Alert on common Kubernetes/OpenShift issues
  • Dynatrace Classic
  • 18-min read
Dynatrace version 1.254+
ActiveGate version 1.253+
To alert on common Kubernetes platform issues, follow the instructions below.
Configure
There are three ways to configure alerts for common Kubernetes/OpenShift issues.
Configuring an alert on a different level is only intended to simplify the configuration of multiple entities at once. It does not change the behavior of an alert.
For example, enabling a workload CPU usage saturation alert will still evaluate and raise problems for each Kubernetes workload separately, even if it has been configured on the Kubernetes cluster level.
For further details on the settings hierarchy, see Settings documentation.
  • Settings apply to all clusters, nodes, namespaces, or workloads in the Kubernetes/OpenShift tenant.
  • To configure settings, go to Settings > Anomaly detection and select any page under the Kubernetes section.
Example:
Kubernetes anomaly detection settings tenant
View alerts
Manually closed problems will show up again after 60 days if their root cause remains unresolved.
You can view alerts
  • On the Problems page.
    Example problem:
    k8s-alert-view-in-problems
  • In the Events section of a cluster details page.
    Example event:
    k8s-alert-view-in-events
    Select the event to navigate to Data Explorer for more information about the metric that generated the event.
Available alerts
See below for a list of available alerts.
Cluster alerts
Cluster metric and DQL expressions
Detect cluster CPU-request saturation
TypeExpression
Metric expressionbuiltin:kubernetes.node.requests_cpu:splitBy():sum/builtin:kubernetes.node.cpu_allocatable:splitBy():sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.container.requests_cpu, rollup: avg), o2=sum(dt.kubernetes.node.cpu_allocatable, rollup: avg)}, by: {}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect cluster memory-request saturation
TypeExpression
Metric expressionbuiltin:kubernetes.node.requests_memory:splitBy():sum/builtin:kubernetes.node.memory_allocatable:splitBy():sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.container.requests_memory, rollup: avg), o2=sum(dt.kubernetes.node.memory_allocatable, rollup: avg)}, by: {}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect cluster pod-saturation
TypeExpression
Metric expression(builtin:kubernetes.node.pods:filter(and(eq(pod_condition,Ready))):splitBy():sum/builtin:kubernetes.node.pods_allocatable:splitBy():sum):default(0.0)*100.0
DQLtimeseries o1=sum(dt.kubernetes.pods, rollup: avg), nonempty:true, filter: {((pod_condition=="Ready"))}, by: {}| join [timeseries operand=sum(dt.kubernetes.node.pods_allocatable, rollup: avg), nonempty:true, by: {}], on: {interval}, fields: {o2=operand}| fieldsAdd result=if(isNull(o1[]/o2[]), 0.0, else: o1[]/o2[])* 100.0| fieldsRemove {o1,o2}
Detect cluster readiness issues
TypeExpression
Metric expressionbuiltin:kubernetes.cluster.readyz:splitBy():sum
DQLtimeseries {sum(dt.kubernetes.cluster.readyz, rollup: avg)}, by: {}
Detect monitoring issues
TypeExpression
Metric expression(no metric expression)
DQL(no DQL)
Default alerts for new tenants
Namespace alerts
Namespace metric and DQL expressions
Detect namespace CPU-limit quota saturation
TypeExpression
Metric expressionbuiltin:kubernetes.resourcequota.limits_cpu_used:splitBy(k8s.namespace.name):sum/builtin:kubernetes.resourcequota.limits_cpu:splitBy(k8s.namespace.name):sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.resourcequota.limits_cpu_used, rollup: avg), o2=sum(dt.kubernetes.resourcequota.limits_cpu, rollup: avg)}, by: {k8s.namespace.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect namespace CPU-request quota saturation
TypeExpression
Metric expressionbuiltin:kubernetes.resourcequota.requests_cpu_used:splitBy(k8s.namespace.name):sum/builtin:kubernetes.resourcequota.requests_cpu:splitBy(k8s.namespace.name):sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.resourcequota.requests_cpu_used, rollup: avg), o2=sum(dt.kubernetes.resourcequota.requests_cpu, rollup: avg)}, by: {k8s.namespace.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect namespace memory-limit quota saturation
TypeExpression
Metric expressionbuiltin:kubernetes.resourcequota.limits_memory_used:splitBy(k8s.namespace.name):sum/builtin:kubernetes.resourcequota.limits_memory:splitBy(k8s.namespace.name):sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.resourcequota.limits_memory_used, rollup: avg), o2=sum(dt.kubernetes.resourcequota.limits_memory, rollup: avg)}, by: {k8s.namespace.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect namespace memory-request quota saturation
TypeExpression
Metric expressionbuiltin:kubernetes.resourcequota.requests_memory_used:splitBy(k8s.namespace.name):sum/builtin:kubernetes.resourcequota.requests_memory:splitBy(k8s.namespace.name):sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.resourcequota.requests_memory_used, rollup: avg), o2=sum(dt.kubernetes.resourcequota.requests_memory, rollup: avg)}, by: {k8s.namespace.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect namespace pod quota saturation
TypeExpression
Metric expressionbuiltin:kubernetes.resourcequota.pods_used:splitBy(k8s.namespace.name):sum/builtin:kubernetes.resourcequota.pods:splitBy(k8s.namespace.name):sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.resourcequota.pods_used, rollup: avg), o2=sum(dt.kubernetes.resourcequota.pods, rollup: avg)}, by: {k8s.namespace.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Node alerts
Node metric and DQL expressions
Detect node CPU-request saturation
TypeExpression
Metric expressionbuiltin:kubernetes.node.requests_cpu:splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum/builtin:kubernetes.node.cpu_allocatable:splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.container.requests_cpu, rollup: avg), o2=sum(dt.kubernetes.node.cpu_allocatable, rollup: avg)}, by: {dt.kubernetes.node.system_uuid,k8s.node.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect node memory-request saturation
TypeExpression
Metric expressionbuiltin:kubernetes.node.requests_memory:splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum/builtin:kubernetes.node.memory_allocatable:splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum*100.0
DQLtimeseries {o1=sum(dt.kubernetes.container.requests_memory, rollup: avg), o2=sum(dt.kubernetes.node.memory_allocatable, rollup: avg)}, by: {dt.kubernetes.node.system_uuid,k8s.node.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect node pod-saturation
TypeExpression
Metric expressionbuiltin:kubernetes.node.pods:filter(and(eq(pod_phase,Running))):splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum/builtin:kubernetes.node.pods_allocatable:splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum*100.0
DQLtimeseries o1=sum(dt.kubernetes.pods, rollup: avg), nonempty:true, filter: {((pod_phase=="Running"))}, by: {dt.kubernetes.node.system_uuid,k8s.node.name}| join [timeseries operand=sum(dt.kubernetes.node.pods_allocatable, rollup: avg), nonempty:true, by: {dt.kubernetes.node.system_uuid,k8s.node.name}], on: {interval}, fields: {o2=operand}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect node readiness issues
TypeExpression
Metric expressionbuiltin:kubernetes.node.conditions:filter(and(eq(node_condition,Ready),ne(condition_status,True))):splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum
DQLtimeseries {sum(dt.kubernetes.node.conditions, rollup: avg)}, filter: {((node_condition=="Ready")AND(condition_status!=true))}, by: {dt.kubernetes.node.system_uuid,k8s.node.name}
Detect problematic node conditions
TypeExpression
Metric expressionbuiltin:kubernetes.node.conditions:filter(and(or(eq(node_condition,ContainerRuntimeProblem),eq(node_condition,ContainerRuntimeUnhealthy),eq(node_condition,CorruptDockerOverlay2),eq(node_condition,DiskPressure),eq(node_condition,FilesystemCorruptionProblem),eq(node_condition,FrequentContainerdRestart),eq(node_condition,FrequentDockerRestart),eq(node_condition,FrequentGcfsSnapshotterRestart),eq(node_condition,FrequentGcfsdRestart),eq(node_condition,FrequentKubeletRestart),eq(node_condition,FrequentUnregisterNetDevice),eq(node_condition,GcfsSnapshotterMissingLayer),eq(node_condition,GcfsSnapshotterUnhealthy),eq(node_condition,GcfsdUnhealthy),eq(node_condition,KernelDeadlock),eq(node_condition,KubeletProblem),eq(node_condition,KubeletUnhealthy),eq(node_condition,MemoryPressure),eq(node_condition,NetworkUnavailable),eq(node_condition,OutOfDisk),eq(node_condition,PIDPressure),eq(node_condition,ReadonlyFilesystem)),eq(condition_status,True))):splitBy(dt.kubernetes.node.system_uuid,k8s.node.name):sum
DQLtimeseries {sum(dt.kubernetes.node.conditions, rollup: avg)}, filter: {(((node_condition=="ContainerRuntimeProblem")OR(node_condition=="ContainerRuntimeUnhealthy")OR(node_condition=="CorruptDockerOverlay2")OR(node_condition=="DiskPressure")OR(node_condition=="FilesystemCorruptionProblem")OR(node_condition=="FrequentContainerdRestart")OR(node_condition=="FrequentDockerRestart")OR(node_condition=="FrequentGcfsSnapshotterRestart")OR(node_condition=="FrequentGcfsdRestart")OR(node_condition=="FrequentKubeletRestart")OR(node_condition=="FrequentUnregisterNetDevice")OR(node_condition=="GcfsSnapshotterMissingLayer")OR(node_condition=="GcfsSnapshotterUnhealthy")OR(node_condition=="GcfsdUnhealthy")OR(node_condition=="KernelDeadlock")OR(node_condition=="KubeletProblem")OR(node_condition=="KubeletUnhealthy")OR(node_condition=="MemoryPressure")OR(node_condition=="NetworkUnavailable")OR(node_condition=="OutOfDisk")OR(node_condition=="PIDPressure")OR(node_condition=="ReadonlyFilesystem"))AND(condition_status==true))}, by: {dt.kubernetes.node.system_uuid,k8s.node.name}
Persistent volume claims alerts
Persistent volume claims metric and DQL expressions
Detect low disk space (%)
TypeExpression
Metric expressionbuiltin:kubernetes.persistentvolumeclaim.available:splitBy(k8s.namespace.name,k8s.persistent_volume_claim.name):avg/builtin:kubernetes.persistentvolumeclaim.capacity:splitBy(k8s.namespace.name,k8s.persistent_volume_claim.name):avg*100.0
DQLtimeseries {o1=avg(dt.kubernetes.persistentvolumeclaim.available), o2=avg(dt.kubernetes.persistentvolumeclaim.capacity)}, by: {k8s.namespace.name,k8s.persistent_volume_claim.name}| fieldsAdd result=o1[]/o2[]* 100.0| fieldsRemove {o1,o2}
Detect low disk space (MiB)
TypeExpression
DQLtimeseries {avg(dt.kubernetes.persistentvolumeclaim.available)}, by: {k8s.namespace.name,k8s.persistent_volume_claim.name}
Workload alerts
Workload metric and DQL expressions
Detect CPU usage saturation
TypeExpression
Metric expression(builtin:kubernetes.workload.cpu_usage:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum/builtin:kubernetes.workload.limits_cpu:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum):default(0.0)*100.0
DQLtimeseries {o1=sum(dt.kubernetes.container.cpu_usage, rollup: avg), o2=sum(dt.kubernetes.container.limits_cpu, rollup: avg)}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}| fieldsAdd result=if(isNull(o1[]/o2[]), 0.0, else: o1[]/o2[])* 100.0| fieldsRemove {o1,o2}
Detect container restarts
TypeExpression
Metric expressionbuiltin:kubernetes.container.restarts:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries {sum(dt.kubernetes.container.restarts, default:0.0, rollup: avg)}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect high CPU throttling
TypeExpression
Metric expression(builtin:kubernetes.workload.cpu_throttled:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum/builtin:kubernetes.workload.limits_cpu:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum):default(0.0)*100.0
DQLtimeseries {o1=sum(dt.kubernetes.container.cpu_throttled, rollup: avg), o2=sum(dt.kubernetes.container.limits_cpu, rollup: avg)}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}| fieldsAdd result=if(isNull(o1[]/o2[]), 0.0, else: o1[]/o2[])* 100.0| fieldsRemove {o1,o2}
Detect job failure events
TypeExpression
Metric expressionbuiltin:kubernetes.events:filter(and(or(eq(k8s.event.reason,BackoffLimitExceeded),eq(k8s.event.reason,DeadlineExceeded),eq(k8s.event.reason,PodFailurePolicy)),or(eq(k8s.workload.kind,job),eq(k8s.workload.kind,cronjob)))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries {sum(dt.kubernetes.events, default:0.0, rollup: avg)}, filter: {(((k8s.event.reason=="BackoffLimitExceeded")OR(k8s.event.reason=="DeadlineExceeded")OR(k8s.event.reason=="PodFailurePolicy"))AND((k8s.workload.kind=="job")OR(k8s.workload.kind=="cronjob")))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect memory usage saturation
TypeExpression
Metric expression(builtin:kubernetes.workload.memory_working_set:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum/builtin:kubernetes.workload.limits_memory:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum):default(0.0)*100.0
DQLtimeseries {o1=sum(dt.kubernetes.container.memory_working_set, rollup: avg), o2=sum(dt.kubernetes.container.limits_memory, rollup: avg)}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}| fieldsAdd result=if(isNull(o1[]/o2[]), 0.0, else: o1[]/o2[])* 100.0| fieldsRemove {o1,o2}
Detect out-of-memory kills
TypeExpression
Metric expressionbuiltin:kubernetes.container.oom_kills:splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries {sum(dt.kubernetes.container.oom_kills, default:0.0, rollup: avg)}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect pod backoff events
TypeExpression
