Closes the specified problem and adds the closing comment.
The request consumes and produces an application/json payload.
| POST | SaaS | https://{your-environment-id}.live.dynatrace.com/api/v2/problems/{problemId}/close |
| POST | Environment ActiveGateCluster ActiveGate | https://{your-activegate-domain}:9999/e/{your-environment-id}/api/v2/problems/{problemId}/close |
To execute this request, you need an access token with problems.write scope.
To learn how to obtain and use it, see Tokens and authentication.
| Parameter | Type | Description | In | Required |
| problemId | string | The ID of the required problem. | path | Required |
| body | Problem | The JSON body of the request. Contains the closing comment on the problem. | body | Optional |
ProblemCloseRequestDtoImpl object| Element | Type | Description | Required |
| message | string | The text of the closing comment. | Required |
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
{"message": "string"}
| Code | Type | Description |
| 200 | Problem | Success |
| 204 | - | The problem is closed already the request hasn't been executed. |
| 4XX | Error | Client side error. |
| 5XX | Error | Server side error. |
ProblemCloseResult objectThe result of closing a problem.
| closeTimestamp | integer | The timestamp when the user triggered the closing. |
| closing | boolean | True, if the problem is being closed. |
| comment | Comment | The comment to a problem. |
| problemId | string | The ID of the problem. |
Comment objectThe comment to a problem.
| authorName | string | The user who wrote the comment. |
| content | string | The text of the comment. |
| context | string | The context of the comment. |
| createdAtTimestamp | integer | The timestamp of comment creation, in UTC milliseconds. |
| id | string | The ID of the comment. |
ErrorEnvelope object| Element | Type | Description |
| error | Error | - |
Error object| Element | Type | Description |
| code | integer | The HTTP status code |
| constraintViolations | Constraint | A list of constraint violations |
| message | string | The error message |
ConstraintViolation objectA list of constraint violations
| location | string | - |
| message | string | - |
| parameterLocation | string | -The element can hold these values
| path | string | - |
{"closeTimestamp": 1,"closing": true,"comment": {"authorName": "string","content": "string","context": "string","createdAtTimestamp": 1,"id": "string"},"problemId": "string"}
{"error": {"code": 1,"constraintViolations": [{"location": "string","message": "string","parameterLocation": "HEADER","path": "string"}],"message": "string"}}
