Cost & Carbon Optimization concepts
  • Latest Dynatrace
  • Explanation
  • Published Jun 29, 2026
Cost & Carbon Optimization Cost & Carbon Optimization uses industry-standard guidelines to estimate electricity consumption, carbon emissions, and cloud costs for Dynatrace-monitored hosts and Kubernetes infrastructure.
Methodology to estimate electricity consumption
Electricity consumption and carbon dioxide emission are calculated based on guidelines from the Sustainable Digital Infrastructure Alliance (SDIA) with some contributions from the Cloud Carbon Footprint project and internal research from Dynatrace. All of the methodology is aligned with the GHG Protocol.
Energy is estimated based on the utilization metrics captured by Dynatrace OneAgent (in all modes for hosts) for CPU, memory, storage IO, and network. This estimation is performed every hour for each instrumented host through an automation.
The formula to estimate energy draw includes several parameters from external data sources and some assumptions.
The deviation from the measured power cannot be reliably determined due to the large variety of devices in the market and lack of statistical analysis.
External data sources
  • Random Access Memory energy usage data source
    • How much power does memory use?
  • CPU architecture sources (TDP, core, thread count) used in calculations
    • Intel Product Specifications
    • AMD Processor Specifications
    • CPUs not officially listed are manually added through research, and the sources vary
  • Storage energy usage
    • United States Data Center Energy Usage Report—Energy Technologies Area
  • Networking energy usage
    • Methodology—Cloud Carbon Footprint
Assumptions for electricity consumption
  • CPU energy measurement:
    • Over a long period of time, a CPU running at 100% utilization will consume its TDP in power draw.
    • The base power draw of a CPU is 1/3 of its TDP It is known that true idle for CPUs is much lower, but CPU utilization hovers around a constant 10-20% for server applications, so true idle can never be reached.
    • One cloud vCPU equals one CPU thread
  • Memory energy measurement:
    • Random Access Memory uses a constant of 3 W of power per 8 GB regardless of utilization.
  • Storage energy measurement:
    • The power draw of a terabyte of SSD storage is 1.2 W
    • All storage is assumed to be on an SSD
    • Storage power draw is constant
    • Cloud storage is replicated twice (or more)
  • Network energy measurement:
    • 1 GB of networking (upload or download) consumes 1 W if sent outside of the local network.
    • 1 GB of networking (upload or download) consumes 0.12 W if remaining within a local network.
Power Usage Effectiveness (PUE)
The final result of the formula includes the energy consumed by hardware and cooling. Cooling is included in a standard metric, Power Usage Effectiveness (PUE—not displayed directly in Cost & Carbon Optimization Cost & Carbon Optimization but available in the raw data generated). This metric, used to measure the energy efficiency of a data center, is a ratio between the total power consumption of a data center—including cooling, lighting, and support equipment energy use—and the power consumed by the IT infrastructure. It describes how much energy IT equipment uses compared to other electrical devices.
The Power Usage Effectiveness varies depending on a data center, but its predefined values for the main cloud providers are publicly available. The ones used in the calculation are:
  • AWS and Azure—Methodology—Cloud Carbon Footprint
  • Google—Efficiency—Data Centers
  • Rest of the world—Global PUEs
Wasted energy calculation
Wasted Energy calculation is based on the assumption that every CPU cycle that is not utilized wastes about 1/3*TDP (Thermal Design Power). The proportion of unutilized CPU cycles is roughly 100% - CPU usage %. With those assumptions, the Wasted Energy (WE) is calculated as WE = Wp * 1/3 * TDP, where Wp is 0 for 100% CPU utilization and 1 when the CPU utilization is equal to the idle threshold.
Carbon emissions calculation
Carbon emissions are estimated in CO2 equivalent grams. The calculation is multiplying carbon intensity factors by total energy consumed calculated with previous methodology.
Assumptions for carbon emissions
  • A data center's carbon intensity is equal to the average carbon intensity of the country where it is located. This means that for large countries the national differences are not considered.
  • Carbon intensity values used on calculations are an annual average.
