Dynatrace version 1.254+
ActiveGate version 1.253+
To alert on common Kubernetes platform issues, follow the instructions below.
There are three ways to configure alerts for common Kubernetes/OpenShift issues.
Configuring an alert on a different level is only intended to simplify the configuration of multiple entities at once. It does not change the behavior of an alert.
For example, enabling a workload CPU usage saturation alert will still evaluate and raise problems for each Kubernetes workload separately, even if it has been configured on the Kubernetes cluster level.
For further details on the settings hierarchy, see Settings documentation.
Example:
Manually closed problems will show up again after 60 days if their root cause remains unresolved.
You can view alerts
On the Problems page.
Example problem:
In the Events section of a cluster details page.
Example event:
Select the event to navigate to Data Explorer for more information about the metric that generated the event.
See below for a list of available alerts.
The following alerts are not reclassified as warning signals when the updated classification is enabled.
| Alert name | Dynatrace version | Problem type | Problem title | Problem description | De-alerts after | Calculation | Supported in |
1.254 | Resource | CPU-request saturation on cluster | CPU-request saturation exceeds the specified threshold. | 10 minutes | Node CPU requests / Node CPU allocatable | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | Memory-request saturation on cluster | Memory-request saturation exceeds the specified threshold. | 10 minutes | Node memory requests / Node memory allocatable | Kubernetes Classic, Kubernetes app | |
1.258 | Resource | Pod saturation on cluster | Cluster pod-saturation exceeds the specified threshold. | 10 minutes | Sum of ready pods / Sum of allocatable pods | Kubernetes Classic, Kubernetes app | |
1.254 | Availability | Cluster not ready | Readyz endpoint indicates that this cluster is not ready. | 10 minutes | Cluster readyz metric | Kubernetes Classic, Kubernetes app | |
1.258 | Availability | Monitoring not available | Dynatrace API monitoring is not available. | 10 minutes | Kubernetes Classic, Kubernetes app |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Alert | Setting | Value |
Readiness Issues | sample period in minutes | 3 |
Readiness Issues | observation period in minutes | 5 |
Monitoring Issues | sample period in minutes | 15 |
Monitoring Issues | observation period in minutes | 30 |
1.254 | Resource | CPU-limit quota saturation | CPU-limit quota saturation exceeds the specified threshold. | 10 minutes | Sum of resource quota CPU used / Sum of resource quota CPU limits | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | CPU-request quota saturation | CPU-request quota saturation exceeds the specified threshold. | 10 minutes | Sum of resource quota CPU used / Sum of resource quota CPU requests | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | Memory-limit quota saturation | Memory-limit quota saturation exceeds the specified threshold. | 10 minutes | Sum of resource quota memory used / Sum of resource quota memory limits | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | Memory-request quota saturation | Memory-request quota saturation exceeds the specified threshold. | 10 minutes | Sum of resource quota memory used / Sum of resource quota memory requests | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | Pod quota saturation | Pod quota saturation exceeds the specified threshold. | 10 minutes | Sum of resource quota pods used / Sum of resource quota pods limit | Kubernetes Classic, Kubernetes app |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
1.254 | Resource | CPU-request saturation on node | CPU-request saturation exceeds the specified threshold. | 10 minutes | Sum of node CPU requests / Sum of node CPU allocatable | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | Memory-request saturation on node | Memory-request saturation exceeds the specified threshold. | 10 minutes | Sum of node memory requests / Sum of node memory allocatable | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | Pod saturation on node | Pod saturation exceeds the specified threshold. | 10 minutes | Sum of running pods on node / Node pod limit | Kubernetes Classic, Kubernetes app | |
1.254 | Availability | Node not ready | Node is not ready. | 10 minutes | Node condition metric filtered by 'not ready' | Kubernetes Classic, Kubernetes app | |
1.264 | Error | Problematic node condition | Node has one or more problematic conditions out of the following: | 10 minutes | Nodes condition metric | Kubernetes Classic, Kubernetes app |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
Readiness Issues | Readiness Issues | sample period in minutes |
3 | observation period in minutes | 5 |
