Create your first AWS connection to start ingesting topology, metrics, logs, and events from your AWS environment into Dynatrace.
All AWS connection creation methods are powered by CloudFormation as the Infrastructure-as-Code (IaC) engine. You can create your first AWS connection via:
Settings app: Onboard your AWS account in a few steps that generate a deployable CloudFormation template.
API and AWS CLI: Onboard your AWS environments and create AWS connections via API and AWS CLI.
API: Onboard your AWS environments and create AWS connections via API.
AWS Organizations: Onboard AWS member accounts within your AWS Organization and Organizational Units.
A single Dynatrace environment allows up to 500 connections. If you need to exceed this, contact Dynatrace support.
