Early Access
Hyperscalers provide offerings such as AWS Security Hub, through which security-related events give insights into potential threats. These events must be triaged, analyzed, and remediated by the owners of the affected resources, and reaching hundreds of thousands of such alerts is common.
Dynatrace addresses these concerns and improves your cloud security posture management (CSPM) by introducing an automation workflow that filters security findings stored in Grail and triggers alerts only for the events that matter.
This page is intended for Security teams analyzing security findings.
In the following, we address a scenario in which 400,000 AWS alerts are issued daily.
Manually dealing with all of them is simply infeasible. The Security team therefore has to focus only on high-priority events and has built custom tooling to partially automate Jira ticket creation.
Effort is sometimes invested in vain, and alerts turn out to be irrelevant, but the resource owner must always cross-check the resolution with the Security team. Ensuring that all are followed up on requires a significant coordination effort, leaving less time for actual security work.
Efficiency: The team should be able to act on everything that matters immediately.
Dynatrace CSPM Notification Automation is a tool designed to answer the Security team's pain and improve their efficiency significantly. It allows the team to continue monitoring events without being burdened with alerts; they can now focus only on what matters and requires their security expertise.
More concretely, from a total of 400,000 alerts per day, of which just 40,000 are relevant, with Dynatrace CSPM Notification Automation, only a couple of Jira tickets are now created daily, just for the relevant issues.
Dynatrace CSPM Notification Automation consists of two stages.
See below for the AWS and Dynatrace requirements.
Grail: storage:logs:read. For instructions, see Assign permissions in Grail.
Workflows: Permissions to access, view, write, and execute workflows. For details, see Authorization.
To access permissions, go to the Settings menu in the upper-right corner of
Workflows and select Authorization settings.
Once your AWS security findings are ingested into Grail (see Prerequisites), you can set up the CSPM Notification Automation workflow.
The workflow consists of several steps you can adapt according to your needs. To configure it, you can start by importing a prefilled workflow into your environment.
Copy and save the JSON file below.
{"id": "dcce961d-26a9-46e6-a9e4-14a0f7f2185c","title": "CSPM Notification Automation","description": "","tasks": {"count_all_new_findings": {"name": "count_all_new_findings","description": "Executes query to count all recently created AWS findings","action": "dynatrace.automations:execute-dql-query","active": true,"input": {"query": "fetch logs, from:now() - 24h, scanLimitGBytes: -1\n| filter aws.log_group == \"/aws/events/AWSSecurityHubLogGroup\"\n| fields timestamp\n| filter timestamp > now() - 24h // Only filter created since last successful run \n| summarize { count=count() }"},"position": {"x": -1,"y": 2},"predecessors": ["workflow_config_params"],"conditions": {"states": {"workflow_config_params": "OK"}}},"log_new_findings_count": {"name": "log_new_findings_count","description": "Logs total number of recently created AWS findings","action": "dynatrace.automations:run-javascript","active": true,"input": {"script": "import { execution } from '@dynatrace-sdk/automation-utils';\n\nexport default async function () {\n\n const ex = await execution();\n const countResult = await ex.result(\"count_all_new_findings\");\n\n console.log('======================================================================')\n console.log('Total findings added since last run: ')\n console.log(countResult.records[0].count)\n console.log('')\n}"},"position": {"x": -1,"y": 3},"predecessors": ["count_all_new_findings"],"conditions": {"states": {"count_all_new_findings": "OK"}}},"log_tickets_by_account": {"name": "log_tickets_by_account","description": "Logs potentially created Jira issues for findings by account","action": "dynatrace.automations:run-javascript","active": true,"input": {"script": "import { execution } from '@dynatrace-sdk/automation-utils';\n\nexport default async function () {\n const ex = await execution();\n const by_control_id = await ex.result(\"fetch_findings_by_account\");\n\n console.log('=================================================================================================')\n console.log(`Issues by accounts, ${by_control_id.records.length} findings`)\n console.log('=================================================================================================')\n\n for(let finding of by_control_id.records) {\n console.log('')\n console.log('=================================================================================================')\n console.log(`Automatic Vulnerability Report for ${finding.controlId} - AWS account ${finding.awsAccountId}`)\n console.log('=================================================================================================')\n console.log('')\n console.log('The following vulnerabilities were reported for your account via AWS Security Hub.')\n console.log('')\n console.log(`AWS Account: ${finding.awsAccountId}`)\n console.log('')\n console.log('Vulnerability:')\n console.log(`${finding.controlId} - ${finding.title}`)\n console.log(finding.severity)\n console.log(finding.description)\n console.log(finding.remediation[0].Recommendation.Url)\n console.log('')\n console.log('Affected resources:')\n for(let resource of finding.resources) {\n console.log(resource)\n }\n console.log('') \n console.log('=================================================================================================')\n console.log('')\n console.log('')\n }\n \n return by_control_id.records;\n}"},"position": {"x": 0,"y": 3},"predecessors": ["fetch_findings_by_account"],"conditions": {"states": {"fetch_findings_by_account": "OK"}}},"workflow_config_params": {"name": "workflow_config_params","description": "Sets configuration parameters for the workflow run","action": "dynatrace.automations:run-javascript","input": {"script": "// This step sets up some configurational parameters for the workflow run \n// (e.g. which accounts, which finding types we are filtering for)\nexport default async function () {\n\n // AWS accounts to filter for\n const awsAccountIds = [\n // add your AWS account ids here, e.g.\n // \"1234567890\"\n ]\n\n // Findings that should be grouped by AWS account\n const securityControlIdsToGroupByAccount = [\n // add you control IDs here, e.g.\n // \"S3.1\" // S3 Block Public Access setting should be enabled\n ]\n\n // Findings that should be grouped by AWS Resource\n const securityControlIdsToGroupByResource = [\n // add you control IDs here, e.g.\n // \"EC2.13\" // Security groups should not allow ingress from 0.0.0.0/0 to port 22\n ]\n \n return { awsAccountIds, securityControlIdsToGroupByAccount, securityControlIdsToGroupByResource }\n}"},"position": {"x": 0,"y": 1},"predecessors": []},"log_tickets_by_resource": {"name": "log_tickets_by_resource","description": "Logs potentially created Jira issues for findings by resource","action": "dynatrace.automations:run-javascript","active": true,"input": {"script": "import { execution } from '@dynatrace-sdk/automation-utils';\n\nexport default async function () {\n const ex = await execution();\n const by_resource = await ex.result(\"fetch_findings_by_resource\");\n\n console.log('=================================================================================================')\n console.log(`Issues by resource, ${by_resource.records.length} findings`)\n console.log('=================================================================================================')\n\n for(let finding of by_resource.records) {\n console.log('')\n console.log('=================================================================================================')\n console.log(`Automatic Vulnerability Report for ${finding.resource.resourceId}`)\n console.log('=================================================================================================')\n console.log('')\n console.log('The following vulnerabilities were reported for your resource via AWS Security Hub.')