.status | 0=Connected to the server. For ESX Server, this is always the setting. 1=The user has explicitly taken the host down. 2=Virtual Center is not receiving heartbeats from the server. |
| Power Status | vmware.host.powered.status | The host power state. See the description in the enums for the PowerState data object type. 0=The host is powered on. A host that is entering standby mode entering is also in this state. 1=The host was specifically put in standby mode, either explicitly by the user, or automatically by DPM. 2=The host was specifically powered off by the user through VirtualCenter. 3=The host is disconnected, or notResponding, we can't have knowledge of its power state |
| Host License Expiration Time | vmware.host.license.expiration | Time until the license expires on this host |
| Memory Granted (max) | vmware.host.mem.granted.maximum | Amount of host physical memory or physical memory that is mapped for a virtual machine or a host |
| Ballooned memory (max) | vmware.host.mem.vmmemctl.maximum | Amount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest |
| Memory cache consumed (max) | vmware.host.mem.llSwapUsed.maximum | Storage space consumed on the host swap cache for storing swapped guest physical memory pages |
| Memory Swap In (max) | vmware.host.mem.swapIn.maximum | — |
| Memory Swap Out (max) | vmware.host.mem.swapOut.maximum | — |
| Memory Consumed (Max) | vmware.host.mem.consumed.maximum | — |
| Memory Active (Max) | vmware.host.mem.active.maximum | — |
| CPU Usage | vmware.vm.cpu.usage.maximum | CPU usage as a percentage during the interval |
| CPU Max Usage | vmware.vm.cpu.max_usage | Current upper-bound on CPU usage |
| VM CPU Reservation | vmware.vm.reservation.cpu | — |
| VM Memory Reservation | vmware.vm.reservation.memory | — |
| — | vmware.info.datastore_relations | — |
| Memory Consumed (max) % | vmware.host.mem.usage.maximum | Percentage of host physical memory that has been consumed |
| VM CPU Cores | vmware.vm.cpu.num_cores | — |
| VM Memory Size | vmware.vm.mem.size | — |
| Memory Swap In Rate | vmware.host.mem.swapinRate.average | Rate at which guest physical memory is swapped in from the swap space |
| Memory Swap Out Rate | vmware.host.mem.swapoutRate.average | Rate at which guest physical memory is swapped out to the swap space |
| Memory Granted (avg) | vmware.host.mem.granted.average | Amount of host physical memory or physical memory that is mapped for a virtual machine or a host |
| Ballooned memory (avg) | vmware.host.mem.vmmemctl.average | Amount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest |
| Memory cache consumed (avg) | vmware.host.mem.llSwapUsed.average | Storage space consumed on the host swap cache for storing swapped guest physical memory pages |
| Memory Latency | vmware.host.mem.latency.average | Percentage of time the virtual machine spent waiting to swap in or decompress guest physical memory |
| Memory Capacity Contention | vmware.host.mem.capacity.contention.average | Percentage of time VMs are waiting to access swapped, compressed or ballooned memory |
| Datastore Capacity | vmware.datastore.capacity | — |
| Datastore Free Space | vmware.datastore.freeSpace | — |
| Average Read Requests (per second) | vmware.datastore.datastore.numberReadAveraged.average | Average number of read commands issued per second to the datastore during the collection interval |
| Average Write Requests (per second) | vmware.datastore.datastore.numberWriteAveraged.average | Average number of write commands issued per second to the datastore during the collection interval |
| Read Rate | vmware.datastore.datastore.read.average | Rate of reading data from the datastore |
| Write Rate | vmware.datastore.datastore.write.average | Rate of writing data to the datastore |
| Throughput Usage | vmware.datastore.datastore.throughput.usage.average | Datastore Throughput Usage |
| Throughput Contention | vmware.datastore.datastore.throughput.contention.average | Datastore Throughput Contention |
| Datastore Uncommitted | vmware.datastore.uncommitted | — |
