Browser Monitors are synthetic monitoring capabilities that simulate user interactions with your web applications.
This page explains how consumption is calculated, and how you can estimate, manage, and optimize your synthetic monitoring usage in Dynatrace.
Browser Monitors consume usage based on the number of synthetic actions executed, using the Browser Monitor or Clickpath rate-card item.
Synthetic actions are triggered by steps within a browser monitor, as described below.
A simulated browser test that you configure in Dynatrace. Each browser monitor is composed of one or more steps.
A discreet unit within a browser monitor, which represents a single simulated user interaction. Example steps are "navigate to homepage", "select the login button", or "submit a form".
A synthetic action is a specific step that is billable. Steps are billable only when they trigger a web request, for example, page loads, navigations, and user actions that explicitly trigger XHR or Fetch requests.
No single step is ever counted as more than one synthetic action.
Every time a synthetic test runs, Dynatrace counts the actions executed during that run.
Synthetic actions are counted for both public and private synthetic executions.
If a step triggers one or more web requests, it's counted as one synthetic action. A step that triggers, for example, three XHR requests is billed as a single synthetic action. Consumption is driven by the number of steps that produce at least one web request, not by the total number of web requests.
A synthetic action is billed as soon as the step is executed, regardless of whether the action passes or fails.
If a step triggers no web requests, it counts as zero synthetic actions. The following interactions don't consume synthetic actions:
Steps that consist only of scrolls, keystrokes, or clicks that don't trigger a web request.
XHR or Fetch requests automatically triggered by the browser after a page load, unless explicitly triggered by a user action.
Any steps that occur after a failed action, since they're never executed.
In this example, we'll have a browser monitor with four steps.
| Step | User action | What happens | Synthetic actions billed |
1 | Go to the homepage | Triggers a page load | 1 |
2 | Select Login | Triggers an XHR request to the authorization API, which then fires two additional XHR requests for user profile and preferences | 1 |
3 | Scroll down the page | No web request triggered | 0 |
4 | Select Submit order | Triggers a Fetch request | 1 |
In total, three synthetic actions are billed for this single browser monitor execution, even though the browser monitor has four steps and step 2 produced three web requests.
You can estimate your monthly cost by calculating the total number of billable steps (that is, a step that triggers at least one web request). Then, use the formula below.
(# of billable steps per execution)× (# of executions per hour)× (# of locations)× (# of hours)= Total synthetic actions
For simplicity, this example assumes that:
If you have a browser monitor that:
Your monthly consumption can be calculated with the formula below.
3 billable steps per execution× 4 executions per hour× 3 locations× 720 hours= 25,920 synthetic actions
Multiplied by the unit cost of $0.0045 per result, the total cost for synthetic actions in this example is $116.64 per month.
Dynatrace provides various options to help you understand and analyze your organization's consumption of Browser Monitor or Clickpath.
The ready-made Usage - Synthetic Monitoring dashboard shows the estimated cost of Browser Monitor or Clickpath alongside the other Synthetic Monitoring capabilities. Use it to see which browser monitors drive synthetic actions, and how their consumption changes over time.
To get the dashboard, go to
Dashboards > Ready-made and search for Usage - Synthetic Monitoring.
For more information, see Usage - Synthetic Monitoring.
License managers can view usage and costs in Account Management. Go to Account Management > Subscription > Overview > Cost and usage details > Usage summary and select the Browser Monitor and Clickpath capability.
For more information, see Overview (Dynatrace Platform Subscription).
Billing usage events (BUEs, billing_usage_event) are system events emitted by Dynatrace into the dt.system.events data space.
You can use DQL to query BUEs, and analyze usage and cost for Real User Monitoring capabilities without re-applying billing rules or session-counting logic.
BUEs represent already-calculated, billable usage for DPS capabilities (not any configuration or potential usage), and are aligned with what is shown in Account Management and on invoices. Therefore, they're the recommended data source for understanding related consumption.
Billing usage events contain:
You can use billing usage events as the authoritative source when building cost allocation, usage analysis, or cost transparency views.
For example, aggregate by application to understand which applications contribute most to usage and cost.
Here are some example DQL queries for various use cases. You can use these queries as-is, or modify them to meet your needs.
Total usage over time
fetch dt.system.events| filter event.kind == "BILLING_USAGE_EVENT" and event.type == "Browser Monitor and Clickpath"| dedup event.id| summarize totalUsage = sum(billed_sessions), by:{bin(timestamp, 1d)}
You can query insights via the Environment API – Grail Query. Example DQL queries are provided in Query billing usage events with DQL.
Yes. On-demand executions from assigned locations count the same as scheduled executions.
Yes. Actions are counted once they start executing. However, any steps that are skipped due to failure do not consume actions.
No. Only web requests triggered directly by synthetic user actions (such as page loads or explicit XHR triggers) are counted.
No. Disabled monitors stop all executions and do not generate any consumption.
