Apply memory limits to the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 2-min read
The following configuration example shows how you configure a Collector instance and its native memory limiter processor to guarantee memory allocation keeps within the specified parameters.
Recommended configuration
For optimal memory usage with your Collector instance, we recommend that you apply this configuration with most containerized setups. See the section on deployment considerations for more information.
Prerequisites
  • One of the following Collector distributions with the memory limiter processor:
    • The Dynatrace OTel Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Core or Contrib
    • A custom Builder version
  • The Dynatrace API endpoint URL to which the data should be exported
  • A Classic access token with the relevant access scope (only required for SaaS and ActiveGate)
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Demo configuration
receivers:
otlp:
protocols:
grpc:
endpoint: 0.0.0.0:4317
http:
endpoint: 0.0.0.0:4318
processors:
memory_limiter:
check_interval: 1s
limit_percentage: 90
spike_limit_percentage: 20
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
service:
pipelines:
traces:
receivers: [otlp]
processors: [memory_limiter]
exporters: [otlp_http]
metrics:
receivers: [otlp]
logs:
receivers: [otlp]
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we configure the following components.
Receivers
Under receivers, we specify the standard otlp receiver as active receiver component for our Collector instance.
This is mainly for demonstration purposes. You can specify any other valid receiver here (for example, zipkin).
Processors
Under processors, we specify the memory_limiter processor with the following parameters:
  • check_interval configured to check the memory status every second
  • limit_percentage configured to allow a maximum memory allocation of 90 percent
  • spike_limit_percentage configured to allow a maximum spike memory usage of 20 percent
With this configuration, the OTel Collector checks the memory allocation every second and starts to apply pressure using separate mechanisms after the following limits are reached:
  • Soft limit (limit_percentage - spike_limit_percentage): After this limit is reached, the processor rejects payloads until memory usage is under the limit. It is up to the receiver upstream of the processor to send the proper rejection messages.
  • Hard limit: (limit_percentage): After this limit is reached, the processor will force garbage Collection until memory usage is under the limit. Data will continue to be rejected until usage is under the soft limit.
In addition to the memory limiter processor, we highly recommend you set the GOMEMLIMIT environment variable to a value 80% of the hard limit. Note that GOMEMLIMIT requires an absolute value in bytes to be set. For example, you could set GOMEMLIMIT=1024MiB to start increasing the frequency of garbage collection cycles once the Collector reaches 1024 MiB of memory used on the Go VM heap. For more information, see the Go package documentation describing how the environment variable works.
Deployment considerations
In containerized environments, or other places where the host environment sets the Collector's maximum allowed memory, we recommend you use the limit_percentage and spike_limit_percentage options.
For deployments on virtual machines or bare metal where the Collector is not given an explicit memory quota, we instead recommend you use the limit_mib and spike_limit_mib options.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest logs (logs.ingest), Ingest metrics (metrics.ingest), and Ingest OpenTelemetry traces (openTelemetryTrace.ingest) scopes.
Service pipelines
Under service, we assemble our receiver and exporter objects into pipelines for traces, metrics, and logs and enable our memory limiter processor by referencing it under processors for each respective pipeline.
Limits and limitations
Data is ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP APIs and is subject to the API's limits and restrictions. For more information see:
  • OpenTelemetry metrics limitations
  • Dynatrace metrics mapping
  • Ingest OpenTelemetry logs
Related topics
  • Enrich ingested data with Dynatrace-specific fields
  • Enrich OTLP requests with Kubernetes data (Dynatrace Classic)
Related tags
Application Observability
