Google Compute Engine with Operations suite metrics monitoring
Dynatrace Google Cloud integration leverages data collected from the Google Operation API to constantly monitor health and performance of Google Cloud Services. While combining all relevant data into dashboards, it also enables alerting and event tracking.
Prerequisites
Set up integration
Add services and feature sets optional
After integration, Dynatrace automatically monitors a number of preset Google Cloud services and feature sets (metrics). Besides these, you can add more services or feature sets to monitoring. For details, see Add or remove services.
For a list of feature sets available for this service, see Metric table.
View metrics
After deploying the integration, you can see metrics from monitored services in the Metrics browser, Data Explorer, and your dashboard tiles.
Metric table
The following feature sets are available for Google Compute Engine.
gce_instance/default_metrics
compute.googleapis.com/firewall/dropped_bytes_count
compute.googleapis.com/firewall/dropped_packets_count
compute.googleapis.com/guest/cpu/runnable_task_count
compute.googleapis.com/guest/cpu/usage_time
compute.googleapis.com/guest/disk/bytes_used
compute.googleapis.com/guest/disk/io_time
compute.googleapis.com/guest/disk/merged_operation_count
compute.googleapis.com/guest/disk/operation_bytes_count
compute.googleapis.com/guest/disk/operation_count
compute.googleapis.com/guest/disk/operation_time
compute.googleapis.com/guest/disk/queue_length
compute.googleapis.com/guest/disk/weighted_io_time
Anonymous memory usage in Bytes
compute.googleapis.com/guest/memory/anonymous_used
compute.googleapis.com/guest/memory/bytes_used
Dirty pages usage in Bytes.
compute.googleapis.com/guest/memory/dirty_used
Page cache memory usage in Bytes
compute.googleapis.com/guest/memory/page_cache_used
Unevictable memory usage in Bytes
compute.googleapis.com/guest/memory/unevictable_used
compute.googleapis.com/guest/system/problem_count
compute.googleapis.com/guest/system/problem_state
compute.googleapis.com/guest/system/uptime
compute.googleapis.com/instance/cpu/reserved_cores
compute.googleapis.com/instance/cpu/scheduler_wait_time
compute.googleapis.com/instance/cpu/usage_time
compute.googleapis.com/instance/cpu/utilization
compute.googleapis.com/instance/disk/max_read_bytes_count
compute.googleapis.com/instance/disk/max_read_ops_count
compute.googleapis.com/instance/disk/max_write_bytes_count
compute.googleapis.com/instance/disk/max_write_ops_count
compute.googleapis.com/instance/disk/read_bytes_count
compute.googleapis.com/instance/disk/read_ops_count
compute.googleapis.com/instance/disk/throttled_read_bytes_count
Throttled read operations
compute.googleapis.com/instance/disk/throttled_read_ops_count
compute.googleapis.com/instance/disk/throttled_write_bytes_count
Throttled write operations
compute.googleapis.com/instance/disk/throttled_write_ops_count
compute.googleapis.com/instance/disk/write_bytes_count
compute.googleapis.com/instance/disk/write_ops_count
compute.googleapis.com/instance/integrity/early_boot_validation_status
compute.googleapis.com/instance/integrity/late_boot_validation_status
compute.googleapis.com/instance/memory/balloon/ram_size
compute.googleapis.com/instance/memory/balloon/ram_used
compute.googleapis.com/instance/memory/balloon/swap_in_bytes_count
compute.googleapis.com/instance/memory/balloon/swap_out_bytes_count
compute.googleapis.com/instance/network/received_bytes_count
compute.googleapis.com/instance/network/received_packets_count
compute.googleapis.com/instance/network/sent_bytes_count
compute.googleapis.com/instance/network/sent_packets_count
compute.googleapis.com/instance/uptime
compute.googleapis.com/instance/uptime_total
compute.googleapis.com/mirroring/dropped_packets_count