\n console.log('')\n console.log(`AWS Account: ${finding.aws.accountId}`)\n console.log('')\n console.log('Resource details:')\n console.log(finding.resource.resourceType)\n console.log(finding.resource.resourceId)\n console.log('')\n console.log('Vulnerabilities:')\n for(let vulnerability of finding.vulnerabilities) {\n console.log(`${vulnerability.controlId} - ${vulnerability.title}`)\n console.log(vulnerability.severity)\n console.log(vulnerability.description)\n console.log(vulnerability.remediation[0].Recommendation.Url) \n }\n console.log('=================================================================================================')\n console.log('')\n console.log('')\n }\n \n return by_resource.records;\n}"},"position": {"x": 1,"y": 3},"predecessors": ["fetch_findings_by_resource"],"conditions": {"states": {"fetch_findings_by_resource": "OK"}}},"create_issue_for_account": {"name": "create_issue_for_account","description": "Creates new Jira issue or the vulnerable AWS account","action": "dynatrace.jira:jira-create-issue","active": false,"input": {"labels": [],"summary": "{{ _.item.summary }}","components": [],"description": "{{ _.item.description }}","fieldSetters": []},"position": {"x": 0,"y": 5},"predecessors": ["prepare_tickets_by_account"],"conditions": {"states": {"prepare_tickets_by_account": "OK"}},"concurrency": 1,"withItems": "item in {{result(\"prepare_tickets_by_account\")}}"},"create_issue_for_resource": {"name": "create_issue_for_resource","description": "Creates new issue for the vulnerable AWS resource","action": "dynatrace.jira:jira-create-issue","active": false,"input": {"labels": [],"summary": "{{ _.item.summary }}","components": [],"description": "{{ _.item.description }}","fieldSetters": []},"position": {"x": 1,"y": 5},"predecessors": ["prepare_tickets_by_resource"],"conditions": {"states": {"prepare_tickets_by_resource": "OK"}},"concurrency": 1,"withItems": "item in {{result(\"prepare_tickets_by_resource\")}}"},"fetch_findings_by_account": {"name": "fetch_findings_by_account","description": "Executes query to get relevant security findings grouped by AWS account","action": "dynatrace.automations:execute-dql-query","active": true,"input": {"query": "fetch logs, from:now() - 24h, scanLimitGBytes: -1\n| filter aws.log_group == \"/aws/events/AWSSecurityHubLogGroup\"\n| parse content, \"JSON:alert\"\n| fields timestamp,\n awsRegion = toString(alert[detail][findings][0][Region]),\n awsAccountId = toString(alert[detail][findings][0][AwsAccountId]),\n resourceType = toString(alert[detail][findings][0][Resources][0][Type]), \n resource = toString(alert[detail][findings][0][Resources][0][Id]),\n alertType = toString(alert[detail][findings][0][Types][0]),\n id = toString(alert[detail][findings][0][Id]),\n severity = toString(alert[detail][findings][0][FindingProviderFields][Severity][Label]),\n title = toString(alert[detail][findings][0][Title]),\n description = toString(alert[detail][findings][0][Description]),\n complianceStatus = toString(alert[detail][findings][0][Compliance][Status]),\n controlId = toString(alert[detail][findings][0][Compliance][SecurityControlId]),\n remediation = alert[detail][findings][0][Remediation],\n created = toTimestamp(alert[detail][findings][0][CreatedAt]),\n lastObservedAt = toTimestamp(alert[detail][findings][0][LastObservedAt])\n| filter in(severity, array(\"HIGH\", \"CRITICAL\", \"MEDIUM\"))\n| filter created > now() - 24h\n| filter in(awsAccountId, array(\"{{ result('workflow_config_params').awsAccountIds | join('\",\"') }}\"))\n| filter in(controlId, array(\"{{ result('workflow_config_params').securityControlIdsToGroupByAccount | join('\",\"') }}\"))\n| summarize { count=count(),\n lastObservedAt = max(lastObservedAt),\n remediation = collectDistinct(remediation),\n complianceStatus = takeLast(complianceStatus),\n resources = collectDistinct(resource),\n title = takeAny(title),\n description = takeAny(description),\n severity = takeAny(severity),\n awsRegion = collectArray(awsRegion)\n },\n by:{\n controlId, \n awsAccountId\n }\n| lookup\n [ fetch dt.entity.aws_credentials \n | fields awsAccountId, entity.name\n ], lookupField:awsAccountId, sourceField:awsAccountId, prefix: \"aws.account.