Dynatrace Runtime Application Protection leverages code-level insights and transaction analysis to detect and block exploitation attempts on your applications automatically and in real time.
Runtime Application Protection (RAP) uses runtime instrumentation to detect and optionally block exploit attempts. When your application receives a web request, Dynatrace OneAgent tracks user input and analyzes how it interacts with sensitive code paths, such as SQL queries, OS commands, or JNDI lookups. If the behavior matches a known attack pattern, Dynatrace reports it as a security finding. If attack blocking is enabled, OneAgent throws an exception to stop the malicious request before it executes. RAP is lightweight and safe for use in production environments.
Before you begin, ensure your environment meets the necessary requirements:
You're using a supported version of Dynatrace. Review the release notes for currently supported versions.
For Runtime Application Protection to work properly, make sure deep monitoring is enabled in Settings > Process and contextualize > Process groups > Process group monitoring.
For .NET, Go, and Python technologies, for which automatic deep monitoring is disabled, you need to manually enable deep monitoring on each host. For more information, see Process deep monitoring.
Dynatrace detects SQL injection, JNDI injection, command injection, and SSRF attacks in the following technologies.
Only supported on Windows x86 and Linux x86 systems.
Only .NET Framework 4.5, .NET Core 3.0 or higher, and 64-bit processes are supported.
For .NET and Go technologies, for which automatic deep monitoring is disabled, you need to manually enable deep monitoring on each host. For more information, see Process deep monitoring.
To set up Runtime Application Protection, follow the instructions below.
To use preview features, please contact a Dynatrace product expert via live chat to activate Runtime Application Protection before continuing.
To enable Runtime Application Protection globally on your environment
Go to Settings > Analyze and alert > Application security > Application protection (New).
Enable Runtime Application Protection.
Select Enable.
Restart your processes.
To define the global attack control for all process groups
If you define custom monitoring rules based on certain process groups or vulnerability types, the custom rules override the global attack control for the selected technology, and Runtime Application Protection continues to monitor the attacks based on your rules.
Select Save.
Go to Settings and select Collect and capture > General monitoring settings > OneAgent features.
Filter by code-level attack evaluation and enable the feature for the technologies you want to monitor.
Select Save changes.
To detect SSRF attacks, you also need to enable SSRF attack evaluation. See below for instructions.
Find and enable Java SSRF code-level vulnerability and attack evaluation.
After you set up Runtime Application Protection, you can
Threats & Exploits.Runtime Application Protection consumption depends on your Dynatrace licensing model:
