This page outlines the minimum version requirements for basic persistent volume claims monitoring capabilities.
Dynatrace version 1.294 +
ActiveGate version 1.289+
In Kubernetes, persistent data is stored in persistent volume claims (PVCs). Dynatrace provides you the needed insights into your persistent volume claims capacity.
To start monitoring persistent volume claims, see below.
PVC monitoring is a built-in feature and does not need to be enabled manually.
Make sure that the get rule and the nodes/metrics resources are enabled in the Kubernetes ClusterRole. If you're monitoring PVCs with an ActiveGate running outside of the cluster, you'll also need the nodes/proxy permission.
Example:
Dynatrace provides a pre-configured dashboard that covers the following use-cases:
This feature is available only if your Kubernetes cluster is connected to a local Kubernetes API endpoint.
