MySQL (remote monitoring) extension
  • Latest Dynatrace
  • Extension
Monitor remote MySQL databases by collecting performance metrics, slow query data, and execution plans to identify bottlenecks and optimize database health.
Get started
Overview
The MySQL (remote monitoring) extension uses a designated ActiveGate group to connect to your MySQL instances, making it suitable for environments where installing OneAgent is not possible. It supports self-hosted MySQL, Amazon RDS, and Amazon Aurora deployments.
Requirements
  • Install an ActiveGate in your environment.
  • Designate an ActiveGate group or groups that will remotely connect to your MySQL Database server to pull data. All ActiveGates in each group must connect to your MySQL database.
  • Create a dedicated database user in your database instance with necessary permissions. Dynatrace uses this user to run monitoring queries against your MySQL database. Follow these steps to create the user:
    1. Create a monitoring user. Choose the authentication method based on your setup.
      • Standard user: Choose the command based on your MySQL version.
        • MySQL 8.4.0 and later
          CREATE USER 'dynatrace'@'%' IDENTIFIED WITH caching_sha2_password BY '<PASSWORD>';
          caching_sha2_password requires a secure connection
          Enable SSL to secure the monitoring connection.
        • MySQL 8.0.0 to 8.3.x
          CREATE USER 'dynatrace'@'%' IDENTIFIED WITH mysql_native_password BY '<PASSWORD>';
      • IAM (AWS RDS): Use this method to authenticate using AWS IAM instead of a database password. Requires an IAM role attached to your ActiveGate host. For IAM policy and role setup, see AWS IAM.
        1. Enable IAM database authentication on your RDS instance. For details, see Enabling and disabling IAM database authentication.
        2. Create the monitoring user.
          CREATE USER 'dynatrace'@'%' IDENTIFIED WITH AWSAuthenticationPlugin AS 'RDS';
    2. Give the user the following permissions:
      • GRANT SELECT ON performance_schema.* TO 'dynatrace'@'%';
        • Allows the user to query the performance_schema schema.
      • GRANT PROCESS ON *.* TO 'dynatrace'@'%';
        • Allows the user to see thread and connection metrics for other users.
      • GRANT SHOW DATABASES ON *.* TO 'dynatrace'@'%';
        • Allows the user to see database metrics for all databases.
      • GRANT SHOW VIEW ON *.* TO 'dynatrace'@'%';
        • Allows the user to see view definitions.
      • GRANT REFERENCES ON *.* TO 'dynatrace'@'%';
        • Allows the user to create foreign key references.
      • GRANT SELECT ON mysql.slow_log TO 'dynatrace'@'%';
        • Allows the user to query slow queries.
      • GRANT SELECT ON sys.x$memory_global_by_current_bytes TO 'dynatrace'@'%';
        • Allows the user to query memory statistics.
    Due to a MySQL limitation, to calculate database sizes, you need to grant SELECT permissions on the individual databases from which you want to collect the size.
Compatibility information
MySQL version 8.0 or higher is required.
MySQL 8.0 has reached end of life for self-hosted and Amazon RDS deployments, so in the extension MySQL 8.0 is supported with the following limitations:
  • Execution plan visualization is not available.
  • Warning signals for execution plans will not work.
For Amazon Aurora clusters (Aurora MySQL version 3), standard support continues until April 30, 2028. For details, see Release calendars for Amazon Aurora MySQL.
Activation and setup
To monitor a new MySQL database, do one of the following:
  • Onboard the database via Databases Databases (recommended for first-time users).
  • Create a monitoring configuration in Extensions Extensions.
Create a monitoring configuration with Extensions
  1. Go to Extensions Extensions.
  2. Search and select the MySQL extension.
1. Add configuration
Go to the MySQL extension and select Add configuration.
2. Choose where to run the extension
In Choose where to run the extension, select ActiveGate.
3. Select an ActiveGate group
In Select ActiveGate group to activate extension, select the ActiveGate group, and then select Next.
4. Create endpoints
Create one or more endpoints that point to your database instances. Each configuration can have up to 20,000 endpoints.
  1. In the Database connection section, provide:
    • Host: Hostname or IP address of your database.
    • Port: Port that the database listens on.
    • Database name: To monitor a single database, enter its name. To monitor all databases, leave it empty (recommended).