Node Problematic Condition | Node Problematic Condition | sample period in minutes |
1.262 | Resource | Kubernetes PVC: Low disk space % | Available disk space for a persistent volume claim is below the threshold. | 10 minutes | Volume stats available bytes / Volume stats capacity bytes | Kubernetes Classic, Kubernetes app | |
1.262 | Resource | Kubernetes PVC: Low disk space | Available disk space for a persistent volume claim is below the threshold. | 10 minutes | Kubelet volume stats available bytes metric | Kubernetes Classic, Kubernetes app |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
1.264 | Resource | CPU usage close to limits | The CPU usage exceeds the threshold in terms of the defined CPU limit. | 10 minutes | Sum of workload CPU usage / Sum of workload CPU limits | Kubernetes Classic, Kubernetes app | |
1.254 | Error | Container restarts | Observed container restarts exceed the specified threshold. | 15 minutes | Container restarts metric | Kubernetes Classic, Kubernetes app | |
1.264 | Resource | High CPU throttling | The CPU throttling to limits ratio exceeds the specified threshold. | 10 minutes | Sum of workload CPU throttled / Sum of workload CPU limits | Kubernetes Classic, Kubernetes app | |
1.268 | Error | Job failure event | Events with reason 'BackoffLimitExceeded', 'DeadlineExceeded', or 'PodFailurePolicy' have been detected. | 60 minutes | Event metric filtered by reason and workload kind | Kubernetes Classic, Kubernetes app | |
1.264 | Resource | Memory usage close to limits | The memory usage (working set memory) exceeds the threshold in terms of the defined memory limit. | 10 minutes | Sum of workload working set memory / Sum of workload memory limits | Kubernetes Classic, Kubernetes app | |
1.268 | Error | Out-of-memory kills | Out-of-memory kills have been observed for pods of this workload. | 15 minutes | Out-of-memory kills metric | Kubernetes Classic, Kubernetes app | |
1.268 | Error | Backoff event | Events with reason 'BackOff' have been detected for pods of this workload. Check for pods with status 'ImagePullBackOff' or 'CrashLoopBackOff'. | 15 minutes | Event metric filtered by reason | Kubernetes Classic, Kubernetes app | |
1.268 | Error | Pod eviction event | Events with reason 'Evicted' have been detected for pods of this workload. | 60 minutes | Event metric filtered by reason | Kubernetes Classic, Kubernetes app | |
1.268 | Error | Preemption event | Events with reasons 'Preempted' or 'Preempting' have been detected for pods of this workload. | 60 minutes | Event metric filtered by reason | Kubernetes Classic, Kubernetes app | |
1.254 | Resource | Pods stuck in pending | Workload has pending pods. | 10 minutes | Pods metric filtered by phase 'Pending' | Kubernetes Classic, Kubernetes app | |
1.260 | Resource | Pods stuck in terminating | Workload has pods stuck in terminating. | 10 minutes | Pods metric filtered by status 'Terminating' | Kubernetes Classic, Kubernetes app | |
1.260 | Error | Deployment stuck | Deployment is stuck and therefore is no longer progressing. | 10 minutes | Workload condition metric filtered by 'not progressing' | Kubernetes Classic, Kubernetes app | |
1.258 | Error | Not all pods ready | Workload has pods that are not ready. | 10 minutes | Sum of all pending or running pods − Sum of ready pending or running pods. Pods of Jobs and CronJob are excluded. | Kubernetes Classic, Kubernetes app | |
1.254 | Error | No pod ready | Workload does not have any ready pods. | 10 minutes | Sum of all pending or running pods − Sum of non-ready pending or running pods. Pods of Jobs and CronJob are excluded. | Kubernetes Classic, Kubernetes app |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
| Type | Expression |
Metric expression |
The following expression returns the number of pending and running pods in the non-ready condition. Pods of Jobs and CronJobs are excluded.
| Type | Expression |
Metric expression |
The following expression returns the number of pending and running pods in the ready condition. Pods of Jobs and CronJobs are excluded.
| Type | Expression |
Metric expression |
Container Restarts | threshold | 1 |
Container Restarts | sample period in minutes | 3 |
Container Restarts | observation period in minutes | 5 |
Deployment Stuck | sample period in minutes | 3 |
Deployment Stuck | observation period in minutes | 5 |
Pending Pods | threshold | 1 |
Pending Pods | sample period in minutes | 10 |
Pending Pods | observation period in minutes | 15 |
Pod Stuck In Terminating | sample period in minutes | 10 |
Pod Stuck In Terminating | observation period in minutes | 15 |
Workload Without Ready Pods | sample period in minutes | 10 |
Workload Without Ready Pods | observation period in minutes | 15 |
Oom Kills | alert | always |
Job Failure Events | alert | always |
Pod Backoff Events | alert | always |
Pod Eviction Events | alert | always |
Pod Preemption Events | alert | always |
