Monitor your HPE H3C switches using SNMP.
The HPE H3C extension leverages SNMP to gather performance and health metrics from your H3C switches every minute. This data is seamlessly integrated into Infrastructure & Operations, offering quick, actionable insights at a glance.
Activate the extension in your environment Web UI using the Dynatrace Hub. Provide the necessary device configuration, and Dynatrace will automatically deploy the extension and begin monitoring.
For more details, see Manage SNMP extensions.
The extension package contains:
The extension is built on top of the SNMP data source that is part of the Dynatrace Extensions framework. For more details, see Extensions.
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The HPE H3C Switch extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
Calculations are based on the assumption that you monitor all metrics for every feature set every minute. Metric data points per minute per switch:
4 + (8 * n_interfaces)
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
| Metric name | Metric key | Description |
| — | com.dynatrace.extension.network_device.if.in.multicast_pkts.count | — |
| — | com.dynatrace.extension.network_device.if.out.multicast_pkts.count | — |
| — | com.dynatrace.extension.network_device.if.in.broadcast_pkts.count | — |
| — | com.dynatrace.extension.network_device.if.out.broadcast_pkts.count | — |
| — | com.dynatrace.extension.network_device.if.in.ucast_pkts.count | — |
| — | com.dynatrace.extension.network_device.if.out.ucast_pkts.count | — |
| — | com.dynatrace.extension.network_device.sysuptime | — |
| — | com.dynatrace.extension.network_device.cpu_usage | — |
| Used memory | com.dynatrace.extension.network_device.hp_switch.memory_used | The amount of memory, in bytes, used by the HP Switch device |
| Total memory | com.dynatrace.extension.network_device.hp_switch.memory_total | The amount of memory, in bytes, available on the HP Switch device |
| — | com.dynatrace.extension.network_device.if.status | — |
| — | com.dynatrace.extension.network_device.if.bytes_in.count | — |
| — | com.dynatrace.extension.network_device.if.bytes_out.count | — |
| Inbound errors | com.dynatrace.extension.network_device.if.in.errors.count | Number of inbound packets/transmission units with errors |
| Inbound discards | com.dynatrace.extension.network_device.if.in.discards.count | Number of inbound packets discarded |
| Outbound errors | com.dynatrace.extension.network_device.if.out.errors.count | Number of outbound packets/transmission units with errors |
| Outbound discards | com.dynatrace.extension.network_device.if.out.discards.count | Number of outbound packets discarded |
| — | com.dynatrace.extension.network_device.if.lastchange | — |
| Interface speed | com.dynatrace.extension.network_device.if.speed | Speed of the network interface in MegaBits per second. |