compute.googleapis.com/mirroring/mirrored_bytes_count
compute.googleapis.com/mirroring/mirrored_packets_count
compute.googleapis.com/nat/allocated_ports
compute.googleapis.com/nat/closed_connections_count
Received packets dropped count
compute.googleapis.com/nat/dropped_received_packets_count
Sent packets dropped count
compute.googleapis.com/nat/dropped_sent_packets_count
compute.googleapis.com/nat/new_connections_count
compute.googleapis.com/nat/open_connections
compute.googleapis.com/nat/port_usage
compute.googleapis.com/nat/received_bytes_count
compute.googleapis.com/nat/received_packets_count
compute.googleapis.com/nat/sent_bytes_count
compute.googleapis.com/nat/sent_packets_count
Monitoring Agent API Request Count
agent.googleapis.com/agent/api_request_count
Logging Agent Log Entry Count
agent.googleapis.com/agent/log_entry_count
Logging Agent Retried Log Entry Writes Count
agent.googleapis.com/agent/log_entry_retry_count
Monitoring Agent Memory Usage
agent.googleapis.com/agent/memory_usage
Monitoring Agent Metric Point Count
agent.googleapis.com/agent/monitoring/point_count
Logging Agent API Request Count
agent.googleapis.com/agent/request_count
Monitoring Agent Process Labels Size
agent.googleapis.com/agent/streamspace_size
Monitoring Agent is Throttling Processes
agent.googleapis.com/agent/streamspace_size_throttling
Monitoring/Logging Agent Uptime
agent.googleapis.com/agent/uptime
agent.googleapis.com/apache/connections
agent.googleapis.com/apache/idle_workers
agent.googleapis.com/apache/request_count
agent.googleapis.com/apache/scoreboard
agent.googleapis.com/apache/traffic
agent.googleapis.com/cassandra/cache/hits
agent.googleapis.com/cassandra/client_request/latency/50p
agent.googleapis.com/cassandra/client_request/latency/95p
agent.googleapis.com/cassandra/client_request/latency/99p
agent.googleapis.com/cassandra/client_request/latency/max
agent.googleapis.com/cassandra/column_family/compression_ratio
agent.googleapis.com/cassandra/column_family/max_row_size
agent.googleapis.com/cassandra/commitlog_total_size
agent.googleapis.com/cassandra/completed_tasks
agent.googleapis.com/cassandra/current_tasks
agent.googleapis.com/cassandra/dropped_message/dropped_count
agent.googleapis.com/cassandra/storage_service_exception_count
agent.googleapis.com/cassandra/storage_service_load
agent.googleapis.com/couchdb/average_request_time
agent.googleapis.com/couchdb/httpd/bulk_request_count
agent.googleapis.com/couchdb/httpd/request_count
agent.googleapis.com/couchdb/httpd/request_method_count
agent.googleapis.com/couchdb/httpd/response_code_count
agent.googleapis.com/couchdb/httpd/temporary_view_read_count
agent.googleapis.com/couchdb/httpd/view_read_count
agent.googleapis.com/couchdb/open_databases
agent.googleapis.com/couchdb/open_files
agent.googleapis.com/couchdb/read_count
agent.googleapis.com/couchdb/write_count
agent.googleapis.com/cpu/load_15m
agent.googleapis.com/cpu/load_1m
agent.googleapis.com/cpu/load_5m
agent.googleapis.com/cpu/usage_time
agent.googleapis.com/cpu/utilization
agent.googleapis.com/disk/bytes_used
agent.googleapis.com/disk/io_time
agent.googleapis.com/disk/merged_operations
agent.googleapis.com/disk/operation_count
agent.googleapis.com/disk/operation_time
agent.googleapis.com/disk/pending_operations
agent.googleapis.com/disk/percent_used
agent.googleapis.com/disk/read_bytes_count
agent.googleapis.com/disk/weighted_io_time
agent.googleapis.com/disk/write_bytes_count
agent.googleapis.com/elasticsearch/cache_memory_usage
agent.googleapis.com/elasticsearch/field_eviction_count
agent.googleapis.com/elasticsearch/filter_cache_eviction_count
agent.googleapis.com/elasticsearch/gc_collection_count
agent.googleapis.com/elasticsearch/memory_usage
agent.googleapis.com/elasticsearch/network
agent.googleapis.com/elasticsearch/num_current_documents
