Tomcat (JMX) extension
  • Latest Dynatrace
  • Extension
Monitor Apache Tomcat connection pools, thread pools, and web request performance with JMX metrics for Java application servers.
Use this extension collects connection pool, thread pool, and web request activity and performance for Tomcat.
Get started
Overview
Apache Tomcat is an open-source web server developed by the Apache Software Foundation (ASF) and one of the most popular servlet containers available today. It’s an incredibly lightweight, flexible and extremely stable platform to build on. The OneAgent will allow you to trace activity on and through your Tomcat applications. Using this JMX extension you'll be able to collect additional key performance data to identify issues and optimize your Tomcat configurations.
Use cases
  • Identify issues with connection pool utilization and activity that could impact your web applications.
  • Optimize your thread and connection pool configurations to increase efficiency while not impacting your application clients.
  • Monitor your web application by viewing web request activity and performance data from Tomcat's perspective in context with other key metrics.
Requirements
  • Tomcat process that runs on a supported Linux or Windows operating system.
  • OneAgent version 1.273+
  • Dynatrace version 1.309+
To get metric insight:
  1. Install OneAgent on the virtual machine or server of your Tomcat process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
    • When enabling for the first time each process will need to be restarted for this feature to become active.
  3. In the same tile, select Add to environment to configure the extension.
Compatibility information
The following Mbeans are used for collecting data. If you don't see the metrics, check that the following Mbeans exist using the tool of your choice (e.g. JConsole).
  • Connection pools:
    • Catalina:type=DataSource,name=*,class=*,context=*,host=* or Catalina:type=DataSource,name=*,class=*
  • Thread pools:
    • Catalina:type=ThreadPool,name=*
  • Web request activity
    • Catalina:type=GlobalRequestProcessor,name=*
For connection pools specifically, this extension only supports the standard Tomcat connection pooling implementation with Mbeans under the Catalina domain. It is not uncommon for a different pooling implementation to be used and in these cases you may need to create your own custom JMX extension to collect similar data (if it is available via JMX). You should consult your implementation's documentation or review available Mbeans in your Tomcat process to get started with this.
Details
Metrics are organized into feature sets you can enable/disable as desired.
Additionally, there is one calculated metric included:
  • Average request processing time (func:tomcat.processingTimePerRequest): Request processing time divided by request count
Licensing and costs
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The Tomcat (JMX) extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
The following formula provides the number of metric data points per minute, assuming all feature sets are enabled.
(16 * <number_of_connection_pools>) + (5 * <number_of_web_apps>) + (3 * <number_of_thread_pools>)
Dynatrace Platform Subscription
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
Feature sets
web-requests
Metric nameMetric keyDescription
Bytes recievedtomcat.bytesReceived.countBytes recieved
Bytes senttomcat.bytesSent.countBytes sent
Request counttomcat.requestCount.countRequest count
Error counttomcat.errorCount.countError count
Request processing timetomcat.processingTime.countRequest processing time
stuck-threads
Stuck thread counttomcat.stuckThreadsStuck thread count
additional-metrics
Borrowed connectionstomcat.connectionPool.borrowedConnections—
Reconnected connectionstomcat.connectionPool.reconnectedConnections—
Released connectionstomcat.connectionPool.releasedConnections—
Returned connectionstomcat.connectionPool.returnedConnections—
limits
Max total connectionstomcat.connectionPool.maxTotalMaximum total amount of connections
Max active connectionstomcat.connectionPool.maxActiveMaximum amount of active connections allowed concurrently
Max idle connectionstomcat.connectionPool.maxIdleThe maximum number of connections that should be kept in the pool at all times
Max wait timetomcat.connectionPool.maxWaitThe maximum number of milliseconds that the pool will wait (when there are no available connections) for a connection to be returned before throwing an exception
Minimum idletomcat.connectionPool.minIdleThe minimum number of established connections that should be kept in the pool at all times
thread-pools
Current thread counttomcat.threadPool.currentThreadCountCurrent thread count
Current threads busytomcat.threadPool.currentThreadsBusyCurrent threads busy
Max threads allowedtomcat.threadPool.maxThreadsMax threads allowed
session-manager
Active sessionstomcat.session.activeSessionsNumber of currently active sessions
Duplicate sessionstomcat.session.duplicatesNumber of duplicated sessions
Expired sessionstomcat.session.expiredSessions.countNumber of sessions that have expired
Max active sessionstomcat.session.maxActiveMaximum number of active sessions seen so far
Max active sessions allowedtomcat.session.maxActiveSessionsMaximum number of active sessions allowed, -1 for no limit
Process expires frequencytomcat.session.processExpiresFrequencyFrequency of the session expiration process
Session processing timetomcat.session.processingTime.countTime spent processing sessions
Rejected sessionstomcat.session.rejectedSessionsNumber of sessions rejected due to maxActive being reached
Session average alive timetomcat.session.sessionAverageAliveTimeAverage time a session has been alive
Session countertomcat.session.sessionCounter.countTotal number of sessions created
Session create ratetomcat.session.sessionCreateRateRate of session creation per minute
Session expire ratetomcat.session.sessionExpireRateRate of session expiration per minute
Session max alive timetomcat.session.sessionMaxAliveTimeLongest time a session has been alive
key-metrics
Active connectionstomcat.connectionPool.activeConnectionsCurrently used connections
Created connectionstomcat.connectionPool.createdConnectionsNumber of connections created
Idle connectionstomcat.connectionPool.idleConnectionsNumber of open but unused connections
Waiting connectionstomcat.connectionPool.numWaitersCurrently waiting connections
Abandoned connectionstomcat.connectionPool.removeAbandonedNumber of connections that have not been properly released
Abandoned connection timeouttomcat.connectionPool.removeAbandonedTimeoutTimeout before an abandoned connection can be removed
Waiting connection requeststomcat.connectionPool.waitCountNumber of connection requests currently waiting
Hub
Explore in Dynatrace Hub
Related topics
  • Dynatrace blog - AI-powered insights into connection pool performance
Related tags
ApplicationJMXConnection poolApacheApplication Observability
