Runtime metrics migration guide
Latest Dynatrace
This guide provides insights into migrating runtime metrics to Grail. Typically, a Grail metric is equivalent to a Metrics Classic metric. In some cases, however, there's no one-to-one relation:
  • Divergent: multiple Grail metrics represent a single Metrics Classic metric to provide additional technology-specific insight.
  • Convergent: a single Grail metric represents multiple Metrics Classic metrics of a similar scope.
  • Unsupported: no Grail metric is planned to represent the Metrics Classic metric.
Divergent metrics
When multiple Grail metric keys provide support for a single Metrics Classic metric, not all values can be converted to the respective new metric keys. For example, the following example queries return equivalent results.
Example 1
  • Metrics Classic
    builtin:tech.jvm.memory.gc.collectionTime:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),entityName.equals(~"MyGoProcessGroup-IG-1~")"))))):auto
    timeseries collection_time = sum(dt.runtime.go.gc.collection_time),
    filter:in(dt.entity.process_group_instance, classicEntitySelector("type(process_group_instance), entityName.equals(\"MyGoProcessGroup-IG-1\")"))
Example 2
  • Metrics Classic
Example 3
  • Metrics Classic
Java Node.js .NET Go
The following Metrics Classic metrics for memory pool and garbage collection are JVM-based. Because Grail metrics are technology-specific, there's no direct relation between Metrics Classic and Grail metrics. You need to choose a technology-dedicated metric in Grail.
Metric key (Grail)
Metric key (Classic)
dt.runtime.jvm.gc.total_collection_time
dt.runtime.clr.gc.collection_time
dt.runtime.jvm.gc.collection_time
dt.runtime.nodejs.gc.collection_time
builtin:tech.jvm.memory.pool.collectionTime
dt.runtime.jvm.gc.suspension_time
dt.runtime.clr.gc.suspension_time
dt.runtime.go.gc.suspension_time
dt.runtime.nodejs.gc.suspension_time
builtin:tech.jvm.memory.gc.suspensionTime
ApacheIIS.NGINX
The following Metrics Classic metrics for web servers hold values for different technologies. Because Grail metrics are technology-specific, there's no direct relation between Classic and Grail metrics. You need to choose the Apache, IIS, or NGINX dedicated metric in Grail.
Metric key (Grail)
dt.runtime.apache.connections.socket_waiting_time
dt.runtime.iis.connections.socket_waiting_time
builtin:tech.webserver.connections.socketWaitingTime
dt.runtime.apache.requests
dt.runtime.iis.requests
dt.runtime.nginx.requests
builtin:tech.webserver.requests
dt.runtime.apache.threads.active
dt.runtime.iis.threads.active
builtin:tech.webserver.threads.active
dt.runtime.apache.threads.idle
dt.runtime.iis.threads.idle
builtin:tech.webserver.threads.idle
dt.runtime.apache.threads.max
dt.runtime.iis.threads.max
builtin:tech.webserver.threads.max
dt.runtime.apache.traffic
dt.runtime.iis.traffic
dt.runtime.nginx.traffic
builtin:tech.webserver.traffic
Convergent metrics
When a single Grail metric provides support for multiple Metrics Classic metrics, all values are converted. To obtain the equivalent results in Grail, use a metric dimension to filter the values. For example, the following metrics return equivalent results.
  • Metrics Classic: builtin:tech.go.http.responses5xx
  • DQL: dt.runtime.go.http.requests filtered by status in the range 500–599
    • via DQL queries
      timeseries responses5xx = sum(dt.runtime.go.http.requests),
      filter:{500 <= status and status <= 599}
    • via Notebooks
      Filter HTTP requests by status
Go
Metric key (Grail)
dt.runtime.go.cf.auctioneer_lrp_auctions
status (failed or started)
builtin:cloud.cloudfoundry.auctioneer.lprFailed (filtered by process type Go)
builtin:cloud.cloudfoundry.auctioneer.lprStarted (filtered by process type Go)
status (== 502 or >= 500 and <=599)
builtin:tech.go.http.badGateways
builtin:tech.go.http.totalRequests
dt.runtime.go.memory.heap
state (idle or live)
builtin:tech.go.memory.heap.idle
builtin:tech.go.memory.heap.live
dt.runtime.go.scheduler.goroutine_count
owner (user or system)
builtin:tech.go.scheduling.g.runningCount
builtin:tech.go.scheduling.g.systemCount
dt.runtime.go.scheduler.worker_thread_count
state (Overall, Idling, or Spinning)
builtin:tech.go.scheduling.m.count
builtin:tech.go.scheduling.m.idlingCount
builtin:tech.go.scheduling.m.spinningCount
.NET
Metric key (Grail)
dt.runtime.clr.gc.collection_count
generation (Generation0, Generation1, or Generation2)
builtin:tech.dotnet.gc.gen0Collections
builtin:tech.dotnet.gc.gen1Collections
builtin:tech.dotnet.gc.gen2Collections
dt.runtime.clr.memory.consumption
generation (Generation0, Generation1, Generation2, and LargeObjectHeap)
builtin:tech.dotnet.memory.gen0Consumption
builtin:tech.dotnet.memory.gen1Consumption
builtin:tech.dotnet.memory.gen2Consumption
builtin:tech.dotnet.memory.LOHConsumption
dt.runtime.clr.threadpool.threads
type (activeIOCompletionThreads or activeWorkerThreads)
builtin:tech.dotnet.threadpool.ioCompletionThreads
builtin:tech.dotnet.threadpool.workerThreads
Unsupported metrics
The following Metrics Classic metrics don't have a dedicated Grail metric.
NGINX
  • builtin:tech.nginx.cache.hitRatio
    timeseries
    misses = sum(dt.runtime.nginx.plus.cache.misses),
    hits = sum(dt.runtime.nginx.plus.cache.hits)
    | fieldsAdd hit_ratio = misses[] / hits[]
  • builtin:tech.nginx.serverZones.active
  • builtin:tech.nginx.serverZones.inactive
Node.js
  • builtin:tech.nodejs.uvLoop.count
  • builtin:tech.nodejs.uvLoop.loopLatency
  • builtin:tech.nodejs.uvLoop.processedLatency
  • builtin:tech.nodejs.uvLoop.totalTime
