Monitor vulnerabilities in Kubernetes/OpenShift
  • Dynatrace Classic
  • 1-min read
  • Published Aug 24, 2022
You can keep track of security vulnerabilities in your Kubernetes environments on the cluster and workload pages.
Prerequisites
  • In Dynatrace, go to your Kubernetes cluster settings page and make sure that Monitor Kubernetes namespaces, services, workloads, and pods is turned on.
  • Activate and enable Application Security
  • To view code-level vulnerabilities Activate and enable Runtime Application Protection
Vulnerability section
The Vulnerabilities section is displayed on the Kubernetes
  • Cluster details page
  • Workloads page
It shows the five most severe related third-party vulnerabilities and code-level vulnerabilities.
  • Select a vulnerability to view the details and understand the severity and impact of a vulnerability within your environment.
  • For a complete list of the detected vulnerabilities for your Kubernetes environment, select Show all third-party vulnerabilities/Show all code-level vulnerabilities.
Example third-party vulnerabilities:
Kubernetes workload: TPV
Example code-level vulnerabilities:
Kubernetes workload: CLV
If you're missing the security permissions for the selected management zone,
  • On the Kubernetes cluster page, the Vulnerabilities section is not displayed.
  • On the Kubernetes workload page, the Vulnerabilities tab on the notification bar shows Not analyzed.
Related topics
  • Set up Dynatrace on Kubernetes
Related tags
Infrastructure ObservabilityContainers