| Disk Provisioned | vmware.datastore.disk.provisioned.latest | Amount of storage set aside for use by a datastore or a virtual machine |
| Guest Heartbeat Status | vmware.vm.guest.status | The guest heartbeat. The heartbeat status is classified as: 0=Green : Guest operating system is responding normally. 1=Gray : VMware Tools are not installed or not running. 2=Yellow : Intermittent heartbeat. May be due to guest load. 3=Red : No heartbeat. Guest operating system may have stopped responding. |
| Power Status | vmware.vm.power.status | Current power state of the virtual machine. Status Codes: 0=Powered On 1=Suspended 2=Powered Off |
| Fault Tolerance Status | vmware.vm.fault.tolerance.status | The fault tolerance state of the VM. 0 = Enabled, 1 = Starting, 2 = notConfigured, 3 = Running, 4 = Disabled, 5 = needSecondary |
| Consolation Needed | vmware.vm.consolidation.needed | Indicates whether a disk associated with the virtual machine requires consolidation. Status codes: 0=false 1=true |
| Memory Granted | vmware.vm.mem.granted.maximum | Amount of host physical memory or physical memory that is mapped for a virtual machine or a host |
| Ballooned memory | vmware.vm.mem.vmmemctl.maximum | Amount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest |
| Memory Consumed | vmware.vm.mem.consumed.maximum | Amount of host physical memory consumed for backing up guest physical memory pages |
| VM Memory Used % (max) | vmware.vm.mem.usage.maximum | Percentage of vm memory that has been consumed |
| Memory Max Usage | vmware.vm.mem.max_usage | Current upper-bound on memory usage. |
| Total CPU Processors | vmware.cluster.cpu.cores | — |
| Cluster CPU Capacity | vmware.cluster.cpu.capacity | — |
| Cluster CPU Used | vmware.cluster.cpu.used | — |
| Cluster Memory Capacity | vmware.cluster.mem.capacity | — |
| Cluster Memory Used | vmware.cluster.mem.used | — |
| Cluster Storage Capacity | vmware.cluster.storage.capacity | — |
| Cluster Storage Used | vmware.cluster.storage.used | — |
| CPU Usage | vmware.host.cpu.usage.average | CPU usage as a percentage during the interval |
| Disk I/O Rate | vmware.host.disk.usage.average | Aggregated disk I/O rate. For hosts, this metric includes the rates for all virtual machines running on the host during the collection interval. |
| Disk Bus Resets | vmware.host.disk.busResets.summation.count | Number of SCSI-bus reset commands issued during the collection interval |
| Disk Commands | vmware.host.disk.commands.summation | Number of SCSI commands issued during the collection interval |
| Disk Commands Aborted | vmware.host.disk.commandsAborted.summation | Number of SCSI commands aborted during the collection interval |
| Queue Command Latency | vmware.host.disk.queueLatency.average | Average amount of time spent in the VMkernel queue, per SCSI command, during the collection interval |
| Disk Read Requests | vmware.host.disk.numberRead.summation | Number of disk reads during the collection interval |
| Disk Write Requests | vmware.host.disk.numberWrite.summation | Number of disk writes during the collection interval |
| Disk Read Rate | vmware.host.disk.read.average | Average number of kilobytes read from the disk each second during the collection interval |
| Disk Write Rate | vmware.host.disk.write.average | Average number of kilobytes written to disk each second during the collection interval |
| Read Latency | vmware.host.disk.totalReadLatency.average | Average amount of time taken during the collection interval to process a SCSI read command issued from the guest OS to the virtual machine |
| Write latency | vmware.host.disk.totalWriteLatency.average | Average amount of time taken during the collection interval to process a SCSI write command issued by the guest OS to the virtual machine |
| Memory Compression Rate | vmware.host.mem.compressionRate.average | Rate of guest physical memory page compression by ESXi |
| Memory Decompression Rate | vmware.host.mem.decompressionRate.average | Rate of guest physical memory decompression |
| Host Memory Consumed % | vmware.host.mem.usage.average | Percentage of host physical memory that has been consumed |