Metric expressionbuiltin:kubernetes.events:filter(and(eq(k8s.event.reason,BackOff))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries {sum(dt.kubernetes.events, default:0.0, rollup: avg)}, filter: {((k8s.event.reason=="BackOff"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect pod eviction events
TypeExpression
Metric expressionbuiltin:kubernetes.events:filter(and(eq(k8s.event.reason,Evicted))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries {sum(dt.kubernetes.events, default:0.0, rollup: avg)}, filter: {((k8s.event.reason=="Evicted"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect pod preemption events
TypeExpression
Metric expressionbuiltin:kubernetes.events:filter(or(eq(k8s.event.reason,Preempted),eq(k8s.event.reason,Preempting))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries {sum(dt.kubernetes.events, default:0.0, rollup: avg)}, filter: {((k8s.event.reason=="Preempted")OR(k8s.event.reason=="Preempting"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect pods stuck in pending
TypeExpression
Metric expressionbuiltin:kubernetes.pods:filter(and(eq(pod_phase,Pending))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum
DQLtimeseries {sum(dt.kubernetes.pods, rollup: avg)}, filter: {((pod_phase=="Pending"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect pods stuck in terminating
TypeExpression
Metric expressionbuiltin:kubernetes.pods:filter(and(eq(pod_status,Terminating))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum
DQLtimeseries {sum(dt.kubernetes.pods, rollup: avg)}, filter: {((pod_status=="Terminating"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect stuck deployments
TypeExpression
Metric expressionbuiltin:kubernetes.workload.conditions:filter(and(eq(workload_condition,Progressing),eq(condition_status,False))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum
DQLtimeseries {sum(dt.kubernetes.workload.conditions, rollup: avg)}, filter: {((workload_condition=="Progressing")AND(condition_status==false))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}
Detect workloads with non-ready pods
The following expression returns the number of pending and running pods in the non-ready condition. Pods of Jobs and CronJobs are excluded.
TypeExpression
Metric expressionbuiltin:kubernetes.pods:filter(and(ne(pod_phase,Failed),ne(pod_phase,Succeeded),ne(k8s.workload.kind,job),ne(k8s.workload.kind,cronjob),ne(pod_status,Terminating))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum-builtin:kubernetes.pods:filter(and(ne(pod_phase,Failed),ne(pod_phase,Succeeded),ne(k8s.workload.kind,job),ne(k8s.workload.kind,cronjob),eq(pod_condition,Ready),ne(pod_status,Terminating))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries o1=sum(dt.kubernetes.pods, rollup: avg), filter: {((pod_phase!="Failed")AND(pod_phase!="Succeeded")AND(k8s.workload.kind!="job")AND(k8s.workload.kind!="cronjob")AND(pod_status!="Terminating"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}| join [timeseries operand=sum(dt.kubernetes.pods, default:0.0, rollup: avg), nonempty:true, filter: {((pod_phase!="Failed")AND(pod_phase!="Succeeded")AND(k8s.workload.kind!="job")AND(k8s.workload.kind!="cronjob")AND(pod_condition=="Ready")AND(pod_status!="Terminating"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}], on: {interval}, fields: {o2=operand}| fieldsAdd result=o1[]-o2[]| fieldsRemove {o1,o2}
Detect workloads without ready pods
The following expression returns the number of pending and running pods in the ready condition. Pods of Jobs and CronJobs are excluded.
TypeExpression
Metric expressionbuiltin:kubernetes.pods:filter(and(ne(pod_phase,Failed),ne(pod_phase,Succeeded),ne(k8s.workload.kind,job),ne(k8s.workload.kind,cronjob))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum-builtin:kubernetes.pods:filter(and(ne(pod_phase,Failed),ne(pod_phase,Succeeded),ne(k8s.workload.kind,job),ne(k8s.workload.kind,cronjob),ne(pod_condition,Ready))):splitBy(k8s.namespace.name,k8s.workload.kind,k8s.workload.name):sum:default(0.0)
DQLtimeseries o1=sum(dt.kubernetes.pods, rollup: avg), filter: {((pod_phase!="Failed")AND(pod_phase!="Succeeded")AND(k8s.workload.kind!="job")AND(k8s.workload.kind!="cronjob"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}| join [timeseries operand=sum(dt.kubernetes.pods, default:0.0, rollup: avg), nonempty:true, filter: {((pod_phase!="Failed")AND(pod_phase!="Succeeded")AND(k8s.workload.kind!="job")AND(k8s.workload.kind!="cronjob")AND(pod_condition!="Ready"))}, by: {k8s.namespace.name,k8s.workload.kind,k8s.workload.name}], on: {interval}, fields: {o2=operand}| fieldsAdd result=o1[]-o2[]| fieldsRemove {o1,o2}
Related tags
Infrastructure ObservabilityContainers
