Create a new AWS connection
  • Latest Dynatrace
  • How-to guide
If this is the first time you are creating a connection, first see the onboarding instructions and its prerequisites.
If you have an existing classic connection, consider upgrading to the new cloud connections for the latest Clouds Clouds experience.
To set up a new AWS connection
  1. Go to Clouds Clouds.
  2. In the upper-right corner of the page, select Create connection > AWS New.
    Note: If it's your first cloud connection, you can also select Create connection > AWS New on the Overview page.
  3. Follow the steps outlined in New connection to start the onboarding process for a new AWS cloud connection.
    Clouds app | Create a new AWS connection
  4. After you’ve successfully deployed the CloudFormation stack within AWS, it takes up to 15 minutes to see your cloud inventory on the new Explorer New tab view within Clouds Clouds.
  5. Optional Check the state and health of your cloud connection in Settings Settings.
    1. Go to Settings Settings > Collect and capture > Cloud and virtualization.
    2. Select AWS.
  6. Optional Set up and configure health alerts and warning signals in Settings Settings.
    1. Go to Settings Settings > Analyze and alert > Alerts > Cloud services.
    2. Select New Alerts.
    3. Follow the steps in the wizard to create health alerts for your newly onboarded AWS Account.
    Settings | Ready-made alertsSettings | Health alert details
    1 of 2Settings | Ready-made alerts
Related tags
CloudsCloudsInfrastructure Observability
