Manage users and groups with SAML in Dynatrace Managed
This page will soon be available only on the dedicated Dynatrace Managed Documentation site. Update your bookmarks.
Dynatrace Managed supports integration with SAML 2.0 as an SSO IdP (Single Sign-On Identity Provider) for the management of users and groups. SAML can use either HTTP POST
(preferred) or HTTP Redirect
bindings. When both are present, HTTP POST
is used.
Set up SAML 2.0 integration
This procedure requires configuration in Dynatrace Managed and at your IdP.
In Dynatrace Managed
From the Cluster Management Console menu, select User authentication > Single sign-on settings.
From Select single sign-on technology, select
SAML 2.0
From Select login page, select the login options you want to offer users:
- Standard + SSO displays the standard Dynatrace login page, where the user has the choice to sign in using a local user account (as configured through User authentication > User accounts) or to select the Log in using SSO link and use SSO authentication.
- SSO skips the Dynatrace login page, so the user cannot sign in using a local user account, and redirects to the IdP login page for SSO authentication only.
Select Download SP metadata to download (to file
sp.xml
) the SAML metadata you need to provide to your SP.
The XML metadata of a SAML 2.0 Service Provider box displays the metadata.
On your Identity Provider server (IdP)
Refer to your IdP documentation for details on these steps.
At your IdP server
- Use the
sp.xml
metadata file you downloaded earlier to configure Dynatrace Managed as a Service Provider (SP). Download the completed configuration metafile from your IdP server.
Back in the Dynatrace Managed Cluster Management Console
- Return to the Single sign-on settings page (User authentication > Single sign-on settings) to continue where you left off.
- Select the Select file button and upload your IdP configuration metafile to Dynatrace Managed.
The XML metadata of a SAML 2.0 Identity Provider box displays the metadata. - Under User attributes based on SAML 2.0 response attributes, enter the user attributes.
- First name attribute
- Last name attribute
- Email attribute
Group assignment configuration
Each Dynatrace Managed user must be assigned to at least one user group, with at least one associated monitoring environment. Without such a mapping, the user can't sign in to Dynatrace Managed and will instead receive an error message stating that no environment has been found.
The Assign users to groups based on SAML 2.0 response attribute switch determines how you manage user-group assignments:
- Manually: Set the switch to the off position if you want to make user-group assignments manually from within Dynatrace Managed. In this case, Dynatrace Managed ignores the list of groups sent in your IdP's authentication response.
- Automatically: Turn on the toggle and enter the group name in the User group attribute field if you want to handle user-group assignment automatically. In this case, any assignments made within Dynatrace Managed are overwritten by the list of groups sent in your IdP's authentication response, such as
which would assign the user to the1<Attribute Name="gr">2 <AttributeValue>Admins</AttributeValue>3 <AttributeValue>Users</AttributeValue>4</Attribute>
Admins
andUsers
groups.- If the value of the user group attribute in the SAML response contains commas, Dynatrace recognizes it as a comma-separated list of user groups and assigns the user to each group in the list. For example
would assign the user to the1<Attribute Name="gr">2 <AttributeValue>Admins,Users</AttributeValue>3</Attribute>
Admins
andUsers
groups. - Make sure group names exactly match existing Dynatrace user group names (case-sensitive, no extra spaces). For example,
Admins
andadmins
would be two different groups.
SAML signing certificate update
To submit a new SAML signing certificate, make a PUT request through the Cluster Management API.
In Cluster Management Console, get a
ServiceProviderAPI
token.- Select Settings > API tokens.
- Select Generate token.
- Give the token a name, turn on Service Provider API, and Save it.
- In the list of tokens, expand the token you just created and select Copy to copy the token value to your clipboard.
Open the User menu in the top-right corner of the window and select Cluster Management API.
Submit the token.
- Select Authorize.
Paste the token value into the edit box.
- Select Authorize.
- Select Close.
Now you are authorized to issue the necessary API request.
Expand the SSO configuration section and select PUT.
Select Try it out.
The Description section displays the format expected for the body of the PUT request.1{2 "privateKeyEncoded": "string",3 "publicKeyCertificateEncoded": "string"4} -
Paste the contents of the RSA private key and certificate to replace the corresponding
privateKeyEncoded
andpublicKeyCertificateEncoded
value placeholders (string
). Be sure to include the fullBEGIN
andEND
tags of each. In this example, the key and certificate are truncated for brevity:1{2 "privateKeyEncoded": "-----BEGIN RSA PRIVATE KEY-----\nMIIEowIBAAKCAQEAp8RXe0PIuDwj1ZbYrShXRxjiFnq8xmLWZlWIYkScX/1KC69M\n...\nPM3kel4na+AGibenqRs7PA6rqFeXDg193pepzWqvqmJ98W8YYecZ\n-----END RSA PRIVATE KEY-----",3 "publicKeyCertificateEncoded": "-----BEGIN CERTIFICATE-----\nMIICzTCCAbWgAwIBAgIRAIpaHcbUOpvhKf6exsxJjVowDQYJKoZIhvcNAQELBQAw\n...\nuw==\n-----END CERTIFICATE-----"4} -
Select Execute to submit the request.
200
- Certificate update was successful.400
- Invalid input. Verify that you pasted the complete key and certificate, including the fullBEGIN
andEND
tags of each, into the body of the request as shown in the example.510
- Failed operation. Check the server logs for details.
ADFS configuration
If you choose to integrate Dynatrace Managed with Active Directory Federation Services (ADFS), perform the following steps on the ADFS side and then in Dynatrace Managed.
Configuration on the ADFS side
Use the Add Relying Party Trust Wizard to add a new relying party trust using Dynatrace SP metadata configuration.
On the Advanced tab, set Secure hash algorithm to
SHA-1
orSHA-256
Add a claim issuance policy to the added relying party trust.
Define a rule to send LDAP attributes as claims.
Define rules to transform LDAP attributes to
Name ID
(create a rule appropriate to your needs).-
Example of a rule to transform the LDAP
login
attribute toName ID
email
attribute toName ID
Configuration on the Dynatrace Managed side
On the Dynatrace Managed Single sign-on settings page, set the User group attribute appropriately.
Frequently asked questions
NameId
is a login on the Dynatrace Managed side. All formats are accepted by Dynatrace Managed, so you can choose the format that best fits your policy rules.
Our recommendation for NameIdFormat
is:
urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress
Upon sign-out, a global sign-out is triggered, including for your IdP, which then cascades to other services. Otherwise, you would be signed out from Dynatrace Managed, but to reauthenticate it would be sufficient to either click the Log in using SSO link on the login page, or to enter the Dynatrace Managed WebUI URL in the browser when the login page is configured to SSO.
If you want to disable it (not a good idea from a security standpoint), edit your metadata, remove all SingleLogoutService
tags, and upload the updated metadata.
Yes, customer IdP metadata can contain multiple signing certificates. Dynatrace Managed validates that SAML messages from the customer IdP are signed by one of them.
Yes, users are added following successful authentication.
This could happen when configured SSO IdP redirects sign in or sign out POST requests to other hosts.
To resolve this, go to User authentication > Single sign-on settings and add the redirect URLs to the SSO IdP redirect URLs section.