  2. In the Authentication section:
    1. Select an Authentication scheme. The default is Basic authentication.
    2. Provide the credentials for the dynatrace monitoring user you created:
      • To enter the credentials directly, provide the Username and Password.
      • To use stored credentials, enable Use credential vault, and then select an entry in Select Vault credentials or select Create new credentials.
    3. Optional Enable Use connection string (requires ActiveGate version 1.307 or later) to connect using a connection string instead of a datasource object, and then enter the Connection string. Don't enter any sensitive data in the connection string.
    4. Optional Enable Enable SSL (requires ActiveGate version 1.269 or later) to establish a secure connection. Use an SSL port and add the server certificate to the truststore. For details, see enable SSL.
  3. Optional Add Primary fields and Primary tags to attach metadata to the entities created for the endpoint.
  4. To monitor more instances, select Add MySQL endpoint and repeat the steps.
  5. After you create all endpoints, select Next.
5. Define the monitoring configuration variables
  1. Adjust the polling frequency for this monitoring configuration:
    • Query interval: Controls the polling frequency for most of the metrics collected by the extension. Defaults to 1 minute.
    • Slow queries interval: Controls the polling frequency of slow and top query monitoring. Defaults to 5 minutes.
    • Table query interval: Controls the polling frequency of table and index monitoring queries. Available from major version 3 onwards.
    • Schema collection interval: Controls the polling frequency of database configuration parameters and schema.
    The default Slow queries interval is five minutes, which aligns with the Database Monitoring billing interval. Setting a shorter interval may result in additional Database Monitoring consumption.
  2. Select Next.
6. Define the metadata
  1. Add a Description to your monitoring configuration.
  2. Optional Add Primary fields and Primary tags.
  3. Optional Add Attributes such as security context, product, and cost center field values to enrich all collected data.
  4. Select your desired feature sets.
  5. Select Save.
Congratulations! You have successfully configured the MySQL extension via Extensions Extensions for remote monitoring.
Configure your database
To monitor your database instance, specific settings must be configured on the MySQL database. If you're onboarding through Databases Databases, scripts are provided that create the necessary database objects. Download the script to your host and run it as an admin user with sufficient permissions. Otherwise, run the following actions manually.
  1. Add manual configurations based on the monitoring requirements.
    • Collect infrastructure metrics
      To enable CPU metrics collection, run this query in the MySQL instance:
      SET GLOBAL innodb_monitor_enable='cpu%';
    • Collect memory metrics
      To enable memory metrics collection, run this query in the MySQL instance:
      SET GLOBAL innodb_monitor_enable='memory%';
    • Collect table statistics
      To enable table statistics collection, run this query in the MySQL instance:
      UPDATE performance_schema.setup_instruments
      SET ENABLED = 'YES', TIMED = 'YES'
      WHERE NAME LIKE 'wait/io/table/%';
      To enable index statistics collection, run this query in the MySQL instance:
      GRANT SELECT ON mysql.innodb_index_stats TO 'dynatrace'@'%';
    • Collect waits metrics
      To enable waits instrumentation:
      WHERE NAME LIKE 'wait/%';
      To enable waits consumers:
      UPDATE performance_schema.setup_consumers
      SET ENABLED='YES'
      WHERE NAME IN ('events_waits_current','events_waits_history','events_waits_history_long');
    • Collect top slow queries
      The following steps apply to the slow_queries feature set, which retrieves data from mysql.slow_log.
      This approach will be deprecated in a future release.
      Enable slow queries logging to a table by executing:
      SET GLOBAL log_output = 'TABLE';
      SET GLOBAL slow_query_log = 'ON';
      The default slow query threshold is 10 seconds.
      Optionally, choose the threshold of what is a "slow query" by executing:
      SET GLOBAL long_query_time = 2;
      This sets the slow queries threshold to 2 seconds.
      • The following steps apply to the top_queries feature set, which retrieves data from performance_schema.events_statements_summary_by_digest.
