Mask sensitive data with the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 5-min read
Telemetry data can often include sensitive data (such as PII), which may need to be redacted due to security and regulatory reasons. While this can be implemented on the application side, it typically is best to handle this centrally using gateways such as the OTel Collector. This enables the single-point management of redaction rules across all your applications and services, without the need to update your code each time a new redaction rule is required.
This page shows sample Collector configurations for the redaction of specific sensitive data (for example, credit card numbers or email addresses) which may appear in telemetry data and which should be masked/redacted before leaving your network.
Prerequisites
  • One of the following Collector distributions with the transform and/or redaction processors:
    • The Dynatrace OTel Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • The Dynatrace API endpoint URL to which the data should be exported
  • A Classic access token with the relevant access scope (only required for SaaS and ActiveGate)
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Redaction processor versus transform processor
The following examples make use of these two Collector processors:
  • the transform processor
  • the redaction processor
While the following examples use both processors to mask data, each processor has its own distinct purpose. The redaction processor is straightforward and takes a list of values, based on which matching data will be completely redacted. On the other hand, the purpose of the transform processor is more versatile and goes beyond mere data redaction.
For data redaction, typically either processor can be used and you may want to choose the one best for your use case. For example, for full data redaction, the redaction processor may be easier to use. On the other hand, partial data redaction can only be achieved with the transform processor. In addition, the transform processor can also filter by data in the body of logs, whereas the redaction processor only has access to attributes.
Limitations and considerations
The examples provided on this page are samples demonstrating common redaction scenarios. Note the following:
  • The examples may not be exhaustive for all use cases. You may need to adapt them to your specific requirements.
  • The regex patterns and attribute matching only work when the entire attribute value matches the pattern to be redacted. Partial matches within larger strings may require more complex patterns or additional processing.
  • The span name is stored as a separate field in the OTLP message structure, not as an attribute. Therefore, redaction processors targeting attributes will not affect span names by default. See the Span names example for how to handle this.
  • Processor order in pipelines matters. Apply transform/redaction before routing or exporting, and keep related processors adjacent so downstream steps see the sanitized data.
Demo configuration
This YAML document is a basic Collector configuration skeleton, containing basic, general components (that is, receivers, exporters, and the pipeline definition).
receivers:
otlp:
protocols:
grpc:
endpoint: 0.0.0.0:4317
http:
endpoint: 0.0.0.0:4318
processors:
PLACEHOLDER-FOR-PROCESSOR-CONFIGURATIONS
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
"Authorization": "Api-Token ${env:DT_API_TOKEN}"
service:
pipelines:
traces:
receivers: [otlp]
processors: [PLACEHOLDER-FOR-PROCESSOR-REFERENCES]
exporters: [otlp_http]
metrics:
receivers: [otlp]
logs:
receivers: [otlp]
Make sure to replace the placeholder values in the document with the respective configurations:
  • PLACEHOLDER-FOR-PROCESSOR-CONFIGURATIONS: the relevant processor configuration
  • PLACEHOLDER-FOR-PROCESSOR-REFERENCES: referencing the applicable processor objects for the individual signal types
IP addresses
Using the transform processor, we mask the attribute client.address with the set statement.
transform:
error_mode: ignore
trace_statements:
- context: span
statements: &filter-statements
# this will not only mask end user client IP addresses,
# but also the address of a server acting as a client when establishing a connection to another server
- set(attributes["client.address"], "<masked-clientip-ot>")
metric_statements:
- context: datapoint
statements: *filter-statements
log_statements:
- context: log
Email addresses
Using the transform processor, we mask the attribute user.email with the set statement.
transform:
error_mode: ignore
trace_statements:
- context: span
- set(attributes["user.email"], "<masked-email-ot>")
metric_statements:
log_statements:
- context: log
Dynatrace API tokens
Using the redaction processor, we use the regular expression dt0[a-z]0[1-9]\.[A-Za-z0-9]{24}\.([A-Za-z0-9]{64}) to mask all occurrences of Dynatrace API tokens in our telemetry data.
redaction:
allow_all_keys: true
blocked_values:
- dt0[a-z]0[1-9]\.[A-Za-z0-9]{24}\.([A-Za-z0-9]{64})
summary: info
Usernames
Using the transform processor, we mask the attributes user.id, user.name, and user.full_name with the set statement.
transform:
error_mode: ignore
trace_statements:
- context: span
- set(attributes["user.id"], "<masked-userid-ot>")
- set(attributes["user.name"], "<masked-username-ot>")
- set(attributes["user.full_name"], "<masked-userfullname-ot>")
metric_statements:
log_statements:
- context: log
Credit card numbers
Using the transform processor, we configure three replace_all_patterns statements to mask any occurrences of credit card numbers and mask everything but the last four digits.
transform:
error_mode: ignore
trace_statements:
- context: span
- replace_all_patterns(attributes, "value", "^3\\s*[47](\\s*[0-9]){9}((\\s*[0-9]){4})$", "<masked-pcard$$2-ot>") where IsValidLuhn(attributes["value"])
- replace_all_patterns(attributes, "value", "^(5[1-5]([0-9]){2}|222[1-9]|22[3-9]\\d|2[3-6]\\d{2}|27[0-1]\\d|2720)(\\s*[0-9]){8}\\s*([0-9]{4})$", "<masked-pcard$$4-ot>") where IsValidLuhn(attributes["value"])
- replace_all_patterns(attributes, "value", "^4(\\s*[0-9]){8,14}\\s*(([0-9]\\s*){4})$", "<masked-pcard$$2-ot>") where IsValidLuhn(attributes["value"])
metric_statements:
log_statements:
- context: log
For credit card numbers, it is also possible to use the built-in, standard OTTL function IsValidLuhn() instead of regular expressions, if you prefer to block values altogether instead of just masking them.
IBAN numbers
Using the redaction processor, we use the regular expression ^[A-Z]{2}[0-9]{2}(\\s*[A-Z0-9]){8,30}$ to mask all IBAN occurrences in our telemetry data.
redaction:
blocked_values:
- "^[A-Z]{2}[0-9]{2}(\\s*[A-Z0-9]){8,30}$"
summary: info
Span names
Span names are not stored as attributes in the OTLP message structure, so attribute-based redaction does not apply to them. There are multiple ways of redacting and simplifying span names:
Generate a new span name
Recommended
set_semconv_span_name is available from Collector Contrib version 0.142.0 and Dynatrace Collector version 0.42.0.
Use the transform processor's set_semconv_span_name to derive a low-cardinality name that is compliant with OpenTelemetry semantic conventions. This will use the (low-cardinality) http.request.method and http.route to generate a new span name. It keeps the name consistent with HTTP/RPC/messaging/database conventions and avoids leaking identifiers.
transform:
error_mode: ignore
trace_statements:
- context: span
statements:
- set_semconv_span_name("1.37.0")
Redact the span name explicitly
transform:
error_mode: ignore
trace_statements:
- context: span
statements:
- replace_pattern(name, "(GET /api/v1/users/)\\d+", "$$1{id}")
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we use the following components.
Receivers
Under receivers, we specify the standard otlp receiver as active receiver component for our Collector instance.
Processors
Under processors, we place the configuration for the relevant processor instances.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest logs (logs.ingest), Ingest metrics (metrics.ingest), and Ingest OpenTelemetry traces (openTelemetryTrace.ingest) scopes.
Service pipelines
Under service, we eventually assemble all the configured objects into pipelines for the individual telemetry signals (traces, etc.) and have the Collector instance run the configured tasks.
Related topics
  • Enrich ingested data with Dynatrace-specific fields
Related tags
Application Observability