Carbon intensity data sources
  • European Union (EU)—Greenhouse gas emission intensity of electricity generation
  • Rest of the world—Carbon intensity of electricity generation
Public price list costs calculation
Cost & Carbon Optimization Cost & Carbon Optimization can collect public price list data from cloud providers available data on a daily basis, limited to the regions where OneAgents are deployed and cloud extensions are configured.
Every hour, the same workflow that generates the data for energy and emissions also calculates the hourly cost of a host based on the public price list matched with its cloud vendor, region, and instance type.
Both business events follow the Dynatrace Semantic Dictionary schema.
Data centers and hosts
The Data center emissions table on the landing page shows costs, energy, and CO2e consumption per data center. Select a data center name to view details of its hosts.
The Hosts tab details cost, energy, and CO2e consumption per host. You can narrow your search using filters. For example, you can view underutilized hosts in a specific data center or top CO2e emitters.
Expand a hostname to see key infrastructure metrics: CPU in use, Memory in use, and Receiving network traffic. Select a host name to view the host details page in Infrastructure & Operations Infrastructure & Operations.
Cost & Carbon Optimization Cost & Carbon Optimization is automatically connected to Dynatrace Smartscape® topology modeling, so it's easy to see the host details or use Notebooks Notebooks for ad hoc analysis with DQL.
Measure the energy of Dynatrace Kubernetes platform monitoring
Use Cost & Carbon Optimization Cost & Carbon Optimization to measure energy and carbon emissions of your Kubernetes infrastructure.
Cost & Carbon Optimization Cost & Carbon Optimization calculates the energy consumed (in Watt-hours) and carbon emissions (in grams of carbon dioxide emissions) of Kubernetes clusters and namespaces, and nodes, monitored by Dynatrace. All Dynatrace Kubernetes monitoring modes are supported, and data is calculated hourly and stored as carbon Kubernetes events.
Organizations using Kubernetes today, or looking to migrate workloads to Kubernetes, should consider using Cost & Carbon Optimization Cost & Carbon Optimization in addition to the Dynatrace Kubernetes monitoring for the following reasons:
Energy use is a direct driver of cost
Cloud infrastructure costs are largely driven by energy consumption. CPU, memory, storage, and networking all consume power, and cloud providers factor this into pricing. By measuring energy usage, you're essentially tracking the underlying metric that influences cost.
Carbon footprint adds environmental context
Carbon footprint translates energy consumption into environmental impact. This is especially valuable for organizations with sustainability goals or ESG (Environmental, Social, and Governance) reporting requirements.
Optimization opportunities align
Inefficient clusters, namespaces, and nodes that consume more energy (and thus emit more carbon) are often the ones driving up cloud costs. Identifying high-carbon workloads can highlight areas for cost and environmental optimization.
The app will generate carbon Kubernetes bizevents in addition to regular carbon bizevents when the Enable energy and emission data generation option is enabled within the app's settings.
You can report on Kubernetes infrastructure energy and carbon emissions using custom DQL and dashboards.
Cluster calculations
Each Kubernetes node within the cluster is identified as a host, and Cost & Carbon Optimization Cost & Carbon Optimization uses the host processor, and utilization information to calculate energy and carbon every hour using the Cost & Carbon Optimization Cost & Carbon Optimization Calculation workflow. The carbon and energy metrics of all nodes are summed and stored as a bizevent using: type="carbon.measurement.k8s.cluster".
Namespace calculations
Namespace carbon and energy values are derived by determining the % utilization of each namespace across the Kubernetes nodes it runs on, proportionally allocating energy and carbon from each node to the namespace. The carbon and energy metrics of all nodes are summed and stored as a bizevent using: type="carbon.measurement.k8s.namespace".
Bear in mind the following:
  • CPU processor information is only available when using Kubernetes platform monitoring + Full-Stack observability. Other monitoring modes provide only instance type. Dynatrace maintains a lookup table of cloud instance type to CPU and will fall back to a Dynatrace-derived Kubernetes median value of 240w TDP and 64 threads.
  • For AWS Fargate, energy calculations assume a Graviton1 processor type (TDP 110w, 16 threads).
Related tags
Business Observability
