Extend traces using OpenTelemetry
OpenTelemetry is a collection of tools, APIs, and SDKs that enable you to use telemetry data (distributed traces, metrics, and logs) to get insights into your application's performance and behavior.
OpenTelemetry with the z/OS Java code module enables you to enrich or extend distributed traces.
Enrich distributed traces with project-specific additions (for example, you can add business-relevant data to your traces or capture developer-specific diagnostics).
Extend distributed traces (for example, you can capture a Java Transport that is not supported out of the box by Dynatrace or fill observability gaps between applications to achieve transactional insights).
OpenTelemetry metrics and logs are currently not supported by the z/OS Java code module.
OpenTelemetry distributed traces captured by the z/OS Java code module are included in the mainframe license.
OpenTelemetry interoperability
z/OS Java code module version 1.225+ OpenTelemetry version 1.0+
Enabling OpenTelemetry interoperability connects the z/OS Java code module to the OpenTelemetry API. When enabled, the code module redirects certain OpenTelemetry API usage (for example, GlobalOpenTelemetry
) to the internal Dynatrace OpenTelemetry SDK.
The z/OS Java code module forwards the captured OpenTelemetry Spans, via the zDC subsystem and zRemote module, to your Dynatrace environment.
Recommendation: avoid using the OpenTelemetry SDK in your applications together with the Dynatrace OpenTelemetry interoperability because it could result in conflicts.
Enable OpenTelemetry interoperability
OpenTelemetry interoperability is disabled by default. To enable it, add the OpenTelemetry: EnableIntegration
attribute to your dtconfig.json
file as shown in the following example.
Typically, you've created the dtconfig.json
file during the z/OS Java code module installation and have set the attributes Tenant
, ClusterID
, and zdcName
to your environment.
1{2 "OpenTelemetry": {3 "EnableIntegration": true4 }5}
Alternatively, you can add the open-telemetry-enable-integration
option to the JVM argument of the z/OS Java code module:
1-javaagent:/PATH_TO/dynatrace-oneagent-zos-java.jar=open-telemetry-enable-integration=true
OpenTelemetry instrumentation samples
To support various use cases, OpenTelemetry enables you to add vendor-neutral custom instrumentation to your applications. Instrumenting applications with OpenTelemetry requires programming knowledge and access to the application’s code. To learn how to instrument your application, refer to OpenTelemetry documentation and OpenTelemetry Java documentation.
See the examples below for using OpenTelemetry Java.
This example shows how you can capture an additional operation in a Java application running on a WebSphere Application Server monitored by Dynatrace.
- Define a
Tracer
.1import io.opentelemetry.api.GlobalOpenTelemetry;2import io.opentelemetry.api.trace.Tracer;34public final class RestaurantOpenTelemetry {5 public static Tracer getTracer() {6 return GlobalOpenTelemetry.getTracer("restaurant", "0.0.1");7 }8} - Use the
Tracer
to capture an operation including some attributes.1import io.opentelemetry.api.trace.Span;2import io.opentelemetry.api.trace.SpanKind;3import io.opentelemetry.context.Scope;45public class MenuDao {67 public Order newOrder(String customer) {89 // OpenTelemetry: create a span and define it's scope10 Span span = RestaurantOpenTelemetry.getTracer().spanBuilder("MenuDao.newOrder")11 .setSpanKind(SpanKind.INTERNAL)12 .setAttribute("customer", customer)13 .startSpan();14 try (Scope scope = span.makeCurrent()) {1516 // Your application code: create a new order17 Order order = new Order();18 order.setCustomer(customer);19 order.setStatus("pending");2021 // OpenTelemetry: add order ID to the span22 span.setAttribute("newOrderId", order.getId());2324 return order;25 } finally {2627 // OpenTelemetry: close the span28 span.end();29 }30 }31}
The MenuDao.newOrder
operation is displayed as a span on the Code level tab in the Dynatrace web UI with the captured span attributes (customer
, newOrderId
) and measured execution time.
This example shows how you can trace an audit service running on a WebSphere Application Server (monitored by Dynatrace) that uses a Java transport that is not supported out of the box. We use Java serialization (object output streams) as an example for such an unsupported Java transport.
To learn more about context propagation, refer to the official OpenTelemetry Context Propagation documentation.