        1. Enable the necessary statement instruments, which tell MySQL to track all statements:
        WHERE NAME LIKE 'statement/%';
        1. Enable the consumers, which tells MySQL where to store the tracked statements:
        SET ENABLED = 'YES'
        WHERE NAME IN ('events_statements_history', 'events_statements_summary_by_digest');
        Note for AWS Relational Database Service (RDS)
        The recommended way to enable this on RDS is to create a custom parameter group. In the group, set performance_schema to 1 and enable the required consumer settings. This configuration persists across restarts and instance changes. For details, see Turn on the Performance Schema for Amazon RDS for MariaDB or MySQL.
    • Fetch execution plans
      MySQL 8.0 uses a different JSON structure for execution plans, which is no longer supported. As a result, execution plan visualization and warning signals that rely on the new JSON format will not work on MySQL 8.0.
      To fetch execution plans:
      1. Create the dynatrace schema.
        CREATE SCHEMA IF NOT EXISTS dynatrace;
      2. Create the stored procedure and grant execute permission in each database schema you want to monitor, including the dynatrace schema created in the previous step. Repeat the following for every schema (replace <schema_name> with the actual schema name):
        DROP PROCEDURE IF EXISTS `<schema_name>`.dynatrace_execution_plan;
        DELIMITER $$
        CREATE PROCEDURE `<schema_name>`.dynatrace_execution_plan(IN query TEXT)
        SQL SECURITY DEFINER
        BEGIN
        SET @explain := CONCAT('EXPLAIN FORMAT=JSON ', query);
        PREPARE stmt FROM @explain;
        EXECUTE stmt;
        DEALLOCATE PREPARE stmt;
        END $$
        DELIMITER ;
        GRANT EXECUTE ON PROCEDURE `<schema_name>`.dynatrace_execution_plan TO 'dynatrace'@'%';
      3. Set the required MySQL variables. These apply to both self-hosted and cloud-hosted (for example, AWS RDS) MySQL.
        • explain_json_format_version (MySQL 8.3.0 and later): Controls the JSON format used for execution plans. Must be set to 2.
        • performance_schema_max_sql_text_length: Controls the maximum length of SQL text captured in the performance schema. Must be set to 4096.
        For self-hosted MySQL, persist the values directly:
        SET PERSIST explain_json_format_version = 2;
        SET PERSIST performance_schema_max_sql_text_length = 4096;
        For cloud-hosted MySQL (for example, AWS RDS), set these values in your instance parameter group instead of using SET PERSIST.
  2. Run FLUSH PRIVILEGES; to apply the permission changes.
  3. Verify that the performance schema is enabled by running SHOW VARIABLES LIKE 'performance_schema';. The result should be ON.
Feature sets
databases
Metric nameMetric keyDescription
Database Sizemysql.databases.sizeThe size of the Database.
Database Queriesmysql.databases.queries.countNumber of queries executed for the database.
Database Rows Readmysql.databases.rows_read.countNumber of rows examined by queries executed for the database.
Database Rows Writtenmysql.databases.rows_written.countNumber of rows affected by queries executed for the database.
locks
statements
Commitsmysql.statements.commit.countThe number of COMMIT statements executed by this server
Deletesmysql.statements.delete.countThe number of DELETE statements executed by this server
Multi-Table Deletesmysql.statements.delete_multi.countThe number of multi-table DELETE statements executed by this server
Insertsmysql.statements.insert.countThe number of INSERT statements executed by this server
Insert Selectsmysql.statements.insert_select.countThe number of INSERT ... SELECT statements executed by this server
Selectsmysql.statements.select.countThe number of SELECT statements executed by this server
Updatesmysql.statements.update.countThe number of UPDATE statements executed by this server
Executesmysql.statements.execute.countThe number of EXECUTE statements executed by this server
Multi-Table Updatesmysql.statements.update_multi.countThe number of multi-table UPDATE statements executed by this server
Bytes Sentmysql.statements.bytes_sent.countThe number of bytes sent to all clients
Bytes Receivedmysql.statements.bytes_received.countThe number of bytes received from all clients
Rollbacksmysql.statements.rollback.countThe number of ROLLBACK statements executed by this server
Replace Selectsmysql.statements.replace_select.countThe number of REPLACE ... SELECT statements executed by this server
waits
Waits IOmysql.waits.waits_io.countThe number of times that the server has waited for an I/O operation to complete.
Waits IO Timemysql.waits.waits_io_time.countThe total time the server has waited for I/O operations to complete.
Waits Syncmysql.waits.waits_sync.countThe number of times that the server has waited for a synchronization operation to complete.
