Segment limits
  • Latest Dynatrace
  • Reference
  • 1-min read
General
  • 10,000 segments per environment
  • 20 include blocks per segment
  • 1 include block per type (for example, Logs, Metrics, Spans etc.)
  • 1 expression per filter condition minimum
  • 10 expressions per filter condition maximum
  • 10,000 values in the variable dropdown
  • 10 segments per query
Classic entities
For classic entities, various limits apply. These limits don't apply to Smartscape on Grail.
  • 1 additional include per classic entity type + relationship (entity includes only)
  • Conditions for related classic entities can be empty
  • 100 selected variable values per segment
Include block conditions
All data
  • Only fields and values of type STRING, and ARRAY_OR_STRINGS are supported
  • Only operators =, and in() are supported
    • You can use wildcards * for starts-with, contains, and ends-with matches. For details, see Wildcards.
    • Asterisks are allowed to follow variable names in conditions for starts-with (for example, foo = $bar*)
Classic entities
  • Only selected properties (suggested in the filter field) are allowed
  • starts-with, contains, and ends-with are not supported
    • The only exception is entity.name, which supports starts-with
    • Other properties only support equals
Related tags
Dynatrace Platform
