Problems API v2
  • Reference
  • Published Oct 12, 2020
Fetch the list of problems
Gain high-level overview of problems.
Get the problem details
When you find a problem you want to investigate, fetch details about it.
Close problem
When a problem is not a concern anymore, close it.
List comments
View all comments on a problem.
View a comment
Check a particular comment on a specified problem.
Post comment
Post a comment on a specified problem.
Edit comment
Edit a comment on a specified problem.
Delete comment
Delete a comment from a specified problem.
Related topics
  • Dynatrace Intelligence