| Memory Active (Avg) | vmware.host.mem.active.average | — |
| Memory Consumed (Avg) | vmware.host.mem.consumed.average | — |
| Memory Swap In (avg) | vmware.host.mem.swapIn.average | — |
| Memory Swap Out (avg) | vmware.host.mem.swapOut.average | — |
| Network Usage | vmware.host.net.usage.average | Network utilization (combined transmit-rates and receive-rates) during the interval |
| Data transmit rate | vmware.host.net.transmitted.average | Rate at which data was transmitted during the interval |
| Data receive rate | vmware.host.net.received.average | Rate at which data was received during the interval |
| Data Receive Rate | vmware.host.net.bytesRx.average | Average amount of data received per second |
| Data Transmit Rate | vmware.host.net.bytesTx.average | Average amount of data transmitted per second |
| Host Network Interface Speed | vmware.host.nic.link_speed | Link Speed of Physical Network Interface Card |
| Received Packets Dropped | vmware.host.net.droppedRx.summation.count | Number of receives dropped |
| Transmitted Packets Dropped | vmware.host.net.droppedTx.summation.count | Number of transmits dropped |
| CPU Capacity Contention | vmware.vm.cpu.capacity.contention.average | Percent of time the VM is unable to run because it is contending for access to the physical CPU(s) |
| CPU Capacity Usage | vmware.vm.cpu.capacity.usage.average | CPU usage as a percent during the interval |
| CPU Core Count Contention (Ready) | vmware.vm.cpu.corecount.contention.average | Time the VM vCPU is ready to run, but is unable to run due to co-scheduling constraints |
| CPU Idle | vmware.vm.cpu.idle.summation | Total time that the CPU spent in an idle state |
| CPU Co-stop | vmware.vm.cpu.costop.summation | Time the virtual machine is ready to run, but is unable to run due to co-scheduling constraints |
| CPU Latency | vmware.vm.cpu.latency.average | Percent of time the virtual machine is unable to run because it is contending for access to the physical CPU(s) |
| CPU Wait | vmware.vm.cpu.wait.summation | Total CPU time spent in wait state |
| CPU Demand | vmware.vm.cpu.demand.average | The amount of CPU resources a virtual machine would use if there were no CPU contention or CPU limit |
| Active (1 min peak) | vmware.vm.rescpu.actpk1.latest | CPU active peak over 1 minute |
| Running (1 min peak) | vmware.vm.rescpu.runpk1.latest | CPU running peak over 1 minute |
| CPU Active (1 min average) | vmware.vm.rescpu.actav1.latest | CPU Active (1 min average) |
| CPU Running (1 min average) | vmware.vm.rescpu.runav1.latest | CPU Running (1 min average) |
| CPU Usage in MHz (max) | vmware.host.cpu.usagemhz.maximum | CPU usage in megahertz during the interval |
| CPU Usage (max) | vmware.host.cpu.usage.maximum | CPU usage as a percentage during the interval |
| Received Packets Dropped | vmware.vm.net.droppedRx.summation.count | Number of receives dropped |
| Transmitted Packets Dropped | vmware.vm.net.droppedTx.summation.count | Number of transmits dropped |
| Network Utilization | vmware.vm.net.usage.maximum | Network utilization (combined transmit-rates and receive-rates) |
| Data received Rate | vmware.vm.net.bytesRx.average | Average amount of data received per second |
| Data Transmit Rate | vmware.vm.net.bytesTx.average | Average amount of data transmitted per second |
| Current Snapshot Age | vmware.vm.current_snapshot.age | Age of the current snapshot. VMware does not recommend using a given snapshot for more than 24 to 72 hours. |
| Ballooned Memory | vmware.vm.mem.ballooned | The size of the balloon driver in the VM, in MB. The host will inflate the balloon driver to reclaim physical memory from the VM. This is a sign that there is memory pressure on the host. |
| Compressed Memory | vmware.vm.mem.compressed | The amount of compressed memory currently consumed by VM, in Kb. |
| Swapped Memory | vmware.vm.mem.swapped | The portion of memory, in MB, that is granted to this VM from the host's swap space. This is a sign that there is memory pressure on the host. |