\"\n"},"position": {"x": 0,"y": 2},"predecessors": ["workflow_config_params"],"conditions": {"states": {"workflow_config_params": "OK"}}},"fetch_findings_by_resource": {"name": "fetch_findings_by_resource","description": "Executes query to get relevant security findings grouped by AWS resource","action": "dynatrace.automations:execute-dql-query","active": true,"input": {"query": "fetch logs, from:now() - 24h, scanLimitGBytes: -1\n| filter aws.log_group == \"/aws/events/AWSSecurityHubLogGroup\"\n| parse content, \"JSON:alert\"\n| fields timestamp,\n awsRegion = toString(alert[detail][findings][0][Region]),\n awsAccountId = toString(alert[detail][findings][0][AwsAccountId]),\n resourceType = toString(alert[detail][findings][0][Resources][0][Type]), \n resourceId = toString(alert[detail][findings][0][Resources][0][Id]),\n alertType = toString(alert[detail][findings][0][Types][0]),\n id = toString(alert[detail][findings][0][Id]),\n severity = toString(alert[detail][findings][0][FindingProviderFields][Severity][Label]),\n title = toString(alert[detail][findings][0][Title]),\n description = toString(alert[detail][findings][0][Description]),\n complianceStatus = toString(alert[detail][findings][0][Compliance][Status]),\n controlId = toString(alert[detail][findings][0][Compliance][SecurityControlId]),\n remediation = alert[detail][findings][0][Remediation],\n created = toTimestamp(alert[detail][findings][0][CreatedAt]),\n lastObservedAt = toTimestamp(alert[detail][findings][0][LastObservedAt])\n| filter in(severity, array(\"HIGH\", \"CRITICAL\", \"MEDIUM\"))\n| filter created > now() - 24h\n| filter in(awsAccountId, array(\"{{ result('workflow_config_params').awsAccountIds | join('\",\"') }}\"))\n| filter in(controlId, array(\"{{ result('workflow_config_params').securityControlIdsToGroupByResource | join('\",\"') }}\"))\n| summarize { count=count(),\n lastObservedAt = max(lastObservedAt),\n remediation = collectDistinct(remediation),\n complianceStatus = takeLast(complianceStatus)\n },\n by:{\n alertType, \n resourceType, \n controlId, \n title,\n description, \n severity, \n resourceId, \n awsAccountId,\n created,\n awsRegion\n }\n| lookup\n [ fetch dt.entity.aws_credentials \n | fields id, awsAccountId, entity.name, tags, awsNameTag\n ], lookupField:awsAccountId, sourceField:awsAccountId, prefix: \"aws.account.\"\n| fields aws = record(\n accountId = awsAccountId,\n name = aws.account.entity.name,\n entity = aws.account.id\n ), \n resource = record(\n resourceId = resourceId,\n resourceType = resourceType\n ),\n region = awsRegion,\n alert = record(controlId = controlId, \n severity = severity, \n complianceStatus = complianceStatus,\n title = title,\n description = description,\n remediation = remediation\n )\n| summarize {\n count=count(),\n vulnerabilities = collectDistinct(alert)\n },\n by:{\n aws,\n resource,\n region\n }"},"position": {"x": 1,"y": 2},"predecessors": ["workflow_config_params"],"conditions": {"states": {"workflow_config_params": "OK"}}},"prepare_tickets_by_account": {"name": "prepare_tickets_by_account","description": "Prepares payload of Jira tickets for vulnerable AWS accounts","action": "dynatrace.automations:run-javascript","active": true,"input": {"script": "import { execution } from '@dynatrace-sdk/automation-utils';\n\nexport default async function () {\n const ex = await execution();\n const records = await ex.result(\"log_tickets_by_account\");\n\n console.log(`${records.length} Tickets will be created!`)\n const result = [];\n for (const finding of records) {\n console.log('------------------------------------- NEW TICKET -------------------------------------')\n const resourcesList = finding.resources\n .map( resource => `|${resource}|` )\n .join('\\n')\n const ticket = {\n summary: `Automatic Vulnerability Report for ${finding.controlId} - AWS Account ${finding.awsAccountId}`,\n description: 'The following vulnerabilities were reported for your resource via AWS Security Hub:\\n\\n'\n + '*AWS Account*:\\n'\n + '||AWS Account Id||\\n'\n + `|${finding.awsAccountId}|\\n\\n`\n + '*Vulnerability*:\\n'\n + '||Id||Sev||Title||Description||Remediation Url||\\n'\n + `|{noformat}${finding.controlId}{noformat}|{noformat}${finding.severity}{noformat}|${finding.title}|${finding.description}|[${finding.remediation[0].Recommendation.Url}]|\\n\\n`\n + '*Affected Resources*:\\n'\n + '||Resource Id||\\n'\n + resourcesList\n + '\\n\\n---\\nAutomatically generated by CSPM Notification Automation'\n }\n