agent.googleapis.com/elasticsearch/num_data_nodes
agent.googleapis.com/elasticsearch/num_http_connections
agent.googleapis.com/elasticsearch/num_nodes
agent.googleapis.com/elasticsearch/num_open_files
agent.googleapis.com/elasticsearch/num_server_connections
agent.googleapis.com/elasticsearch/num_shards
agent.googleapis.com/elasticsearch/operation_count
agent.googleapis.com/elasticsearch/operation_time
agent.googleapis.com/elasticsearch/peak_threads
agent.googleapis.com/elasticsearch/storage_size
agent.googleapis.com/elasticsearch/threads
agent.googleapis.com/hbase/ipc/connections
agent.googleapis.com/hbase/ipc/queue_length
agent.googleapis.com/hbase/ipc/traffic_count
agent.googleapis.com/hbase/master/average_load
agent.googleapis.com/hbase/master/dead_region_servers
agent.googleapis.com/hbase/master/live_region_servers
agent.googleapis.com/hbase/regionserver/block_cache/access_count
agent.googleapis.com/hbase/regionserver/block_cache/evicted_blocks_count
agent.googleapis.com/hbase/regionserver/block_cache/hit_ratio_percent
agent.googleapis.com/hbase/regionserver/block_cache/memory
agent.googleapis.com/hbase/regionserver/block_cache/num_items
agent.googleapis.com/hbase/regionserver/call_queue/length
agent.googleapis.com/hbase/regionserver/compaction_queue/length
agent.googleapis.com/hbase/regionserver/flush_queue/length
agent.googleapis.com/hbase/regionserver/memory/heap_usage
agent.googleapis.com/hbase/regionserver/memstore/files
agent.googleapis.com/hbase/regionserver/memstore/index_size
agent.googleapis.com/hbase/regionserver/memstore/open_stores
agent.googleapis.com/hbase/regionserver/memstore/size
agent.googleapis.com/hbase/regionserver/online_regions
agent.googleapis.com/hbase/regionserver/request_count
agent.googleapis.com/hbase/regionserver/requests/total_rate
agent.googleapis.com/hbase/regionserver/slow_operation_count
Thrift average batch latency
agent.googleapis.com/hbase/thrift/batch_latency/average
Thrift average call latency
agent.googleapis.com/hbase/thrift/call_latency/average
agent.googleapis.com/hbase/thrift/call_queue/length
Thrift average slow call latency
agent.googleapis.com/hbase/thrift/slow_call_latency/average
Thrift average time in queue
agent.googleapis.com/hbase/thrift/time_in_queue/average
agent.googleapis.com/iis/current_connections
agent.googleapis.com/iis/network/transferred_bytes_count
agent.googleapis.com/iis/new_connection_count
agent.googleapis.com/iis/request_count
agent.googleapis.com/interface/errors
agent.googleapis.com/interface/packets
agent.googleapis.com/interface/traffic
agent.googleapis.com/jvm/gc/count
agent.googleapis.com/jvm/gc/time
agent.googleapis.com/jvm/memory/usage
agent.googleapis.com/jvm/os/cpu_time
agent.googleapis.com/jvm/os/open_files
agent.googleapis.com/jvm/thread/num_daemon
agent.googleapis.com/jvm/thread/num_live
agent.googleapis.com/jvm/thread/peak
agent.googleapis.com/jvm/uptime
agent.googleapis.com/kafka/broker/topics/failed_request_count
agent.googleapis.com/kafka/broker/topics/incoming_message_count
agent.googleapis.com/kafka/broker/topics/traffic
agent.googleapis.com/kafka/controller/kafka/active
agent.googleapis.com/kafka/controller/kafka/offline_partitions
agent.googleapis.com/kafka/controller/leader_elections/election_count
agent.googleapis.com/kafka/controller/leader_elections/unclean_count
agent.googleapis.com/kafka/log/flush_count
agent.googleapis.com/kafka/network/request_count
Delayed purgatory requests
agent.googleapis.com/kafka/purgatory/num_delayed_requests
agent.googleapis.com/kafka/purgatory/size
agent.googleapis.com/kafka/replica_fetcher/max_lag
agent.googleapis.com/kafka/replica_fetcher/min_fetch_rate
agent.googleapis.com/kafka/replica_manager/isr/expand_count
agent.googleapis.com/kafka/replica_manager/isr/shrink_count