Waits Sync Timemysql.waits.waits_sync_time.countThe total time the server has waited for synchronization operations to complete.
default
Uptimemysql.global_status.uptimeThe time in seconds that the MySQL server has been running since it was started.
topQueries
slowQueries
tables
Table Data Sizemysql.tables.data_sizeFor MyISAM, DATA_LENGTH is the length of the data file, in bytes. For InnoDB, DATA_LENGTH is the approximate amount of space allocated for the clustered index, in bytes. Specifically, it is the clustered index size, in pages, multiplied by the InnoDB page size.
Table Index Sizemysql.tables.index_sizeFor MyISAM, INDEX_LENGTH is the length of the index file, in bytes. For InnoDB, INDEX_LENGTH is the approximate amount of space allocated for non-clustered indexes, in bytes. Specifically, it is the sum of non-clustered index sizes, in pages, multiplied by the InnoDB page size.
Table Total Sizemysql.tables.total_sizeThe total size of the table, in bytes. This is the sum of data and index size.
Table Estimated Rowsmysql.tables.estimated_rowsThe number of rows in the table. For InnoDB, this is an approximation. For MyISAM, this is an exact count.
Table Free Spacemysql.tables.free_spaceThe number of allocated but unused bytes.
Table IO Eventsmysql.tables.io_events.countNumber of summarized events and the sum of the x_READ and x_WRITE columns.
Table IO Wait Timemysql.tables.io_wait_time.countTotal wait time of the summarized events that are timed.
Table IO Readmysql.tables.io_read.countNumber of all read operations, and the sum of the equivalent x_FETCH columns.
Table IO Read Wait Timemysql.tables.io_read_wait_time.countTotal wait time of all read operations that are timed.
Table IO Writemysql.tables.io_write.countNumber of all write operations, and the sum of the equivalent x_INSERT, x_UPDATE, and x_DELETE columns.
Table IO Write Wait Timemysql.tables.io_write_wait_time.countTotal wait time of all write operations that are timed.
Table IO Fetchmysql.tables.io_fetch.countNumber of all fetch operations.
Table IO Fetch Wait Timemysql.tables.io_fetch_wait_time.countTotal wait time of all fetch operations that are timed.
Table IO Insertmysql.tables.io_insert.countNumber of all insert operations.
Table IO Insert Wait Timemysql.tables.io_insert_wait_time.countTotal wait time of all insert operations that are timed.
Table IO Updatemysql.tables.io_update.countNumber of all update operations.
Table IO Update Wait Timemysql.tables.io_update_wait_time.countTotal wait time of all update operations that are timed.
Table IO Deletemysql.tables.io_delete.countNumber of all delete operations.
Table IO Delete Wait Timemysql.tables.io_delete_wait_time.countTotal wait time of all delete operations that are timed.
Index Sizemysql.indexes.index_sizeThe calculated size of the index in bytes. Derived by multiplying the number of 16KB pages by 16384.
Index Scansmysql.indexes.scans.countThe total number of times this specific index was accessed or scanned by queries.
Index Rows Readmysql.indexes.rows_read.countThe number of read operations on the index structure itself. High values indicate heavy index traversal.
Index Rows Fetchedmysql.indexes.rows_fetched.countThe number of actual table rows retrieved using this index.
Index Rows Insertedmysql.indexes.rows_inserted.countThe number of rows inserted using this index.
Index Rows Updatedmysql.indexes.rows_updated.countThe number of rows updated using this index.
Index Rows Deletedmysql.indexes.rows_deleted.countThe number of rows deleted using this index.
globalStatus
Queriesmysql.global_status.queries.countThe total number of queries executed by the server. This includes statements executed within stored procedures, unlike the Questions variable.
Slow Queriesmysql.global_status.slow_queries.countThe number of queries that have taken more than long_query_time seconds. This counter increments regardless of whether the slow query log is enabled. For information about that log, see Section 5.4.5, The Slow Query Log.
Table Locks Waitedmysql.global_status.table_locks_waited.countThe number of times that a request for a table lock could not be granted immediately and a wait was needed. If this is high and you have performance problems, you should first optimize your queries, and then either split your table or tables or use replication.
Table Locks Immediatemysql.global_status.table_locks_immediate.countThe number of times that a request for a table lock could be granted immediately.