| Memory Capacity Contention | vmware.vm.mem.capacity.contention.average | Percentage of time VMs are waiting to access swapped, compressed or ballooned memory |
| Memory Latency | vmware.vm.mem.latency.average | Percentage of time the virtual machine spent waiting to swap in or decompress guest physical memory |
| Command latency | vmware.host.disk.totalLatency.average | Average amount of time taken during the collection interval to process a SCSI command issued by the guest OS to the virtual machine |
| CPU Capacity Contention | vmware.host.cpu.capacity.contention.average | Percent of time the VM is unable to run because it is contending for access to the physical CPU(s) |
| CPU Capacity Usage | vmware.host.cpu.capacity.usage.average | CPU usage as a percent during the interval |
| CPU Idle | vmware.host.cpu.idle.summation | Total time that the CPU spent in an idle state |
| CPU Co-stop | vmware.host.cpu.costop.summation | Time the virtual machine is ready to run, but is unable to run due to co-scheduling constraints |
| CPU Latency | vmware.host.cpu.latency.average | Percent of time the virtual machine is unable to run because it is contending for access to the physical CPU(s) |
| CPU Ready | vmware.host.cpu.ready.summation | Time that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval |
| CPU Ready Percent | vmware.host.cpu.ready.percent | Time that the virtual machine was ready, but could not get scheduled to run on the physical CPU during last measurement interval |
| CPU Swap Wait | vmware.host.cpu.swapwait.summation | CPU time spent waiting for swap-in |
| CPU Total Hz | vmware.host.cpu.total_hz | Total CPU Hz available to Host (num of CPU Cores * Hz for Each Core) |
| CPU Used Hz | vmware.host.cpu.used_hz | Used CPU Hz of Host |
| CPU Wait | vmware.host.cpu.wait.summation | Total CPU time spent in wait state |
| CPU Usage in MHz (avg) | vmware.host.cpu.usagemhz.average | CPU usage in megahertz during the interval |
| CPU Usage in MHz (min) | vmware.host.cpu.usagemhz.minimum | CPU usage in megahertz during the interval |
| CPU Usage (min) | vmware.host.cpu.usage.minimum | CPU usage as a percentage during the interval |
| Running (1 min average) | vmware.host.rescpu.runav1.latest | CPU running average over 1 minute |
| Running (1 min peak) | vmware.host.rescpu.runpk1.latest | CPU running average over 1 minute |
| Active (1 min peak) | vmware.host.rescpu.actpk1.latest | CPU active peak over 1 minute |
| CPU Active (1 min average) | vmware.host.rescpu.actav1.latest | CPU Active (1 min average) |
| Host Disk Capacity | vmware.host.disk.capacity | — |
| Network Usage (min) | vmware.host.net.usage.minimum | Network utilization (combined transmit-rates and receive-rates) during the interval |
| Network Usage (max) | vmware.host.net.usage.maximum | Network utilization (combined transmit-rates and receive-rates) during the interval |
| Memory Consumed (min) % | vmware.host.mem.usage.minimum | Percentage of host physical memory that has been consumed |
| Memory Granted (min) | vmware.host.mem.granted.minimum | Amount of host physical memory or physical memory that is mapped for a virtual machine or a host |
| Ballooned memory (min) | vmware.host.mem.vmmemctl.minimum | Amount of guest physical memory reclaimed from the virtual machine by the balloon driver in the guest |
| Memory cache consumed (min) | vmware.host.mem.llSwapUsed.minimum | Storage space consumed on the host swap cache for storing swapped guest physical memory pages |
| Memory Swap In (min) | vmware.host.mem.swapIn.minimum | — |
| Memory Swap Out (min) | vmware.host.mem.swapOut.minimum | — |
| Memory Consumed (Min) | vmware.host.mem.consumed.minimum | — |
| Memory Active (Min) | vmware.host.mem.active.minimum | — |
| Storage Committed | vmware.vm.storage.committed | Total storage space, in bytes, committed to this virtual machine across all datastores. |
| Storage Uncommitted | vmware.vm.storage.uncommitted | Additional storage space, in bytes, potentially used by this virtual machine on all datastores. |
| Datastore Read Latency | vmware.vm.datastore.totalReadLatency.average | — |