agent.googleapis.com/kafka/replica_manager/leaders
agent.googleapis.com/kafka/replica_manager/partitions
agent.googleapis.com/kafka/replica_manager/under_replicated_partitions
agent.googleapis.com/memcached/command_count
agent.googleapis.com/memcached/current_connections
agent.googleapis.com/memcached/current_items
agent.googleapis.com/memcached/eviction_count
agent.googleapis.com/memcached/memory
agent.googleapis.com/memcached/network
agent.googleapis.com/memcached/operation_count
agent.googleapis.com/memcached/operation_hitratio
agent.googleapis.com/memcached/rusage
agent.googleapis.com/memcached/threads
agent.googleapis.com/memory/bytes_used
agent.googleapis.com/memory/percent_used
agent.googleapis.com/mongodb/cache/hits
agent.googleapis.com/mongodb/cache/misses
agent.googleapis.com/mongodb/collections
agent.googleapis.com/mongodb/connections
agent.googleapis.com/mongodb/data_size
agent.googleapis.com/mongodb/extents
agent.googleapis.com/mongodb/global_lock_hold_time
agent.googleapis.com/mongodb/index_size
agent.googleapis.com/mongodb/indexes
agent.googleapis.com/mongodb/memory_usage
agent.googleapis.com/mongodb/objects
agent.googleapis.com/mongodb/operation_count
agent.googleapis.com/mongodb/storage_size
SQL Server open connections
agent.googleapis.com/mssql/connections/user
SQL Server transaction rate
agent.googleapis.com/mssql/transaction_rate
SQL Server write transaction rate
agent.googleapis.com/mssql/write_transaction_rate
agent.googleapis.com/mysql/buffer_pool/num_pages
agent.googleapis.com/mysql/buffer_pool/operation_count
agent.googleapis.com/mysql/buffer_pool_size
agent.googleapis.com/mysql/command_count
agent.googleapis.com/mysql/handler_count
InnoDB doublewrite buffers
agent.googleapis.com/mysql/innodb/doublewrite_count
agent.googleapis.com/mysql/innodb/log_operation_count
agent.googleapis.com/mysql/innodb/operation_count
agent.googleapis.com/mysql/innodb/page_operation_count
agent.googleapis.com/mysql/innodb/row_lock_count
agent.googleapis.com/mysql/innodb/row_operation_count
agent.googleapis.com/mysql/lock_count
agent.googleapis.com/mysql/qcache/operation_count
agent.googleapis.com/mysql/qcache/query_count
agent.googleapis.com/mysql/slave_replication_lag
agent.googleapis.com/mysql/sort_count
agent.googleapis.com/mysql/thread_count
agent.googleapis.com/network/tcp_connections
agent.googleapis.com/nginx/connections/accepted_count
agent.googleapis.com/nginx/connections/current
agent.googleapis.com/nginx/connections/handled_count
agent.googleapis.com/nginx/request_count
agent.googleapis.com/pagefile/percent_used
agent.googleapis.com/postgresql/blocks_read_count
agent.googleapis.com/postgresql/commit_count
agent.googleapis.com/postgresql/db_size
agent.googleapis.com/postgresql/num_backends
agent.googleapis.com/postgresql/num_tuples
agent.googleapis.com/postgresql/operation_count
agent.googleapis.com/postgresql/rollback_count
agent.googleapis.com/processes/count_by_state
agent.googleapis.com/processes/cpu_time
agent.googleapis.com/processes/disk/read_bytes_count
agent.googleapis.com/processes/disk/write_bytes_count
agent.googleapis.com/processes/fork_count
agent.googleapis.com/processes/rss_usage
agent.googleapis.com/processes/vm_usage
agent.googleapis.com/rabbitmq/consumers
agent.googleapis.com/rabbitmq/delivery_rate
agent.googleapis.com/rabbitmq/num_messages
agent.googleapis.com/rabbitmq/publish_rate
agent.googleapis.com/redis/changes_since_last_save
agent.googleapis.com/redis/clients/blocked
agent.googleapis.com/redis/clients/connected
agent.googleapis.com/redis/commands_processed
agent.googleapis.com/redis/connections/slaves
agent.googleapis.com/redis/connections/total
agent.googleapis.com/redis/expired_keys
agent.googleapis.com/redis/memory/usage
agent.googleapis.com/redis/memory/usage_lua
agent.googleapis.com/redis/pubsub/channels