console.log(JSON.stringify(ticket))\n result.push(ticket)\n }\n\n return result;\n}"},"position": {"x": 0,"y": 4},"predecessors": ["log_tickets_by_account"],"conditions": {"states": {"log_tickets_by_account": "OK"}}},"prepare_tickets_by_resource": {"name": "prepare_tickets_by_resource","description": "Prepares payload of Jira tickets for vulnerable AWS resources","action": "dynatrace.automations:run-javascript","active": true,"input": {"script": "import { execution } from '@dynatrace-sdk/automation-utils';\n\nexport default async function () {\n const ex = await execution();\n const records = await ex.result(\"log_tickets_by_resource\");\n\n console.log(`${records.length} Tickets will be created!`)\n const result = [];\n for (const finding of records) {\n console.log('------------------------------------- NEW TICKET -------------------------------------')\n const vulnerabilitiesList = finding.vulnerabilities\n .map( vuln => \n `|{noformat}${vuln.controlId}{noformat}|{noformat}${vuln.severity}{noformat}|${vuln.title}|${vuln.description}|[${vuln.remediation[0].Recommendation.Url}]|`)\n .join('\\n')\n const ticket = {\n summary: `Automatic Vulnerability Report for ${finding.resource.resourceId}`,\n description: 'The following vulnerabilities were reported for your resource via AWS Security Hub:\\n\\n'\n + '*AWS Account*:\\n'\n + '||AWS Account Id||\\n'\n + `|${finding.aws.accountId}|\\n\\n`\n + '*Resource Details*:\\n'\n + '||Resource Type||Resource Id||\\n'\n + `|${finding.resource.resourceType}|${finding.resource.resourceId}|\\n\\n`\n + '*Vulnerabilities*:\\n'\n + '||Id||Sev||Title||Description||Remediation Url||\\n'\n + vulnerabilitiesList\n + '\\n\\n---\\nAutomatically generated by CSPM Notification Automation'\n }\n console.log(JSON.stringify(ticket))\n result.push(ticket)\n }\n\n return result;\n}"},"position": {"x": 1,"y": 4},"predecessors": ["log_tickets_by_resource"],"conditions": {"states": {"log_tickets_by_resource": "OK"}}}},"ownerType": "USER","isPrivate": false,"trigger": {"schedule": {"rule": null,"trigger": {"type": "time","time": "09:00"},"timezone": "Europe/Berlin","isActive": true,"isFaulty": false,"nextExecution": "2023-10-03T07:00:00.000Z","filterParameters": {"earliestStart": "2023-09-25"},"inputs": {}}},"schemaVersion": 3}
In
Workflows, select Upload and upload the file.
Fixed time trigger: Sets the time when you want the workflow to run (in the current case, the workflow runs every day at 9:00 AM). See Schedule workflows for more information on scheduling a workflow.
Workflow config params: Determines what findings you want to filter for. In the current scenario, the team wants to
awsAccountIds, select which AWS accounts you want to get findings for.securityControlIdsToGroupByAccount, select which security control IDs you want to group by AWS account.securityControlIdsToGroupByResource, select which security control IDs you want to group by AWS resource.
The following task sequence orchestrates grouping and converting the resulting findings into one ticket per AWS account.
Fetch findings by account: Executes the DQL query that fetches the findings. Some of the information fetched for the current case, to be displayed in Jira, includes
Log tickets by account: Shows a ticket's potential content before one is automatically created. This step ensures that your configuration is correct. For details, see Plot statistics before creating tickets.
Prepare tickets by account: Configures the payload for the Jira ticket.
Create issues for account: Integrates with your Jira connection. In Input, select your Jira connection created in Prerequisites and enter the desired parameters of the Jira ticket.
The following task sequence displays a count of the new findings since the last workflow run.
Once you're done configuring the workflow, select Save.
To test your configuration before sending Jira tickets
For instructions on disabling a task, see Disable or enable a task.
Congratulations! You’ve now set up an automation that empowers your security team. With Dynatrace CSPM Notification Automation, critical events are streamlined, alert fatigue is minimized, and cloud security is enhanced. Efficiency unleashed!
The following is a tutorial by the internal customer of Dynatrace CSPM Notification Automation.