| Datastore Write Latency | vmware.vm.datastore.totalWriteLatency.average | — |
| — | vmware.info.datastore_info | — |
| — | vmware.info.host_relations | — |
| Host Availability | vmware.host.availability | 100% if Connected and Powered On, else 0% |
| VM Availability | vmware.vm.availability | 100% if Connected and Powered On, else 0% |
| Sensor State | vmware.host.sensor.state | Hardware sensor state within the ESXi Host. 0=Green 1=Gray 2=Yellow 3=Red |
| Backing Device Capacity | vmware.vm.device.capacity | — |
| Volume Capacity | vmware.vm.volume.capacity | Total capacity of the disk, in bytes. This is part of the virtual machine configuration. |
| Volume Free Space | vmware.vm.volume.free_space | Free space on the disk, in bytes. This is retrieved by VMware Tools. |
| Disk Highest Latency | vmware.host.disk.maxTotalLatency.latest | Highest latency value across all disks used by the host |
| Physical Device Read Latency | vmware.host.disk.deviceReadLatency.average | Average amount of time, in milliseconds, to read from the physical device |
| Physical Device Write Latency | vmware.host.disk.deviceWriteLatency.average | Average amount of time, in milliseconds, to write to the physical device |
| Queue Write Latency | vmware.host.disk.queueWriteLatency.average | Average amount of time spent in the VMkernel queue, per SCSI write command, during the collection interval |
| Total Write latency (StoragePath) | vmware.host.storagePath.totalWriteLatency.average | The average time a write issued on the storage path takes |
| Number of CPU Cores | vmware.host.cpu.num_cores | — |
| Memory Size | vmware.host.mem.size | Total amount of physical memory on the host in bytes. |
| Memory Used (MB) | vmware.host.mem.used_mb | Physical memory usage on the host in MB |
| ESXi Host Uptime | vmware.host.uptime | Number of seconds the ESXi host has been up |
| Disk Highest latency | vmware.vm.disk.maxTotalLatency.latest | Highest latency value across all disks used by the host |
| Total Write latency | vmware.vm.disk.totalWriteLatency.average | Average amount of time taken during the collection interval to process a SCSI write command issued by the guest OS to the virtual machine |
| Read Requests | vmware.vm.disk.numberReadAveraged.average | Number of disk reads per second during the collection interval |
| Write Requests | vmware.vm.disk.numberWriteAveraged.average | Number of disk writes per second during the collection interval |
| Read latency | vmware.vm.disk.totalReadLatency.average | The average time a read from the virtual disk takes |
| Read rate | vmware.vm.disk.read.average | Average number of kilobytes read from the disk each second during the collection interval |
| Write rate | vmware.vm.disk.write.average | Average number of kilobytes written from the disk each second during the collection interval |
| Read Requests | vmware.vm.virtualDisk.numberReadAveraged.average | — |
| Write Requests | vmware.vm.virtualDisk.numberWriteAveraged.average | — |
| Read Rate | vmware.vm.virtualDisk.read.average | — |
| Write Rate | vmware.vm.virtualDisk.write.average | — |
| Read Latency | vmware.vm.virtualDisk.totalReadLatency.average | — |
| Write Latency | vmware.vm.virtualDisk.totalWriteLatency.average | — |
| Throughput Contention | vmware.vm.virtualDisk.throughput.cont.average | — |
The following events are included in the VMware (remote monitoring) extension and are ingested as log messages.
The ingested severities apply to version 4.4.0 and above.
| Event Type | Ingested Severity |
| WARN |
| INFO |
| ERROR |
| ERROR |
| ERROR |
| INFO |
| ERROR |
| WARN |
| WARN |
| ERROR |
| ERROR |
| WARN |
| INFO |
| INFO |
| WARN |
| INFO |
| INFO |
| INFO |
| INFO |
| ERROR |
| WARN |
Alarm events may be ingested as either logs or events. For large environments, we recommend using event-based alarms. If you're using version older than 3.14.2, log-based alarms aren't supported when lowering the Task Size parameter due to performance constraints. However, with version 3.14.2+, log-based alarms can be used with a lowered task size.