Current Connectionsmysql.global_status.current_connectionsThe number of currently open connections.
Threads Runningmysql.global_status.threads_runningThe number of threads that are not sleeping.
Innodb Buffer Pool Pages Datamysql.global_status.innodb_buffer_pool_pages_dataThe number of pages in the InnoDB buffer pool containing data. The number includes both dirty and clean pages. When using compressed tables, the reported Innodb_buffer_pool_pages_data value may be larger than Innodb_buffer_pool_pages_total
Innodb Buffer Pool Pages Dirtymysql.global_status.innodb_buffer_pool_pages_dirtyThe current number of dirty pages in the InnoDB buffer pool.
Innodb Buffer Pool Pages Freemysql.global_status.innodb_buffer_pool_pages_freeThe number of free pages in the InnoDB buffer pool.
Innodb Buffer Pool Pages Totalmysql.global_status.innodb_buffer_pool_pages_totalThe total size of the InnoDB buffer pool, in pages. When using compressed tables, the reported Innodb_buffer_pool_pages_data value may be larger than Innodb_buffer_pool_pages_total
Innodb Data Readsmysql.global_status.innodb_data_reads.countThe total number of data reads (OS file reads).
Innodb Data Writesmysql.global_status.innodb_data_writes.countThe total number of data writes.
Innodb Data Readmysql.global_status.innodb_data_read.countThe total amount of data read from files.
Innodb Data Writtenmysql.global_status.innodb_data_written.countThe total amount of data written.
Innodb Buffer Pool Readsmysql.global_status.innodb_buffer_pool_readsThe number of logical reads that InnoDB could not satisfy from the buffer pool, and had to read directly from disk.
Innodb Buffer Pool Read Requestsmysql.global_status.innodb_buffer_pool_read_requestsThe number of logical read requests.
Availabilitymysql.global_status.availabilityWhether or not a connection can be made to the database
Statusmysql.global_status.statusA status of AVAILABLE is returned if we can query the database
infrastructure
CPU Usermysql.infrastructure.cpu.userThe percentage of CPU time spent in user mode.
CPU Systemmysql.infrastructure.cpu.systemThe percentage of CPU time spent in system mode.
Memorymysql.infrastructure.memoryThe amount of memory used per each code area.
FAQ
Why don't I see wait metrics?
Data collection must be allowed for the MySQL instance to gather wait metrics. For details, see Performance Schema Wait Event Tables.
Can I monitor MariaDB with this extension?
This extension was tested only with MySQL instances. MariaDB is not officially supported.
I get an error "RSA public key is not available on client side".
This error occurs when using caching_sha2_password (the default for MySQL 8.4.0 and later) without a secure connection. To resolve it, either enable SSL for the monitoring connection, or add allowPublicKeyRetrieval=true to the JDBC connection string in the monitoring configuration. However, enabling allowPublicKeyRetrieval doesn't guarantee a secure connection.
Alternatively, use mysql_native_password instead (MySQL 8.0.0 to 8.3.x). For details, see Activation and setup.
I can't see CPU and Memory metrics.
Ensure that data collection is enabled for your instance.
  • For CPU: SET GLOBAL innodb_monitor_enable='cpu%';.
  • For Memory: Visit Monitoring MySQL Memory Usage.
To test that you can query the data, run:
SELECT * FROM information_schema.INNODB_METRICS WHERE name IN ('cpu_utime_pct', 'cpu_stime_pct');
And:
SELECT SUBSTRING_INDEX(event_name,'/',2) AS code_area,
SUM(current_alloc) AS current_alloc
FROM sys.x$memory_global_by_current_bytes
GROUP BY SUBSTRING_INDEX(event_name,'/',2)
ORDER BY SUM(current_alloc) DESC;
I can't see slow queries.
See the Collect top slow queries section in Add monitoring configurations.
How can I view top queries in a Managed environment?
On Managed tenants, log records can be retrieved by filtering logs using 2 attributes:
  • dt.extension.name: com.dynatrace.extension.mysql.
  • event.group: top_queries (versions 2.1.6+) or event.group: query_performance (versions <2.1.6).
Explore in Dynatrace Hub
Related tags
DatabaseSQLMySQLMySQLApplication Observability