agent.googleapis.com/redis/pubsub/patterns
agent.googleapis.com/redis/uptime
agent.googleapis.com/riak/latency/95th_percentile
agent.googleapis.com/riak/latency/average
agent.googleapis.com/riak/latency/maximum
agent.googleapis.com/riak/memory_usage
agent.googleapis.com/riak/num_siblings/95th_percentile
agent.googleapis.com/riak/num_siblings/average
agent.googleapis.com/riak/num_siblings/maximum
agent.googleapis.com/riak/object_size/95th_percentile
agent.googleapis.com/riak/object_size/average
agent.googleapis.com/riak/object_size/maximum
agent.googleapis.com/riak/operation_count
agent.googleapis.com/swap/bytes_used
agent.googleapis.com/swap/io
agent.googleapis.com/swap/percent_used
agent.googleapis.com/tomcat/manager/sessions
agent.googleapis.com/tomcat/request_processor/error_count
agent.googleapis.com/tomcat/request_processor/processing_time
agent.googleapis.com/tomcat/request_processor/request_count
agent.googleapis.com/tomcat/request_processor/traffic_count
agent.googleapis.com/tomcat/threads/busy
agent.googleapis.com/tomcat/threads/current
Backend connection successes
agent.googleapis.com/varnish/backend_connection_count
agent.googleapis.com/varnish/cache_operation_count
agent.googleapis.com/varnish/client_connection_count
agent.googleapis.com/zookeeper/connections_count
agent.googleapis.com/zookeeper/data_size
agent.googleapis.com/zookeeper/followers/count
agent.googleapis.com/zookeeper/followers/synced_count
agent.googleapis.com/zookeeper/network/received_packets_count
agent.googleapis.com/zookeeper/network/sent_packets_count
agent.googleapis.com/zookeeper/nodes/count
agent.googleapis.com/zookeeper/nodes/ephemeral_count
agent.googleapis.com/zookeeper/nodes/watches_count
agent.googleapis.com/zookeeper/requests/latency/average
agent.googleapis.com/zookeeper/requests/latency/maximum
agent.googleapis.com/zookeeper/requests/latency/minimum
agent.googleapis.com/zookeeper/requests/outstanding_count
agent.googleapis.com/zookeeper/sync_operations/pending_count
gce_instance/firewallinsights
firewallinsights.googleapis.com/vm/firewall_hit_count
VM Firewall Last Used Timestamp
firewallinsights.googleapis.com/vm/firewall_last_used_timestamp
Client Connection Close Count
istio.io/service/client/connection_close_count
Client Connection Open Count
istio.io/service/client/connection_open_count
Client Received Bytes Count
istio.io/service/client/received_bytes_count
istio.io/service/client/request_bytes
istio.io/service/client/request_count
istio.io/service/client/response_bytes
Client Roundtrip Latencies
istio.io/service/client/roundtrip_latencies
istio.io/service/client/sent_bytes_count
Server Connection Close Count
istio.io/service/server/connection_close_count
Server Connection Open Count
istio.io/service/server/connection_open_count
Server Received Bytes Count
istio.io/service/server/received_bytes_count
istio.io/service/server/request_bytes
istio.io/service/server/request_count
istio.io/service/server/response_bytes
Server Response Latencies
istio.io/service/server/response_latencies
istio.io/service/server/sent_bytes_count
gce_instance_vm_flow/default_metrics
networking.googleapis.com/vm_flow/egress_bytes_count
networking.googleapis.com/vm_flow/ingress_bytes_count
networking.googleapis.com/vm_flow/rtt
instance_group/default_metrics
compute.googleapis.com/instance_group/size
autoscaler/default_metrics
autoscaler.googleapis.com/capacity
Current Autoscaler utilization
autoscaler.googleapis.com/current_utilization
tpu_worker/default_metrics
Container CPU utilization
tpu.googleapis.com/container/cpu/utilization
tpu.googleapis.com/container/memory/usage
tpu.googleapis.com/cpu/utilization
tpu.googleapis.com/memory/usage
tpu.googleapis.com/network/received_bytes_count
tpu.googleapis.com/network/sent_bytes_count
tpu.googleapis.com/tpu/mxu/utilization