Service A writes an audit entry to the ObjectOutputStream
1import io.opentelemetry.api.GlobalOpenTelemetry;2import io.opentelemetry.context.Context;3import io.opentelemetry.context.propagation.TextMapPropagator;45public class AuditService {67 public static void sendAuditEntry(Order order) {89 // Your application code: declare an audit entry10 Map<String, String> auditEntry = new HashMap<>();11 auditEntry.put("name", order.getId().toString());12 auditEntry.put("description", order.getCustomer());1314 // OpenTelemetry: Inject current context of audit entry and propagate it15 TextMapPropagator propagator = GlobalOpenTelemetry.getPropagators().getTextMapPropagator();16 propagator.inject(17 Context.current(),18 auditEntry,19 Map::put20 );2122 // Your application code: write audit entry to objectOutputStream (Socket)23 Socket socket = new Socket(host, port);24 ObjectOutputStream objectOutputStream = new ObjectOutputStream(socket.getOutputStream())) {25 objectOutputStream.writeObject(auditEntry);26 }27}
Service B reads an audit entry from the ObjectInputStream
1import io.opentelemetry.api.GlobalOpenTelemetry;2import io.opentelemetry.api.trace.Span;3import io.opentelemetry.api.trace.SpanKind;4import io.opentelemetry.context.Context;5import io.opentelemetry.context.Scope;6import io.opentelemetry.context.propagation.TextMapGetter;78public class AuditService {910 private static void receivedAuditEntry(Map<String, String> auditEntry) {1112 // OpenTelemetry: declare the tracer, create a span and define it's scope13 Span span = GlobalOpenTelemetry.getTracer("auditing-center", "0.0.1")14 .spanBuilder("auditEntry")15 .setSpanKind(SpanKind.SERVER)16 .setAttribute("auditName", auditEntry.get("name"))17 .startSpan();18 try (Scope scope = span.makeCurrent()) {1920 // Your application code: process audit entry21 // ...22 }23 span.end();24 }2526 public static void readAuditEntryFromSocket(Socket socket) {27 ObjectInputStream objectInputStream = new ObjectInputStream(socket.getInputStream());28 Object input = objectInputStream.readObject();2930 // OpenTelemetry: extract context of audit entry31 Context context = GlobalOpenTelemetry.getPropagators().getTextMapPropagator()32 .extract(33 Context.current(),34 input,35 new TextMapGetter<Map<String, String>>(){ /* ... */ });3637 try (Scope scope = context.makeCurrent()) {38 receivedAuditEntry((Map<String, String>) input);39 }40 // ...41 }42}
Dynatrace displays the full end-to-end trace as a distributed trace that contains the auditEntry
as a service method which includes the captured attributes and measured execution time. The auditEntry
service method is the result of the traced receivedAuditEntry
method with its new span. The fact that it is displayed as a child of the /orderReceived
service method is the result of the inject
and extract
calls of the TextMapPropagator
Suppress spans from specific instrumentations
You can suppress spans coming from a particular instrumentation scope/library. To do so, add the library name to the OpenTelemetry: DisabledSensors
parameter in name via the dtconfig.json
file. You can use an asterisk (*
) to exclude all instrumentation scope/library names starting with the preceding string. You can't use asterisk at the beginning or in the middle of a library name.
1{2 "OpenTelemetry": {3 "EnableIntegration": true,4 "DisabledSensors": [5 "com.example.MyLib",6 "opentelemetry.urllib3*"7 ]8 }9}
Alternatively, you can add the open-telemetry-disabled-sensors
1-javaagent:/PATH_TO/dynatrace-oneagent-zos-java.jar=open-telemetry-disabled-sensors=com.example.MyLib:opentelemetry.urllib3*
If you specify exclusions in the command line, the exclusions in the dtconfig.json
file ignored.
Use colon :
as the separator for instrumentation scope/library names in the command line.
The examples above suppress spans from the com.example.MyLib
instrumentation scope/library and spans from all libraries starting with the name opentelemetry.urllib3
Rules for spans that Dynatrace will report
Depending on the SpanKind
, Dynatrace will suppress some OpenTelemetry spans:
- A span needs to either be of kind
SpanKind.SERVER
orSpanKind.CONSUMER
or it needs to have another span (SpanContext
) as a non-remote parent. Usually, this is handled by the Dynatrace Servlet sensor, which creates aSERVER
span and sets it as the current, active span. - Child spans of spans of kind
SpanKind.CLIENT
orSpanKind.PRODUCER
will be suppressed. For example, after Dynatrace creates a span of kindSpanKind.CLIENT
for a synchronous outgoing HTTP call, all spans created in the thread will be suppressed until the HTTP call, and thus the HTTP Span, is finished. You can of course create new spans in the called service which will be linked correctly.
Suppressed spans will not be visible in distributed traces.
Define a request attribute for span attributes
You can define a request attribute for any captured span attribute. To do so
- In the Dynatrace menu, go to Settings > Server-side service monitoring > Request attributes.
- Select Define a new request attribute and enter the name and data type of your request attribute.
- Select Add new data source and select
Span attribute
as the Request attribute source. - Enter your Attribute key.
- Select Save.
To learn more details about span attributes and how to capture them, see Span settings.
You can find the Attribute key of your spans on the Distributed traces page in the Code level tab under Span attributes.
